1266:
Post
by bitfogav » Wed Jun 29, 2011 8:49 pm
Heres how to connect up some 10F, 12F and 16F series microchips, I will add some 18F series soon
- Pickit216frange.jpg (74.62 KiB) Viewed 36238 times
Heres the links on the picture:
For other PIC Microcontrollers, refer to the datasheet to identify the correct pin connections:
http://www.microchip.com/en_US/family/8bit/index.html
See also PICkit 2 User’s Guide:
http://ww1.microchip.com/downloads/en/D ... 51553E.pdf
Some other notes, make sure that you have no components connected to the ICSPDAT and ICSPCLK Lines, has this can stop the pickit2/3 communicating to your microcontroller, especially if you are programming the microcontroller in circuit.
Post
by brad » Wed Jun 29, 2011 9:52 pm
Very nice bitfogav!
Post
by bitfogav » Fri Jul 01, 2011 7:29 pm
Heres an updated version, inc connecting up 40pin microchips.
- Connecting pickit to microcontrollers1.jpg (118.83 KiB) Viewed 36235 times
If you would like to download this information for reference purposes then you can download my PDF I put together.
Post
by brad » Sat Jul 02, 2011 10:28 pm
Even better! Just downloaded it
Post
by bitfogav » Sat Jul 02, 2011 11:05 pm
thank you Brad
Post
by sdudley » Sat Jul 09, 2011 11:48 pm
Thanks bifogav!
nodoubtman
Post
by nodoubtman » Wed Mar 07, 2012 12:11 am
Thank you so much Brad!
Before i was unable to program my pic10fxx series, now i can... thank you so much Brad!
you are the best!
marC:)
Post
by brad » Thu Mar 08, 2012 7:36 pm
No problem, but bitfogav was the one who made this awesome chart
theenggprojects
- newbie
Post
by theenggprojects » Wed Aug 31, 2016 10:58 pm
Thanks for this awesome tutorial, helped me a lot in my project.
Post
by bitfogav » Wed Aug 31, 2016 11:16 pm
@theenggprojects
Glad you found it useful..
Post
by brad » Fri Sep 02, 2016 8:43 pm
theenggprojects wrote:Thanks for this awesome tutorial, helped me a lot in my project.
What project have you been working on?
1266:
1266:
