Can I tempt you into using basic and a pic microcontroller
const prog_uint32_t MAPGreen3[97] PROGMEM = { 0, 1, whatever numbers you want};
pgm_read_dword(&MAPGreen2[x])
//First game engine started by Joshua Little 10/08/12
//Overhead view designed to be used on LED matrix displays of any desired size
#include <avr/pgmspace.h>
#include <LiquidCrystal.h> // include the library code
char name[][7] = {
{"Josh:"},
{"Zach:"},
{"Alex:"},
{"Corb:"},
byte displayY = 8;
byte displayX = 8;
byte spaceData = 0;
byte middleY = ((displayY/2)-1); //the middle of the display - 1
byte middleX = ((displayX/2)-1); //the middle of the display - 1
byte RAM = 0; //temp data used to check changes
byte lcdRefresh[] = {0, 0, 0, 0,}; //if true then LCD is refreshed
//debug
byte fps; //tha mount of frames per second
byte fpsOn = 0;
unsigned long fpsTimer = 0;
byte fpsToggle = 0;
//end debug
//LCD
byte heart[] = {0, 0, 033, 037, 016, 016, 004, 0, 0};
byte stickPerson[] = {016, 016, 004, 037, 004, 004, 012, 021};
byte skull[] = {0, 016, 037, 025, 037, 016, 0, 0};
//end LCD
//pins
LiquidCrystal lcd1(2, 7, 3, 4, 5, 6); // Rs, Enable, D4, D5, D6, D7 Controls all LCDs with 9 pins
LiquidCrystal lcd2(2, 8, 3, 4, 5, 6); // Rs, Enable, D4, D5, D6, D7
LiquidCrystal lcd3(2, 9, 3, 4, 5, 6); // Rs, Enable, D4, D5, D6, D7
LiquidCrystal lcd4(2, 9, 3, 4, 5, 6); // Rs, Enable, D4, D5, D6, D7
byte clockPin595 = 10; //595 shift register pins
byte dataPin595 = 11;
byte latchPin595 = 12;
byte muxPin[][4] = {
{13, A1, A2},
{A3, A4, A5},
byte muxInPin = A0;
//end pins
//digital buttons
byte playerButton[][9] = { //indicates whether a player's button is pressed or not
{0, 0, 0, 0, 0, 0, 0, 0,}, //the first 0 is the directional pad, 1 is up, 2 down, 3 left, 4 right
byte swordButton[] = {0, 0, 0, 0,};
byte shieldButton[] = {0, 0, 0, 0,};
byte directionButton[][4] = {0, 0, 0, 0,};
byte startButton[] = {0, 0, 0, 0,};
//end digital buttons
//matrix stuff
byte displayData[2][9] = {0, 0,};
byte tempAnodeData[] = {0, 0, }; //used to store individual values of the anode strings
byte tempCathodeData[] = {0, 0, 0,}; //used to store individual values of the cathode strings
byte anodeString[9] = {0b00000001, 0b00000010, 0b00000100, 0b00001000, 0b00010000, 0b00100000, 0b01000000, 0b10000000}; //scans the anode rowns
byte cathodeData[][9] = {
{0b00000000, 0b00000000, 0b00000000, 0b00000000, 0b00000000, 0b00000000, 0b00000000, 0b00000000,},
//end matrix stuff
//manual modifiers
int immunityTime[] = {1000, 1000, 1000, 1000,}; //how long a player can't get hurt after they are hit
int swordDamageDefault[] = {1, 1, 1, 1,}; //default sword damage for each player
int swordAttackTime[] = {750, 750, 750, 750,}; //the amount of time a sword is out for
int swordAttackDelay[] = {750, 750, 750, 750,}; //the amount of time until a sword can be used again
byte playerDefaultSpawnHealth[] = {5, 5, 5, 5,}; //the amount of health a player will spawn with by default
byte playerStartingHealth[] = {5, 5, 5, 5,}; //how much health a player starts with
byte playerSpawnLocation[][4] = { //where the player will spawn to upon death {x, y, map}
{5, 6, 0,}, // {x, y, map, sub-map}
{9, 6, 0,},
{9, 9, 0,},
{5, 9, 0,},
byte playerPos[][5] = { // where each player is (and starts upon game start)
{9, 7, 0,},
{9, 9, 0,},
{5, 9, 0,},
byte playerStartingLives[] = {3, 3, 3, 3,}; //the amount of lives each player starts with
int playerMovementDelay[] = {350, 350, 350, 350,}; //amount of time in milliseconds before a player can move again after moving
//end manual modifiers
//automated modifiers
byte swordDamageAdded[] = {0, 0, 0, 0,}; //added sword damage modifier
byte playerAddedSpawnHealth[] = {0, 0, 0, 0,}; //the amount added to the player's default spawn health
byte playerLivesGained[] = {0, 0, 0, 0,};// the amount of lives each player has gained
//end automated modifiers
//calculated values
byte swordDamage[] = {0, 0, 0, 0,}; //calculated sword damage
