Wireless Project Revisited using Basic Language
Post by bitfogav » Thu Mar 29, 2012 8:45 am
Hey guys do you remember these? Im sure Brad does..
These are two devices one Transmitter (TM1000-1) and one Receiver (RM1SGS) with a range of 1000m and they are very cheap! Can still be brought from Ebay. Awhile ago I put an Assembly language wireless project together which can be found here Bitfogavs Wireless Project.
Well I decided to revisit this project but make it from a Basic language using Proton Basic, Proton Basic uses some of the more baseline Microchips like the 12F, 16F PICs. maybe we can convert Stacy to the Basic language now, hey Brad?! hehe!.
For this im going to use the 12F675 8pin microchip, and the RSIn and RSOut commands from the Proton Basic language.
heres an example of the Transmitter code I have so far:
Device = 12F675
    Xtal = 4
            ' Set ext 4mhz crystal
	Config FOSC_XT, CPD_OFF, CP_OFF, BODEN_OFF, MCLRE_OFF, PWRTE_ON, WDT_OFF
    All_Digital = TRUE   ' set CMCON = 7
    INTCON = 0           ' Disable Interrupts
'-------[DECLARE SERIAL DATA]--------------------------------------------
		Declare Rsout_Pin GPIO.2             ' Assigns the Port and Pin that will be used to Output serial data.
        Declare Rsout_Mode 0                 ' Sets the serial mode.
        Declare Serial_Baud 1200             ' Baud Rate to receive and transmit data.
        Declare Rsout_Pace 10                ' Delay between characters transmitted by the Rsout command.
'-------[ASSIGN PINS]----------------------------------------------------
        Symbol Led  = GPIO.0
        Symbol btn1 = GPIO.1
'-------[ASSIGN GENERAL VARIABLES]---------------------------------------
        Dim byteOut As Byte
        Dim looop As Byte
'-------[INITIALISE THE PICMICRO]----------------------------------------
        TRISIO = %111010				' Set pin functions (Input/Output)
        Output Led
        Low Led
        Input  btn1
        ' Init variables
        byteOut = 1
        DelayMS 100						' Wait for the PICmicro to stabilise
'-------[MAIN PROGRAM LOOP STARTS HERE]----------------------------------
While 1 = 1	    ' Create an infinite loop
          ' check if button pressed
          If btn1 = 0 Then
            High Led
            RSOut Bin 43690
              For looop = 0 To 2
                RSOut "Z" , Dec byteOut, 13
              Next
            DelayMS 500
            Low Led
Wend    ' Loop prog
Re: Wireless Project Revisited using Basic Language
Post by brad » Sun Apr 01, 2012 1:47 pm
I remember this!
I actually didn't ever get my version to work. However now that I am using Basic - it may just be a whole heap easier. Great to see you getting back into the wireless projects. Do you have a plan for what you might do with it?
Post by bitfogav » Sun Apr 01, 2012 6:26 pm
Well I do have an idea, A fews years ago I made a simple 2Led flasher for a friends outside alarm box on his house, which used a potentiometer connected to an analogue pin of a microcontroller to control the delay between flashes, I was thinking of actually making up something for him so he could adjust the time delay between flashes with a wireless remote.
A very simple design but a good deterrent against burglars!.
heres a picture of the veroboard I made up for him a few years ago:
schematic:
Post by brad » Mon Apr 09, 2012 6:35 pm
That's a great idea. Would the receiver connect directly to the 8pin PIC you already have there?
Post by bitfogav » Mon Apr 09, 2012 7:31 pm
Yes Brad, there is 3 spare pins on the PIC on the original board so I may use one of them for the Receiver. :)
Post by bitfogav » Wed Apr 11, 2012 3:25 am
Heres my two test codes which work for the RF modules.
Tx Code:
Device = 12F675
    Xtal = 4
        Reminders = Off
        Config XT_OSC, WDT_OFF, PWRTE_ON, BODEN_OFF, CPD_OFF, CP_OFF, MCLRE_OFF
        Reminders = On
    Set_OSCCAL           ' Calibrate the on-chip oscillator
        Symbol Led  = GPIO.0
        Dim byteOut As Byte
        Dim looop As Byte
        Output Led
        Low Led
        Input  btn1
        ' Init variables
        byteOut = 1
While 1 = 1
          If btn1 = 0 Then  ' test button
            High Led    ' turn on led to show that button was pressed
            DelayMS 50  ' button debounce
            ' send out some data so stabilize the RF receiver
            RSOut Bin 43690
              ' then send header Z, then your data byte
              ' send data serveral times to make sure Receiver receives data
              For looop = 0 To 2
              Next
            DelayMS 500
         Low Led  ' turn off led
Wend
RX Code:
Device = 12F675
    Xtal = 4
        Reminders = Off
        Reminders = On
        Declare Rsin_Pin GPIO.2             ' Assigns the Port and Pin that will be used to input serial data.
        Declare Rsin_Mode 0                 ' Sets the serial mode.
        Declare Rsin_Timeout 5000           ' Time, in ms, that Rsin will wait for a start bit to occur.
        Symbol Led  = GPIO.0
        Dim byteIn As Byte
        TRISIO = %111100                ' Set pin functions (Input/Output)
        Output Led
        High Led
        ' Init variables
While 1 = 1
      ' Wait for the value "Z" to be received
        RSIn {Time_Out}, Wait("Z"), Dec byteIn
           ' Put your code here when correct data received
            Low Led     ' turn off led to show data received
            DelayMS 2000
        Time_Out:
         ' This is where we go if nothing is received in 5 Secs
          High Led
Wend
