Beat Detection using an op-amp
Re: Beat Detection using an op-amp
Ive been looking at ways of improving my original circuit and using a tone decoder?
http://www.classiccmp.org/rtellason/chipdata/ba1604.pdf
Contains a comparator circuit with an output logic, but you can set the frequency to precisely.
- odessa
Hi all,
Heres a vid of mine running using the LM324. I used the same 10k resistor you did Gav for the mic ( rather than the 1k i was using ) and its much more responsive overall now. The variable resistor on the comparator helps to set the threshold just right.
(\_/)
Great video Jay
That's so cool! That little LED is jammin' to the music!
- odessa
(\_/)
How about connecting it to a strobe light?
- odessa
Thats a great idea
(\_/)
Ive revisited this beat detection circuit at the weekend for a new project, and I have made up a pcb test board using smd parts. I want to see how the circuit will preform using smd, in the mean time Sparkfun has just posted a great video which is perfect on this subject, which I thought I would share, will add it at the end of this post.
heres some images from my smd board:
Nice board Gav! I'm guessing you used your famous PCB etching method - obviously works like a charm!
I've just been re-reading all the posts from this topic and realised that I didn't answer Odessa about the clamper circuit. I wonder where he's gone?
Yeah I used my etching methodbrad wrote:Nice board Gav! I'm guessing you used your famous PCB etching method - obviously works like a charm!
Yeah not sure where Odessa has gone!?brad wrote:I've just been re-reading all the posts from this topic and realised that I didn't answer Odessa about the clamper circuit. I wonder where he's gone?
Well. It looks great
Have you got a permanent home for the circuit?
Well this smd circuit is a test for my next iteadstudio pcb project
but I have just received a very nice strip of RGB leds which I might attached this circuit too
Link to the RGB led strip that I have just received:
http://www.ebay.co.uk/itm/160913879395? ... 1439.l2649
- odessa
Hi Guys .... I'm still here
I've been very busy with work etc and have just landed a new job
I'm still very much into my electronics and have been concentrating on C mostly ( and my many arduinos )
I'll post up some of my recent stuff when I get a chance... I've also just bought exactly the same remote/ Led controller as you Gav, I was going to make my own but when you can buy a controller and remote for £6 on ebay it hardly seems worth the effort.
Hope you are both doing well
Jay
Jay
(\_/)
Hi Jay - good to hear from you
I too have been looking into Arduino - infact I made a little Arduino / Amicus18 compatible device - the PICnDuino.
http://www.bradsprojects.com/electronic ... Duino.html
C is a great language and very similar to Basic I have found (except you need one of these ; at the end of each line...)
Great to hear you're still into your projects.
As for those LED strips - It never ceases to amaze me just how cheap you can get things like this for. Look forward to seeing what becomes of those Gav
Hi Jay, Nice to hear from you. hope your well.odessa wrote:I've also just bought exactly the same remote/ Led controller as you Gav, I was going to make my own but when you can buy a controller and remote for £6 on ebay it hardly seems worth the effort.
I got my led strip and i'm very pleased!, seems a shame that I want to cut it up and use it for a project haha!.
Users browsing this forum: No registered users and 16 guests
