Tetris on a PIC
Re: Tetris on a PIC
Is the fire out yet?
Re: Tetris on a PIC
Its still burning. If you go online and search for mustang complex fire you will see just how big this fire is.
I'm not bothered by the smoke itself but whats in the smoke. The fuel (trees etc) are emitting lots of allergens in the air. I can't consecrate on my project much. Took to many allergy pills (followed directions) but the jellcap didn't like me.
Going to remove the two ULN2803 and attempt to blink an LED on each output pin. Hopefully I can find out why some do not go high. Weak pullups or maybe a short on the board?
Re: Tetris on a PIC
Did you try each output pin with a logic probe?
Re: Tetris on a PIC
I got all the pins to work after I put the utils.bas and setalldigital.
Now trying to get the red leds to mix it up with the green leds.
Having the first 4 rows on porta and the 3 rows on portb, need to combine the two. Thinking scan the rows 1-4 (portA in a for next loop then scan portB in a for next loop.
Another issue is manipulating the bits. Keep getting an over-range error?
will hack at it making progress. Found if I step away and come back to it later I can make a little progress.
will post my revised code after I clean it up.
Re: Tetris on a PIC
I will go check out your other post.
Re: Tetris on a PIC
Users browsing this forum: No registered users and 12 guests
