Sample Sketches not working in IDE 1.5.8 BETA
Post here to discuss all things DigiPixel related.
synd
Post by synd » Thu Jan 08, 2015 5:11 am
The PROGMEM is changed in this Version! The Compiler is reporting an Error, that only a Constant can be written in this Part of the Memory! Does anyone know a solution, what to change in the code so it works?
Many thanks for help! Because working with the avr-libs is new for me!
Re: Sample Sketches not working in IDE 1.5.8 BETA
Post by brad » Thu Jan 08, 2015 10:35 am
Hmm, that's interesting.
Can you post your code just to make sure we're looking at the same thing?
synd
Post by synd » Fri Jan 09, 2015 4:51 am
Hi, i found already a solution! You have to write a "const" in front of the declaration!
for example:
// Program memory arrays
const byte numberTable[30]PROGMEM={0b01111110, 0b01000010, 0b01111110, 0b0010001..........
many thanks!
Post by brad » Sat Jan 10, 2015 1:53 pm
Great work synd, thanks for updating us!
theenggprojects
Post by theenggprojects » Mon Sep 05, 2016 7:45 pm
Thanks a lot bro, I was also having the same problem, now it works ... Thumbs up.
You should also check The Engineering Projects because they have posted a lot of Arduino Projects and PIC Mirocontroller Projects and have also designed many new Proteus Tutorials and C# Tutorial. I hope you guys are gonna like them.
