Alright I now it works fine. I decreased the delay too much 1st, then gradually increased it until it worked fine.There may be still more FINE TUNING to be done but as of now its working.
Now I've tried your software which you provided with the "One Chip POV Project", but that software (POVConverterBigGraphics & POVConverterLong) just wont get installed. Can you tell me of some other software which I can use to convert images into HEX code (Taking into consideration the way the Excel Sheet works, i.e. each cell's hex value is converted into binary, the binary values are segregated column-wise and then we get get HEX code for each column and then we have the final HEX code). Is there a software which works like that?
I couldn't find a software that follows the Excel Sheet Pattern to generate the HEX code so I got a software that generates a binary code for 85x24 matrix and then I'm manually
Also i just realised that once I get the microcontroller functioning with the right code I wont need to program it again, I'll only have to change the hex code in the EEPROM (i.e. data to be displayed), so I can display any image at any time I want. Do you know of an in-circuit programmer that can program the ATmega16L AS WELL AS the W27C512 EEPROM??
Thanx and Regards,
Robert
