Schematic
Post here to discuss The Great Race.
1kiko1
Schematic
Post by 1kiko1 » Sun Jul 03, 2011 2:16 am
here is my finished schematic
The Great Race Schematic.jpg (311.88 KiB) Viewed 40081 times
rd1196
Re: Schematic
Post by rd1196 » Mon Oct 17, 2011 10:22 am
What pins exactly are connected to the buttons? Because I always seem to connects the wrong button to each pin so the car moves to the opposite side of the button
Re: Schematic
Post by brad » Mon Oct 17, 2011 8:45 pm
Are you sure that you aren't just putting your buttons on the wrong sides?
Re: Schematic
Post by sdudley » Mon Oct 17, 2011 9:01 pm
Maybe the buttons are on backwards? :shock:
Sorry, I couldn't resist! :P
rd1196
Re: Schematic
Post by rd1196 » Tue Oct 18, 2011 10:51 am
Yeah you are probably right, I just wanted to make sure because it seemed odd that of the 3games ive build i had to change the button connections on all 3 of them
rd1196
Re: Schematic
Post by rd1196 » Tue Oct 18, 2011 11:38 am
What do you mean by putting the buttons backwards? I thought it was the same to put the buttons one way or rotated 90 deegres
Re: Schematic
Post by sdudley » Tue Oct 18, 2011 12:29 pm
rd1196 wrote:What do you mean by putting the buttons backwards? I thought it was the same to put the buttons one way or rotated 90 deegres
I was joking. You mentioned the cars going the opposite direction so I couldn't resist making a joke, sorry! :D
Yes, the buttons work both ways.
rd1196
Re: Schematic
Post by rd1196 » Wed Oct 19, 2011 11:12 am
I know it was a joke but could that really be the problem? I mean if either side is fine (up or down) why if I use the connections shown on that schematic (the one provided by 1kiko1) the car goes the opposite sides?
Re: Schematic
Post by brad » Wed Oct 19, 2011 8:43 pm
One thing to note with the buttons is that there are four connections although they are shorted together on opposite sides to really give you just two connections. So just be mindful of where you connect your wires to.
rd1196
Re: Schematic
Post by rd1196 » Thu Oct 20, 2011 11:40 am
http://www.sparkfun.com/datasheets/Comp ... /00097.jpg in this picture you can see the internal connections of the buttons so I think the way to do it is connect either the ground or the microcontroller to pin 1 or 2 and the other one to pin 3 or 4, I mean I think it is the same to use 1-3 or 2-4. Brad using that picture what connections do you think would be wrong to do while using those buttons?
Re: Schematic
Post by bitfogav » Fri Oct 21, 2011 1:30 am
I think you have put your LEFT button to pin RA7 and your RIGHT button to RA6.. When you really need to connect your LEFT button to RA6 and your RIGHT button to RA7 of the microcontroller pins.
rd1196
Re: Schematic
Post by rd1196 » Fri Oct 21, 2011 9:30 am
I did connect RA6 to the left button and RA7 to the right but on the schematic on top of the topic it is actually the other way around
1kiko1
Re: Schematic
Post by 1kiko1 » Fri Oct 28, 2011 2:05 am
ricky i did it the way in my schematic and i had no problem play with the cables and you will get success :D
