Not working properly
- Joined: Sat May 03, 2014 9:13 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Hi! I stumbled upon your project on the instructables website. I must say, it is really amazing.
So i followed all the instructions and made my own super pong table. But when i started it, it didn't really do much.
It showed the title Super Pong Table as a mirror image. Also it was a little bit moved towards a corner.
In few initial startups it showed choose your player screen. But now it doesn't even show that.
The main problem is that the two buttons for mode and player selection do not work. They seem to show no effect on the game.
But in-spite of all this sometimes the game starts randomly.
I don't know where i have made a mistake.
I have checked all the circuit for any loose connection or any mistake as per the schematic you have given.
Info:
I have made 30x30 matrix instead of 32x32 and thereby skipped the 4 connections corresponding to the border led's in the schematic.
I have used the super pong knockout code in the micro controller.
Info:
Re: Not working properly
Could you please upload a photo of your super pong table circuit board so I can see what version you have?
This problem has come up before I just remembered!
Try this updated super pong table knockout code and see if it works for you
download/file.php?id=694
also, if you have a bit of time, you can read through the previous posts on a similar problem to yours:
viewtopic.php?f=27&t=725&start=15
Hey brad, sorry to replying late. This is the project i made, i've attached the pics. I didn't have the pcb so i have wired all the connections. The mode button is not working, display is mirrored and one line is behaving like a permanent wall. Moreover upon turning on the circuit, random things are happening, i.e. like shows the "super pong table" or player select or the game, but all randomly. I have done exactly as given on instructables, please tell me if there is something there.
please see the attachments.
link to video, when powered on, mode buttons not working here
please help, this project is already selected for display in the university.
- mirrored display
- IMG_20140516_120343.jpg (1022.37 KiB) Viewed 29098 times
i updated the code now that u sent
but now it is not working only only 9 squares emerge of the led's of 4x4 and nothing else happens
Hmm, firstly by looking at the video, you will need to rewire your less so that it is not back to front. You will just need to swap the left most connection with the right most connection, then the second left most connection with the second right most etc. Keep doing this until all 30 have been re-wired.
As for the screen having a solid line and also what appears to be some ghosting (for example, down the bottom of the screen). This would be caused by either faulty wiring / soldering (I.E. you may have shorting a cathode to an anode somewhere) or you may have a faulty LED or maybe a few. I have had this sort of ghosting problem before when making my own matrix displays and it is always down to one of those two problems.
Now as for the screen displaying random things (sometimes the super ping title, sometimes the game etc. This is because the buttons are not connected to where they should be. Unfortunately I messed up the code on my latest instructables upload. Did you have a chance to have a read through the link I posted above? that link tells you where the buttons actually need to connect to.
do i need to put the pull down resistors
i know abt wiring mess its just temporary as it will put under the lid i will but on the box to cover it
nd wat abt the code as this video was before i updated the new code you referred in the above posts as know i have updated it
the led dont display much jst some randomly lit lines
i read ur link bt still it's not clear to me where the buttons to be attached
it only tells that u corrected the code nt the position of buttons
and the second jst tells to ground the push buttons which i have done only as it was in schematics
Make sure you are using this version of the game, it has a fix for the buttons.
Then make sure that your circuit diagram is exactly like the circuit diagram that you would have downloaded from instructables. Let me know how this goes for you.-
ok i will try the above code
and jst to make sure of instructable schematics(below) wouldn't it result in logic 0 when i press the button
so jst one question do while making connections to PIN 6 and PIN 7 do irequire to produce logic 0 when i press the button and logic 1 when button is not pressed because if i m not wrong the schematics says so
pls reply asap
pls reply asap
- ni.PNG (7.81 KiB) Viewed 29056 times
Yes that is correct. When the button is not pressed you will get a logic 1.so jst one question do while making connections to PIN 6 and PIN 7 do irequire to produce logic 0 when i press the button and logic 1 when button is not pressed because if i m not wrong the schematics says so
When the button is pressed you will get a logic 0.
That is exactly what the code is looking for
ok i l let u know as soon as i try the code
Ho did you get on with this rhshanks? Did you get it working?