byte playerSpawnHealth[] = {0, 0, 0, 0,}; //the total amount of health a player will spawn with
byte playerHealth[] = {0, 0, 0, 0}; //the player's health
int playerHealthAdded[] = {0, 0, 0, 0,}; //health added from having died
int playerHealthGained[] = {0, 0, 0, 0,}; //the amount of health the player has gained
byte playerLives[] = {0, 0, 0, 0}; //the current amount of lives each player has
//end calculated values
//game modifiers
byte currentPlayers[] = {1, 1, 1, 1,}; //the current players playing. if lives = 0, current players = 0 !!!!need to automate this function
byte playerCount = 4; //the amount of players that are playing. !!!!need to automate this function
byte PvP = 1; //0 is off, 1 is on, allows players to hurt each other !!!!need to automate this function
byte startAttack[] = {0, 0, 0, 0,}; //needed to determine if player can attack or not
byte directionAllow[] = {1, 1, 1, 1,}; //allows the direction of the player to change
//end game modifiers
//time values
unsigned long swordTimer[] = {0, 0, 0, 0,}; // a timer per player needed for the sword attack function
unsigned long swordDelayTimer[] = {0, 0, 0, 0,}; //when the last sword attack was
unsigned long time;
unsigned long playerTimeSinceMovement[] = {0, 0, 0, 0,}; //the last time the player has moved is stored here
unsigned long immunityTimer[] = {0, 0, 0, 0,};
//end time values
//coordinates
byte swordPosition[][4] = { //the location of the player's swords
{0, 0, 0,},
{0, 0, 0,},
{0, 0, 0,},
{0, 0, 0,},
byte shieldPosition[][4] = { //the location of the players's shields
{0, 0, 0,},
{0, 0, 0,},
{0, 0, 0,},
{0, 0, 0,},
//end coordinates
//statistics
int playerScore[] = {0, 0, 0, 0}; //the score of each player
int playerHitsTaken[] = {0, 0, 0, 0}; //the amount of hits the player has taken !!! not scripted
int playerDeaths[] = {0, 0, 0, 0}; //the amount of times a player has died
int playerHits[] = {0, 0, 0, 0}; //amount of times player has hit an enemy !!! not scripted
int playerDamageDealt[] = {0, 0, 0, 0,}; //the amount of damage the player has done !!! not scripted
int playerDamageTaken[] = {0, 0, 0, 0,}; //the amount of damage the player has recieved !!! not scripted
//end statistics
//player modifiers
byte playerCondition[] = {0, 0, 0, 0}; //states if a player has any special status effects !!!!!not scripted
byte playerDirection[] = {0, 0, 0, 0}; //which way the player is facing //1 is up, 2 is down, 3 is left, 4 is right
byte playerMaxLives = 0; // the maximum amount of lives a player can have, 0 = infinite !!!!!not scripted
byte playerMaxHealth = 0; //the maximum amount of health a player can have, 0 = infinite !!!!!not scripted
int playerCurrency[] = {0, 0, 0, 0,}; //the amount of money a player has !!!!!not scripted
byte playerLastMoved[] = {0, 0, 0, 0,}; //the last direction the player moved in
//end player modifiers
byte wallData = 1; //the number of a wall in the map
const prog_uint32_t MAP0[97] PROGMEM= //the maps in the game
0b11111111111111111111111111111111, 0b11111111111111111111111111111111, //1
0b10000000000000000000000000000000, 0b00000000000111111111111111111111,
0b10000000000000000000000000000000, 0b00000000000110000000000000000011,
0b10000000000000000000000000000000, 0b00000000000110000000011101110011, //5
0b10000000000000000000000000000000, 0b00000000000110000000010101010011,
0b10000000000000000000000000000000, 0b00000000000000000000000000000011,
0b10000000000000000000000000000000, 0b00000000000110000000010101010011, //10
0b10000000000000000000000000000000, 0b00000000000110001100011101110011,
0b10000000000000000000000000000000, 0b00000000000110011111011101110011,
0b10000000000000000000000000000000, 0b00000000000110011111000000000011,
0b10000000000000000000000000000000, 0b00000000000110111110000000000111,
0b10000000000000000000000000000000, 0b00000000000110011100000000011111, //15
0b10000000000000000000000000000000, 0b00000000000110000000000001111111,
