Diptrace 3D Component Library
Post here to discuss designing your own PCB's
Locked [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Post by bitfogav » Tue Jun 10, 2014 1:42 am
Hi all, here is where I am going to be sharing my Diptrace 3D component Library (WRL 2.0 format). I'm sure I'll be updating it quite frequently and adding new components.. (keep checking by for updates)..
To find out how to import the files into Diptrace check out my 3D component tutorial here.
Arduino Stackable Headers (v1.0) - Contains 6,8,10pin
Arduino Stackable Headers.jpg (14.48 KiB) Viewed 20780 times
Arduino Stackable headers v1_0.zip
(25.4 KiB) Downloaded 1627 times
Bi-Color Led Matrix 8x8 (v1.0) - 24pin Led Matrix Display
Matrix_8x8 _led_3mm v1_0.zip
(944.21 KiB) Downloaded 1639 times
Female Headers (v1.0) - Contains Female Headers (Straight/Angled) from 2 to 20 pin configurations.
Female Headers.jpg (16.11 KiB) Viewed 20780 times
Female Headers (v1_0).zip
(363.34 KiB) Downloaded 1546 times
DC Power Jack 2.1mm (v1.0)
DC_PowerJack_2_1mm_v1_0.zip
(71.14 KiB) Downloaded 1534 times
Pin Headers (v1.0) - Contains single/double/straight/angled pin headers (various lengths)
Pin Headers.jpg (29 KiB) Viewed 20776 times
Pin Headers v1_0.zip
(320.43 KiB) Downloaded 1537 times
Leds SMD (v1.1) - Contains 0402,0603,0805,1206
leds smd v1.1.jpg (40.62 KiB) Viewed 20764 times
Led SMD_v1.1.zip
(790.71 KiB) Downloaded 1670 times
USB Mini B (v1.0)
USB_mini_B_v1_0.zip
(157.08 KiB) Downloaded 1531 times
Re: Diptrace 3D Component Library
Post by brad » Tue Jun 10, 2014 11:17 pm
Thanks Gav!
Those 0402 LED's I can use straight away with my current project :)
Post by brad » Wed Jun 11, 2014 10:13 pm
And here they are, thanks again!
Locked
