Schematic
- 1kiko1
- Joined: Wed Jun 29, 2011 11:16 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Schematic
Hey brad I tried to make the reaction game but I don't know why it didn't work I used a 9 volt battery and everything else you used is the schematic good or do I have to change something
Re: Schematic
The schematic and source code should all be just fine - I just double checked it then.
You said that you used a 9 volt battery - I am hoping that you used a 5volt regulator with it because the pic microcontroller can't handle 9volts. I think it can only go up to 5.5volts.
- 1kiko1
Re: Schematic
Ok thank you very much