0b10000000000000000000000000000000, 0b00000000000110000000000011111001,
0b10000000000000000000000000000000, 0b00000000000110000000000111100001,
0b10000000000000000000000000000000, 0b00000000000111111111111111000001,
0b10000000000000000000000000000000, 0b00000000000111111111111110000001, //20
0b10000000000000000000000000000000, 0b00000000000000000000000000000001,
0b10000000000000000000000000000000, 0b00000000000000000000000000000001, //25
0b10000000000000000000000000000000, 0b00000000000000000000000000000001, //30
0b10000000000000000000000000000000, 0b00000000000000000000000000000001, //32
0b10000000000000000000000000000000, 0b00000000000000000000000000000001, //1
0b10000000000000000000000000000000, 0b00000000000000000000000000000001, //5
0b10000000000000000000000000000000, 0b00000000000000000000000000000001, //10
0b10000000000000000000000000000000, 0b00000000000000000000000000000001, //15
const prog_uint32_t MAP1[97] PROGMEM= //the maps in the game
0b11111111100000000000000000000000, 0b00000000000000000000000000000000, //1
0b10000000100000000000000000000000, 0b00000000000000000000000000000000,
0b10000000100000000000000000000000, 0b00000000000000000000000000000000, //5
0b11110111100000000000000000000000, 0b00000000000000000000000000000000,
0b00000000000000000000000000000000, 0b00000000000000000000000000000000,
0b00000000000000000000000000000000, 0b00000000000000000000000000000000, //10
0b00000000000000000000000000000000, 0b00000000000000001100000000000000,
0b00000000000000000000000000000000, 0b00000000000000011111000000000000,
0b00000000000000000000000000000000, 0b00000000000000111110000000000000,
0b00000000000000000000000000000000, 0b00000000000000011100000000000000, //15
0b00000000000000000000000000000000, 0b00000000000000000000000000000000, //20
0b00000000000000000000000000000000, 0b00000000000000000000000000000000, //25
0b00000000000000000000000000000000, 0b00000000000000000000000000000000, //30
0b00000000000000000000000000000000, 0b00000000000000000000000000000000, //32
0b00000000000000000000000000000000, 0b00000000000000000000000000000000, //5
0b00000000000000000000000000000000, 0b00000000000000000000000000000000, //15
const prog_uint32_t MAP2[97] PROGMEM= //the maps in the game
const prog_uint32_t MAP3[97] PROGMEM= //the maps in the game
const prog_uint32_t MAPGreen0[97] PROGMEM = { //the maps in the game
const prog_uint32_t MAPGreen1[97] PROGMEM = { //the maps in the game
const prog_uint32_t MAPGreen2[97] PROGMEM = { //the maps in the game
const prog_uint32_t MAPGreen3[97] PROGMEM = { //the maps in the game
void setup(){
pinMode(latchPin595, OUTPUT); //sets shift register pins as output
pinMode(clockPin595, OUTPUT);
pinMode(dataPin595, OUTPUT);
for(int p = 0; p < 2; p++){ // for each set of 4051s
for(int q = 0; q < 3; q++){ //for each pin going to the 4051s
pinMode(muxPin[p][q], OUTPUT); //sets pins as outputs and pulls low
digitalWrite(muxPin[p][q], LOW);
pinMode(muxInPin, INPUT); //sets the 4051 input pin as an input
lcd1.createChar(1, stickPerson);
lcd1.createChar(2, heart);
lcd1.createChar(3, skull);
lcd2.createChar(1, stickPerson);
lcd2.createChar(2, heart);
lcd2.createChar(3, skull);
lcd3.createChar(1, stickPerson);
lcd3.createChar(2, heart);
lcd3.createChar(3, skull);
lcd4.createChar(1, stickPerson);
lcd4.createChar(2, heart);
lcd4.createChar(3, skull);
lcd1.begin(16, 2); //defines amount of LCD rows and columns
lcd2.begin(16, 2); //defines amount of LCD rows and columns
lcd3.begin(16, 2); //defines amount of LCD rows and columns
lcd4.begin(16, 2); //defines amount of LCD rows and columns
void loop(){
controls(); //what button controls what
numberCalculating(); //calculates health, lives, etc.
lcdDisplay(); //displays the LCD
playerMovements(); //moves the player based on player controlls
playerLocationScripts(); //scripts that run based on player's location
playerAttacks(); //runs player attack codes
shield();
playerLocationUpdates(); //moves the player out of walls, etc.
