Post
by brad » Tue Jun 01, 2010 6:05 am
I will check but I am 99% sure that you do need to connect the shielding to ground.
Basically you get exactly 50 ohms between the shielding and the inner conductor, so if you leave one side disconnected (from ground) then you are not completing the circuit.
- Moderator
Post
by bitfogav » Tue Jun 01, 2010 6:06 am
yeah I thought so, I did connect it to ground
Post
by brad » Tue Jun 01, 2010 6:08 am
Sorry I forgot to say that if the other side is not terminated then you are still not completing the circuit
How long is your antenna?
- Moderator
Post
by bitfogav » Tue Jun 01, 2010 6:11 am
It is 23cm long.. so I need to get some coax ends?
these would look abit naff on the aerial though!! haha!
[/url]
- coax connectors.jpg (6.91 KiB) Viewed 11515 times
- Moderator
Post
by bitfogav » Fri Jul 23, 2010 2:53 am
brad wrote:I will check but I am 99% sure that you do need to connect the shielding to ground.
Hi Brad did you find out any more about connecting the shielding to ground?
Post
by brad » Fri Jul 23, 2010 6:19 am
Im sorry, I forgot to reply!
Yes, the shielding does connect to ground
1266:
