The PICnDuino
The PICnDuino is an Open Source dual microcontroller development platform built into a tiny direct to USB device. It is compatible with both Arduino and Amicus18 which have an already established fan base giving you instant access to hundreds of tutorials, code examples, project designs and support forums.
PICnDuinoRed
For the more adventurous users, you can even use the PICnDuino with loads of other programming languages such as MPLAB and Swordfish.
Pre-ordering for the PICnDuino is now over. I am looking into selling these online later this year.
Great For Everyone
The PICnDuino provides a fantastic opportunity to learn two programming languages in one device (Arduino which is C and Amicus18 which is Basic).
ArduinoLEDBlinkCode AmicusLEDBlinkCode
The PICnDuino doesn’t require any special programmer or extra hardware to work. You just plug it in to USB and start coding. The software is free to download and since the PICnDuino has four user programmable LED’s onboard – you can can get started straight away with the LED Blink and Fader examples. Perfect for beginners!
Configure to your needs
The PICnDuino comes with male and female headers not yet soldered on, this allows you to configure it to your needs.
DifferentVarieties
Soldering on male and female headers is ideal for those wanting to plug the PICnDuino in a breadboard – great for experimenting!
PICnDuinoBreadboard
Main Features
  • Direct to USB interface – no special programmer or power supply required
  • Atmega 328P microcontroller (compatible with Arduino)
  • PIC18F25K20 microcontroller (compatible with Amicus18)
  • Seven onboard LED’s (four of which can be directly controlled with the microcontrollers)
  • Two reset buttons (one for each microcontroller)
  • Microcontroller select switch (both microcontrollers run simultaneously, however this switch selects which one has access to the USB port. You can even select between them on the fly without powering down, unplugging or resetting the PICnDuino).
  • A combined total of 44 I/O pins providing standard digital pins, analog, SPI, I2C, PWM, Interrupts and USART.
  • A combined total of 64KB of program memory (some memory space is taken up by the Arduino and Amicus18 bootloaders)
PICnDuino
What can the PICnDuino do?
The PICnDuino can perform a huge range of tasks, from the most basic LED blinker example as seen above, to recording GPS co-ordinates to an SD card or perhaps even making your own home video game system. The PICnDuino has many inbuilt features often only found in more expensive devices, but for a fraction of the price.
Here’s the PICnDuino fading a couple of LED’s via PWM (one LED per Microcontroller).
PICnDuinoUSB
Here’s the PICnDuino running dual LCD screens – (one display per microcontroller).
TwoLCDs
Here’s the PICnDuino sending data to the computer via USART.
SerialData
Here’s the PICnDuino running a River Raid type game on an RGB LED matrix display with a Super Nintendo control pad.
RiverRaid
What is the PICnDuino compatible with?
The PICnDuino currently only runs with Windows. It will however work with a virtualisation environment such as parallels desktop on a Mac (as seen in the video clip).
The PICnDuino is plug and play compatible with Arduino and Amicus18 software. It will also work with other programs like Swordfish Basic (which is my favourite IDE) – it just requires you to tell the software that this is the programmer that you want to use.
SideBySideCode
What do you get?
Each PICnDuino reward comes with male and female headers (as shown below). The headers are the only components not soldered to the board – this allows you to configure the PICnDuino to your requirements.
WhatDoYouGet
You can download the PICnDuino Archive here:
Downloads
PICnDuinoFiles
The download contains schematic, pinout, PCB layout, Dimensions, Mac and Linux instructions (for the Arduino side of things) and more. (Thanks to Jason for the Linux Write up and Macdefender for the Mac write up).
0 0 votes
4 Comments
Hi Brad, I was looking for PicnDuino pwm capable ports and came across a site, where your PicnDuino seems to be for sale:
http://fabtolab.com/PIC-n-Duino
You know anything about it being sold/remade?
AND: are the PWM capable ports the same as on the Uno? Been a while, but finally have some time to delve further into this convenient little gadget.
Hi Thierry, I had seen that they were being sold which is fair enough since it was all open hardware / open source. I wonder how many they have sold?
The PWM ports are exactly the same as the Arduino Nano:
http://arduino.alhin.de/images/Boards/nano_pins.png
Be sure to let me know what projects you come up with 🙂
Good to know someone found your project worth while enough to reproduce it!
Concerning Nano, thanks mate, that explains everything. Didn’t know it worked exactly like a Nano, newbie as I am. 🙂
[…] The PICnDuino was used as the microcontroller for the project (this is a dual microcontroller development platform that I made back in 2012, you can see more info on that HERE) […]
16
toto
toto togel
toto
toto
toto
situs togel
slot
toto slot