damage(); //calculates who or what gets hurt by how much
debug(); //debug scrips (can remove)
playerScripts(); //scripts such as death
matrixDisplay(); //displays the matrix data
void damage(){
swordDamageUpdate();
void controls(){
controllers();
assignButtons();
void matrixDisplay(){
dataDisplayScrolling();
matrixDisplay8x8Bi();
void playerAttacks(){
sword();
void playerLocationUpdates(){
shieldUpdate(); //moves players if they are in a shield or if their shield is in another person's
wallCheck(); //checks if the player is in a wall and fixes it
void playerMovements(){
playerMovement(); //moves player if movement button is pressed
void playerLocationScripts(){
playerTeleport();
void playerScripts(){
death();
void shieldUpdate(){
for(int x = 0; x < playerCount; x++){ //for each player
for(int y = 0; y < playerCount; y++){ //for each other player
if((y != x)){
if((playerPos[y][0] == shieldPosition[x][0]) && (playerPos[y][1] == shieldPosition[x][1]) && (playerPos[y][2] == shieldPosition[x][2])){ // if another player is in the same location as the shield
playerTimeSinceMovement[x] = (time + long(playerMovementDelay));
if(playerDirection[x] == 0){
playerPos[y][1]--;
playerLastMoved[y] = 0;
if(playerDirection[x] == 1){
playerPos[y][1]++;
playerLastMoved[y] = 1;
if(playerDirection[x] == 2){
playerPos[y][0]++;
playerLastMoved[y] = 2;
if(playerDirection[x] == 3){
playerPos[y][0]--;
playerLastMoved[y] = 3;
if((shieldPosition[y][2] !=1) && (y != x)){ //if a shield is in the same place as another shield
if((shieldPosition[y][0] == shieldPosition[x][0]) && (shieldPosition[y][1] == shieldPosition[x][1]) && (shieldPosition[y][2] == shieldPosition[x][2])){
playerTimeSinceMovement[y] = (time + long(playerMovementDelay));
playerPos[x][1]++;
playerLastMoved[x] = 1;
playerPos[x][1]--;
playerLastMoved[x] = 0;
playerPos[x][0]--;
playerLastMoved[x] = 3;
playerPos[x][0]++;
playerLastMoved[x] = 2;
if(playerDirection[y] == 0){
playerPos[y][1]++;
if(playerDirection[y] == 1){
playerPos[y][1]--;
if(playerDirection[y] == 2){
playerPos[y][0]--;
if(playerDirection[y] == 3){
playerPos[y][0]++;
void shield(){
if(shieldButton[x] == 0){ //if the shield is not out
directionAllow[x] = 1; //allow player to change directions
shieldPosition[x][0] = 0; //despawn the shield
shieldPosition[x][1] = 0;
shieldPosition[x][2] = 1;
if(shieldButton[x] == 1 && startAttack[x] == 1){ //if the shield button is pressed an the player is allowed to attack
directionAllow[x] = 0; // prevent the player from turning
shieldPosition[x][0] = playerPos[x][0];
shieldPosition[x][1] = (playerPos[x][1] - 1);
shieldPosition[x][2] = playerPos[x][2];
shieldPosition[x][1] = (playerPos[x][1] + 1);
shieldPosition[x][0] = (playerPos[x][0] + 1);
shieldPosition[x][1] = playerPos[x][1];
shieldPosition[x][0] = (playerPos[x][0] - 1);
void playerTeleport(){
if(playerPos[x][2] == 0){ //if a player is on map 0
if((playerPos[x][0] == 5) && (playerPos[x][1] == 5)){ //if player is in player house 1
playerPos[x][0] = 59;
playerPos[x][1] = 6;
playerPos[x][2] = 1;
playerLastMoved[x] = 5;
if(playerPos[x][2] == 1){ // if player is on map 1
if((playerPos[x][0] == 59) && (playerPos[x][1] == 7)){ //if player is in player house 1
playerPos[x][0] = 5;
playerPos[x][2] = 0;
void controllers(){
for(int a = 0; a < playerCount; a++){ //for each extra IC
for(int b = 0; b < 3; b++){ //BCD to decimal for first IC
digitalWrite(muxPin[0][b], bitRead(a, b)); //writes the BCD to the decimal for the first IC
for(int c = 0; c < 8; c++){ // for each extra IC pin
for(int d = 0; d < 3; d++){ //BCD to decimal for second IC
digitalWrite(muxPin[1][d], bitRead(c, d)); //writes the BCD to the decimal for the second IC
playerButton[a][c] = digitalRead(A0);
void assignButtons(){
for(int y = 0; y < 4; y++){ //for each direction possibility
directionButton[x][y] = playerButton[x][y];
swordButton[x] = playerButton[x][6];
shieldButton[x] = playerButton[x][5];
//debug-------------------------------------------------------------------------------------------------------------debug
void debug(){
playerLocationCheck();
fpsChecker();
void playerLocationCheck(){
if(playerButton[x][7] == 1){
lcd1.setCursor(4, 1);
lcd1.print(playerPos[x][0]);
lcd1.setCursor(7, 1);
lcd1.print(playerPos[x][1]);
lcd1.setCursor(10, 1);
lcd1.print(playerPos[x][2]);
void fpsChecker(){ //checks the fps note: fpsOn must be on to start/stop it (the button must be held)
if(fpsOn == 0){
fpsTimer = time;
if(playerButton[0][4] == 1){
fpsOn=1;
if(fpsOn == 1){
if(fpsToggle == 0){
fpsToggle = 1;
fps = 0;
fps++;
if((fpsTimer+1000) <= time){
lcd1.setCursor(10,1);
lcd1.print(fps);
fpsOn = 0;
fpsToggle = 0;
//end debug-------------------------------------------------------------------------------------------------------------end debug
//LCDs--------------------------------------------------------LCDs
void lcdRefresher(){
if(lcdRefresh[0] == 1){
lcd1.clear();
lcd1.setCursor(0, 0);
lcd1.print(name[0]);
if(playerHealth[0] > 0){ //if player has lives then display them //player lives
for(int y = 0; y < (playerHealth[0]); y++){ //for each life
lcd1.setCursor((5 + y), 0);
lcd1.write(2);
if(playerLives[0] > 0){ //if player has lives then display them //player lives
for(int y = 0; y < (playerLives[0]); y++){ //for each life
lcd1.setCursor(y, 1);
lcd1.write(1);
if(playerLives[0] == 0){
for(int a = 0; a < 2; a++){
for(int b = 0; b < 16; b++){
lcd1.setCursor(b, a);
lcd1.write(3);
lcdRefresh[0] = 0;
if(lcdRefresh[1] == 1){
lcd2.clear();
lcd2.setCursor(0, 0);
lcd2.print(name[1]);
if(playerHealth[1] > 0){ //if player has lives then display them
for(int y = 0; y < playerHealth[1]; y++){ //for each life
lcd2.setCursor((5 + y), 0);
lcd2.write(2);
if(playerLives[1] > 0){ //if player has lives then display them
for(int y = 0; y < playerLives[1]; y++){ //for each life
lcd2.setCursor(y, 1);
lcd2.write(1);
if(playerLives[1] == 0){
lcd2.setCursor(b, a);
lcd2.write(3);
lcdRefresh[1] = 0;
if(lcdRefresh[2] == 1){
lcd3.clear();
lcd3.setCursor(0, 0);
lcd3.print(name[2]);
if(playerHealth[2] > 0){ //if player has lives then display them
for(int y = 0; y < playerHealth[2]; y++){ //for each life
lcd3.setCursor((5 + y), 0);
lcd3.write(2);
if(playerLives[2] > 0){ //if player has lives then display them
for(int y = 0; y < playerLives[2]; y++){ //for each life
lcd3.setCursor(y, 1);
lcd3.write(1);
if(playerLives[2] == 0){
lcd3.setCursor(b, a);
lcd3.write(3);
lcdRefresh[2] = 0;
if(lcdRefresh[3] == 1){
lcd4.clear();
lcd4.setCursor(0, 0);
lcd4.print(name[3]);
if(playerHealth[3] > 0){ //if player has lives then display them
for(int y = 0; y < playerHealth[3]; y++){ //for each life
lcd4.setCursor((5 + y), 0);
lcd4.write(2);
if(playerLives[3] > 0){ //if player has lives then display them
for(int y = 0; y < playerLives[3]; y++){ //for each life
lcd4.setCursor(y, 1);
lcd4.write(1);
if(playerLives[3] == 0){
lcd4.setCursor(b, a);
lcd4.write(3);
lcdRefresh[3] = 0;
void lcdDisplay(){
lcdRefresher();
//end LCDs--------------------------------------------------------end LCDs
//player actions-----------------------------------------------------------------------------------------------player actions
void playerMovement(){
if(currentPlayers[x] == 1){ //if the player is playing
if(directionButton[x][0] == 1 && time >= (playerTimeSinceMovement[x] + playerMovementDelay[x])){ //if up is pressed //if player hasn't moved since the set amount of time
playerPos[x][1]--;
if(directionAllow[x] == 1){
playerDirection[x] = 0;
playerTimeSinceMovement[x] = time;
if(directionButton[x][1] == 1 && time >= (playerTimeSinceMovement[x] + playerMovementDelay[x])){ //if down is pressed //if player hasn't moved since the set amount of time
playerPos[x][1]++;
playerDirection[x] = 1;
if(directionButton[x][2] == 1 && time >= (playerTimeSinceMovement[x] + playerMovementDelay[x])){ //if left is pressed //if player hasn't moved since the set amount of time
playerPos[x][0]++;
playerDirection[x] = 2;
if(directionButton[x][3] == 1 && time >= (playerTimeSinceMovement[x] + playerMovementDelay[x])){ //if right is pressed //if player hasn't moved since the set amount of time
playerPos[x][0]--;
playerDirection[x] = 3;
for(int y = 0; y < playerCount; y++){ //for each player //makes so players cannot run into each other
if(x != y ){
if(playerPos[x][0] == playerPos[y][0] && playerPos[x][1] == playerPos[y][1] && playerPos[x][2] == playerPos[y][2]){
if(playerLastMoved[x] == 0){
