Schematic
- 1kiko1
- Joined: Wed Jun 29, 2011 11:16 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Schematic
here is my finished schematic
- The Great Race Schematic.jpg (311.88 KiB) Viewed 40087 times
- Joined: Mon Aug 30, 2010 8:05 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Schematic
What pins exactly are connected to the buttons? Because I always seem to connects the wrong button to each pin so the car moves to the opposite side of the button
Re: Schematic
Are you sure that you aren't just putting your buttons on the wrong sides?
- sdudley
Re: Schematic
Maybe the buttons are on backwards?
Sorry, I couldn't resist!
Re: Schematic
Yeah you are probably right, I just wanted to make sure because it seemed odd that of the 3games ive build i had to change the button connections on all 3 of them
Re: Schematic
What do you mean by putting the buttons backwards? I thought it was the same to put the buttons one way or rotated 90 deegres
- sdudley
Re: Schematic
I was joking. You mentioned the cars going the opposite direction so I couldn't resist making a joke, sorry!rd1196 wrote:What do you mean by putting the buttons backwards? I thought it was the same to put the buttons one way or rotated 90 deegres
Yes, the buttons work both ways.
Re: Schematic
I know it was a joke but could that really be the problem? I mean if either side is fine (up or down) why if I use the connections shown on that schematic (the one provided by 1kiko1) the car goes the opposite sides?
Re: Schematic
One thing to note with the buttons is that there are four connections although they are shorted together on opposite sides to really give you just two connections. So just be mindful of where you connect your wires to.
Re: Schematic
http://www.sparkfun.com/datasheets/Comp ... /00097.jpg in this picture you can see the internal connections of the buttons so I think the way to do it is connect either the ground or the microcontroller to pin 1 or 2 and the other one to pin 3 or 4, I mean I think it is the same to use 1-3 or 2-4. Brad using that picture what connections do you think would be wrong to do while using those buttons?
Re: Schematic
I think you have put your LEFT button to pin RA7 and your RIGHT button to RA6.. When you really need to connect your LEFT button to RA6 and your RIGHT button to RA7 of the microcontroller pins.
Re: Schematic
I did connect RA6 to the left button and RA7 to the right but on the schematic on top of the topic it is actually the other way around
- 1kiko1
Re: Schematic
ricky i did it the way in my schematic and i had no problem play with the cables and you will get success
