Digipixel Piezo
- ZephaniahNoah
- semi-newbie
- Location: Milky Way, Earth [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Digipixel Piezo
I was just wondering how to use the Piezo buzzer on the DigiPixel. It goes here right? I soldered the negative lead to the square hole and positive to the circle.
How would I figure out which pins to send the sound to? I'm a complete newbie to the DigiPixel as well as Arduino but I've made games in other computer languages and I was able to create something simple for the DigiPixel. I've barely worked with micro-controllers and don't know how to add sound to my game.
EDIT: Just in case anyone was wondering I soldered the Piezo on wrong. Don't do it the way I did.
Last edited by ZephaniahNoah on Fri Jan 02, 2015 6:02 pm, edited 3 times in total.
Re: Digipixel Piezo
The piezo speaker connection was a bit of a late requested addition and as such I didn't write any code for it myself however the main thing you need to know is that it is connected to the Arduino pin 9.
So if you have a look on google for 'arduino sound' or something to that effect, you should get some pretty good tutorials.
Here is one such example:
http://arduino.cc/en/pmwiki.php?n=Reference/tone
Just remember that your piezo speaker is connected to pin 9
- ZephaniahNoah
- semi-newbie
Re: Digipixel Piezo
Awesome! Thanks, I'll have a look.brad wrote:The piezo speaker connection was a bit of a late requested addition and as such I didn't write any code for it myself however the main thing you need to know is that it is connected to the Arduino pin 9.
Re: Digipixel Piezo
I was going to say isn't that the wrong way around for the piezo connections? but I see you have now updated your post
How did you get on with this ZephaniahNoah? I was hoping to try out this too
- ZephaniahNoah
- semi-newbie
Re: Digipixel Piezo
It went well. Any time I wanted my game to play a sound I just added:bitfogav wrote:I was going to say isn't that the wrong way around for the piezo connections? but I see you have now updated your post
tone(9, frequency, duration);
However, if I wanted to play a little jingle when the player died I would have to put a delay(X); and set X to the previous tone's duration. For instance, if I were to just do... :
tone(9, 100, 100);
tone(9, 200, 100);
tone(9, 300, 100);
tone(9, 100, 100);
delay(100);
tone(9, 200, 100);
delay(100);
tone(9, 300, 100);
The link brad provided was very useful and I was able to look up pretty much everything else on the web but other than that it was quite simple.
Re: Digipixel Piezo
What you could do is look into using interrupts. You can set the interrupt for a certain amount of time (like your delays) but your code still runs and then when that certain amount of time has ticked over, the interrupt will trigger your audio code.
- ZephaniahNoah
- semi-newbie
Re: Digipixel Piezo
Ok, I'll look into that.brad wrote:What you could do is look into using interrupts. You can set the interrupt for a certain amount of time (like your delays) but your code still runs and then when that certain amount of time has ticked over, the interrupt will trigger your audio code.
Re: Digipixel Piezo
Infant the tone function uses interrupts itself in the form of timer2