playerPos[x][1]++;
if(playerLastMoved[x] == 1){
playerPos[x][1]--;
if(playerLastMoved[x] == 2){
playerPos[x][0]--;
if(playerLastMoved[x] == 3){
playerPos[x][0]++;
int MAPChooser(int x, int y, int z){ //x position, y position
if(z == 0){
if(bitRead(pgm_read_dword(&MAP0[y]), x) == 1){
return 1;
else{
return 0;
if(z == 1){
if(bitRead(pgm_read_dword(&MAP1[y]), x) == 1){
return 1;
else{
return 0;
if(z == 2){
if(bitRead(pgm_read_dword(&MAP2[y]), x) == 1){
return 1;
else{
return 0;
if(z == 3){
if(bitRead(pgm_read_dword(&MAP3[y]), x) == 1){
return 1;
else{
return 0;
void wallCheck(){ //if player moves into a wall, the play gets set back to original position
for(int x = 0; x < playerCount; x++){ //player
if(playerPos[x][0] <= 31){ //if player is in the first half of the map
if(currentPlayers[x] == 1){ //map[Pmap][[Py*2], Px //if player is in a wall
if(MAPChooser(playerPos[x][0], ((2*playerPos[x][1])+1), (playerPos[x][2])) == 1){
if(playerLastMoved[x] == 0){ //player moved back to where they were
playerPos[x][1]++;
playerPos[x][1]--;
playerPos[x][0]--;
playerPos[x][0]++;
if(playerPos[x][0] > 31){ //if player is in the last half of the map
if(currentPlayers[x] == 1){ //if player is in a wall //map[][y], y is the last half of the map y
if(MAPChooser((playerPos[x][0]-32), (2*(playerPos[x][1])), playerPos[x][2]) == 1){
playerPos[x][1]++;
playerPos[x][1]--;
playerPos[x][0]--;
playerPos[x][0]++;
//end player actions-----------------------------------------------------------------------------------------------end player actions
//number calculating--------------------------------------------------------------------------------------------number calculating
void numberCalculating(){
time = millis(); // a timer needed for timing functions
health();
lives();
swordAttackDamage();
respawnHealth();
void health(){ //updates the health a character has
RAM = playerHealth[x];
playerHealth[x] = (playerStartingHealth[x] + playerHealthGained[x] + playerHealthAdded[x] - playerDamageTaken[x]);
if(RAM != playerHealth[x]){
lcdRefresh[x] = 1;
void lives(){ //updates the lives a character has
RAM = playerLives[x];
playerLives[x] = (playerStartingLives[x] + playerLivesGained[x] - playerDeaths[x]);
if(RAM != playerLives[x]){
lcdRefresh[x] = 1;
void respawnHealth(){
playerSpawnHealth[x] = (playerDefaultSpawnHealth[x] + playerAddedSpawnHealth[x]);
void swordAttackDamage(){
swordDamage[x] = (swordDamageDefault[x] + swordDamageAdded[x]);
//end number calculating--------------------------------------------------------------------------------------------end number calculating
//scripts--------------------------------------------------------------------------------------------scripts
//end scripts--------------------------------------------------------------------------------------------end scripts
//game actions----------------------------------------------------------------------------------------game actions
void death(){ //If a player has no health, that player respawns at spawn location, adds a death, and gets spawnhealth
if(playerHealth[x] <= 0 && playerLives[x] > 1){ //if player has no health but still has lives left
for(int y = 0; y < 3; y++){ //for each player coordinate
playerPos[x][y] = playerSpawnLocation[x][y];
playerDeaths[x]++;
playerHealthAdded[x] = (playerHealthAdded[x] + playerSpawnHealth[x]);
playerHealth[x] = 9;
if(playerHealth[x] <= 0 && playerLives[x] == 1){
playerDeaths[x]++;
playerPos[x][0] = 9; //player spawns at map 0, x,y 0, 0
playerPos[x][1] = 9;
//player attacks------------------------------------------------------------player attacks
void sword(){
if(swordButton[x] == 0 || (time >= swordTimer[x] + swordAttackTime[x])){
startAttack[x] = 0;
if(startAttack[x] == 0){ //if the player is not allowed to attack then sword out timer is reset and the sword is nowhere
swordTimer[x] = time;
swordPosition[x][0] = 0;
swordPosition[x][1] = 0;
swordPosition[x][2] = 0;
if((time >= (swordDelayTimer[x] + swordAttackDelay[x])) && (currentPlayers[x] == 1)){ //( //if attack button is pressed and delay timer is done and player is playing
startAttack[x] = 1;
if(startAttack[x] == 1 && swordButton[x] == 1 && (time < swordTimer[x] + swordAttackTime[x]) && (currentPlayers[x] == 1)){ //if the attack button is pressed, the player is allowed to attack, and the swordAttack time is not expired
swordPosition[x][1] = (playerPos[x][1] - 1); //sword attack directions
swordPosition[x][0] = playerPos[x][0];
swordPosition[x][1] = (playerPos[x][1] + 1);
swordPosition[x][0] = (playerPos[x][0] + 1);
swordPosition[x][1] = playerPos[x][1];
swordPosition[x][0] = (playerPos[x][0] - 1);
swordDelayTimer[x] = time; //if a sword is out, then the delay timer is reset
void swordDamageUpdate(){ //used for pvp
if(PvP == 1){
for(int x = 0; x < playerCount; x++){ //attacked
for(int y = 0; y < playerCount; y++){ //attacker
if(playerPos[x][0] == swordPosition[y][0] && playerPos[x][1] == swordPosition[y][1] && playerPos[x][2] == swordPosition[y][2] && (time >= immunityTime[x] + immunityTimer[x])){
playerDamageTaken[x] = (playerDamageTaken[x] + swordDamage[y]);
playerDamageDealt[y] = (playerDamageDealt[y] + swordDamage[y]);
immunityTimer[x] = time;
//end player attacks------------------------------------------------------------enplayer attacks
//matrix functions--------------------------------------------------------------------------------------matrix functions
void swordDisplayerScrolling(int x, int y, int d){ //x, y, 0 for red 1 for green //displays the swords
for(int z = 0; z < playerCount; z++){ //for each player
if(swordPosition[z][0] == (x) && swordPosition[z][1] == (y) && (swordPosition[z][0] != 0 || swordPosition[z][1] != 0 || swordPosition[z][2] != 0)){
bitClear(cathodeData[d][(y - playerPos[0][1] + middleY)], (-x + playerPos[0][0] + middleX));
void shieldDisplayerScrolling(int x, int y, int d){ //x, y, 0 for red 1 for green //displays the shields
if(shieldPosition[z][0] == (x) && shieldPosition[z][1] == (y) && (shieldPosition[z][0] != 0 || shieldPosition[z][1] != 0 || shieldPosition[z][2] != 1)){
void playerDisplayerScrolling(int x, int y, int d){ //displays the players
if(playerPos[z][0] == (x) && playerPos[z][1] == (y) && playerLives[z] > 0){
void MAPDisplayerScrolling(int x, int y, int d){
if(x <= 31){
if(MAPChooser(x, ((2*y)+1), playerPos[0][2]) == 1){
bitClear(cathodeData[d][(y - playerPos[0][1] + 3)], (-x + playerPos[0][0] + 3));
if(x > 31){
if(MAPChooser((x-32), (2*y), playerPos[0][2]) == 1){
bitClear(cathodeData[d][((y - playerPos[0][1] + 3))], (-x + playerPos[0][0] + 3));
void MAPGreenDisplayerScrolling(int x, int y, int d){
if(x <= 31){
if(MAPGreenDisplayChooser(x, (2*y)+1, playerPos[0][2]) == 1){
if(x > 31){
if(MAPGreenDisplayChooser((x-32), (2*y), playerPos[0][2]) == 1){
int MAPGreenDisplayChooser(int x, int y, int z){
if(z == 0){
if(bitRead(pgm_read_dword(&MAPGreen0[y]), x) == wallData){
return 1;
else{
return 0;
if(z == 1){
if(bitRead(pgm_read_dword(&MAPGreen1[y]), x) == wallData){
return 1;
else{
return 0;
if(z == 2){
if(bitRead(pgm_read_dword(&MAPGreen2[y]), x) == wallData){
return 1;
else{
return 0;
if(z == 3){
if(bitRead(pgm_read_dword(&MAPGreen3[y]), x) == wallData){
return 1;
else{
return 0;
void dataDisplayScrolling(){ // determines what is displayed on the LEDs
for(int j = 0; j < 8; j++){ //clear displays
cathodeData[0][j] = 0b11111111;
cathodeData[1][j] = 0b11111111;
for(int y = (playerPos[0][1] - 3); y < (playerPos[0][1] + 4 ); y++){ //each line of data //player pos y
for(int x = (playerPos[0][0] - 3); x < (playerPos[0][0] + 4 ); x++){ //each bit of data //player pos x
MAPDisplayerScrolling(x, y, 0);
playerDisplayerScrolling(x, y, 1);
swordDisplayerScrolling(x, y, 0);
MAPGreenDisplayerScrolling(x, y, 1);
shieldDisplayerScrolling(x, y, 0);
shieldDisplayerScrolling(x, y, 1);
//8x8 LEDs, 2 colors
void matrixDisplay8x8Bi(){ //writes cathode1String[9] to display, code taken from ShiftOut on arduino website http://arduino.cc/en/Tutorial/ShiftOut
//changes cathode 0s to 1s and 1s to 0s, also mirrors the image
for (int j = 0; j < 8; j++) {
//load the light sequence you want from array
tempAnodeData[0] = anodeString[j];
tempCathodeData[0] = cathodeData[0][j];
tempCathodeData[1] = cathodeData[1][j];
//ground latchPin595 and hold low for as long as you are transmitting
digitalWrite(latchPin595, 0);
//move 'em out
shiftOut(dataPin595, clockPin595, tempAnodeData[0]);
shiftOut(dataPin595, clockPin595, tempCathodeData[0]);
shiftOut(dataPin595, clockPin595, tempCathodeData[1]);
//return the latch pin high to signal chip that it
//no longer needs to listen for information
digitalWrite(latchPin595, 1);
//@@@@@ do not change @@@@@
void shiftOut(int myDataPin, int myClockPin, byte myDataOut) { //'595 matrix setup code, code taken from ShiftOut on arduino website http://arduino.cc/en/Tutorial/ShiftOut
int i=0; // This shifts 8 bits out MSB first, on the rising edge of the clock, clock idles low
int pinState; //internal function setup
pinMode(myClockPin, OUTPUT);
pinMode(myDataPin, OUTPUT);
digitalWrite(myDataPin, 0); //clear everything out just in case to prepare shift register for bit shifting
digitalWrite(myClockPin, 0);
for (i=7; i>=0; i--) { //for each bit in the byte myDataOut� NOTICE THAT WE ARE COUNTING DOWN in our for loop This means that %00000001 or "1" will go through such that it will be pin Q0 that lights.
if ( myDataOut & (1<<i) ) { //if the value passed to myDataOut and a bitmask result true then... so if we are at i=6 and our value is %11010100 it would the code compares it to %01000000 and proceeds to set pinState to 1.
pinState= 1;
else {
pinState= 0;
digitalWrite(myDataPin, pinState); //Sets the pin to HIGH or LOW depending on pinState
digitalWrite(myClockPin, 1); //register shifts bits on upstroke of clock pin
digitalWrite(myDataPin, 0); //zero the data pin after shift to prevent bleed through
digitalWrite(myClockPin, 0); //stop shifting
//end matrix functions--------------------------------------------------------------------------------------end matrix functions
It now compiles down to 14kb with 4 maps. I did some math, and believe that the maximum amount of 64x48 pixel maps that can be programmed is 25, then the Arduino's data will be full. I definitively don't need serial eeprom right now, but I might later if I make the game really big.How much does it compile to now? do you think you might need external memory - maybe a serial eeprom?
I would use a serial eeprom (or perhaps SPI memory) to hold onto all of your constants data (like game screens and LCD text etc...)Saimaster13 wrote:I just typed up the intro. It now compiles down to 20kb. So what was that about extra memory and serial eeprom?
The main problem here is the amount of rows being activated at once is not enough. Let's just say that you are sending out 1 bit every 1uS. If you have a bi-color 8x8 matrix then it will take 8*8*2 = 128uS to send out your red and green colors to the display. You then need to allow a delay of perhaps 1mS for each time you activate a row of LED's - so you have and extra 8mS delay for an 8 column display. If you then go worst case scenario and have a 64x16 pixel (bi-color) display then you are looking at needing 16 of these 8x8 matrix displays. so:Saimaster13 wrote:I just realized: I do not know how to adequately power LED matrices.
What I need for right now is to know how to power two or four 2x2 matrix of 8x8 matrices.
Where each x is a 8x8 matrix, what I am making will look sort of like this:
xx xx xx xx
xx xx xx xx
Either all of them will be driven together, or the first two 2x2 matrix of matrices will be driven together, and the other matrices will be driven separately.
So it is effectively going to be either a 2 row and 4 column matrix of matrices, or a 2 row 8 column matrix of matrices, totaling to either a 16x32 or 16x64 pixel matrix.
My hardware:
Arduino
74HC595 shift registers
eight 8x8 matrices (I will eventually get 8 more to double the matrix count.I have yet to decide whether they will be powered by the same Arduino or not.)
Also, it should be noted that I have 74HC373 and '374s, but do not know how to use either. Should I use one of these instead of the '595s?
What I have on hand for current (sinking or sourcing, I'm not sure which.):
resistors
10x ULN2803APG transistor arrays
2n2222a Transistors
I am willing to get whatever I need to properly power the matrices. However, I would prefer, if it would work just as well, to use the transistor arrays I already have to power the matrices.
Links:
Link to download ULN datasheet
link to matrix datasheet
