Implementing DS18B20.bas into code w/ ADC
Post by MrDEB » Tue Aug 07, 2012 3:07 pm
I got the LCD working then the code for the ADC section all working together but when I attempt to insert the DS18B20.bas temperature code into the works all I get are syntax errors.
I don't know proper procedure to insert a subroutine as I have indicated.
Been looking at sample codes trying to decipher why certain sections were inserted where they did. Moved the code around but to no avail.
WHY??
*  Author  : [select VIEW...EDITOR OPTIONS]                                 *
*  Notice  : Copyright (c) 2011 [select VIEW...EDITOR OPTIONS]              *
*  Date    : 10/6/2011                                                      *
*  Notes   :compute voltage to temperature. Start with sensor at 50ohms.
*          : 180-200 ohms melts solder                                                               *
Device = 18F4520
Clock = 20
// some LCD options...
#option LCD_DATA = PORTD.4
#option LCD_RS = PORTD.2
#option LCD_EN = PORTD.3
// uses LCD and AD libraries...
Include "LCD.bas"
Include "ADC.bas"
Include "convert.bas"
Include "DS18B20.bas"
Dim ADVal As Word
Dim LED_g As PORTB.0
Dim LED_r As PORTB.1
Dim Vref As Word
Dim  Vsensor As Word
Dim deg_s As Word         //DESIRED TEMP
Dim drf As Word           //DEFROST TIME
Dim TempA As Word
Dim TempB As ShortInt
// Read the AD ports and scale
Function REF_V() As Word
 result = (ADC.Read(1) +1) /100  //1024 is divide by  tip sensor
End Function
Function sensor() As Word
 result = (ADC.Read(0) + 1)/100  // 100  //1024 is divide by  temp ref desired
End Function
//xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
// I need this routine to read the DS18B20 but keep getting syntax errors
// the LCD, ADC sections all worked before putting the DS18B20 into the code
//syntax says a sub routine or  or function is expected
Public Sub sens_tep()
        If DS18B20.Find Then
        While True
            Convert
            GetTemp(TempA, TempB)
   // LCD.WriteAt(1,1,"BX temp = "DecToStr(TempA))
//xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
// Start Of Program...
Input(PORTA.0)                  // DESIRED TEMP
Input(PORTA.1)                  // DEFROST TIMER
Low (LED_g)                     //set lEDs OFF
Low (LED_r)
ADCON1 = %10000000              //set up ADC regesters
ADCON0.7 = 1
ADCON0.6 = 1
DelayMS (150)
LCD.Cls
 While true
        // call function REF_V() and assign the result to word variable 'Vref'
        Vref = REF_V()
        Vsensor = sensor()
Select Vref
       Case <1 deg_s = 32
       Case <2 deg_s = 33
       Case <3 deg_s = 34
       Case <4 deg_s = 35
       Case <5 deg_s = 36
       Case <6 deg_s = 37
       Case <7 deg_s = 38
       Case <8 deg_s = 39
       Case <9 deg_s = 40
End Select
Select Vsensor
       Case <1 drf = 10
       Case <2 drf = 12
       Case <3 drf = 14
       Case <4 drf = 16
       Case <5 drf = 17
       Case <6 drf = 19
       Case <7 drf = 21
       Case <8 drf = 23
       Case <9 drf = 25
End Select
    // main program loop...
        LCD.MoveCursor (1,1)
        LCD.Write("Desired temp= ", DecToStr(deg_s))
        DelayMS(250)
   // call function sensor() and assign the result to word variable 'drf'
        LCD.MoveCursor (2,1)
        LCD.Write("DEFROST = ", DecToStr(drf),"    ")
        DelayMS(250)
   // compare Vsensor and Vref values
        If Vsensor < Vref Then      // not hot enough
            LED_r=1
            LED_g=0
        Else                        // Vsensor must be >= Vref, so desired temperature
            LED_g=1
            LED_r=0
        End If
Re: Implementing DS18B20.bas into code w/ ADC
Post by bitfogav » Wed Aug 08, 2012 3:01 am
Ive not used the DS18B20.bas module for Swordfish yet but what if you change the subroutine to something like this?
    dim myTemp as word
            DS18B20.Convert
            mytemp = DS18B20.GetTemp()
            LCD.WriteAt(1,1,"BX temp = ",DecToStr(myTemp))
Note that the syntax works now when compiled with Swordfish but ive not tested it with a DS18B20? :roll:
Post by MrDEB » Wed Aug 08, 2012 3:05 am
I will give that a try. Everytime I change something or location withing the code) I get different syntax.
Will keep you informed.
Been looking at the Swordfish Bible for answers but ?
Post by bitfogav » Wed Aug 08, 2012 3:10 am
But in your code you not actually calling "sens_tep()" subroutine anywhere?? :?
Post by bitfogav » Wed Aug 08, 2012 5:05 am
The other thing I just noticed aswell with your code is that your Variables for TempA and TempB types aren't correctly configured.
you have
Dim TempA As Word
they should be the other way around like
Dim TempA As ShortInt
Dim TempB As word
So if you change your original code back to something like this then thats closer to what you had before, so all you have to do is call the subroutine "sens_tep()" in your main programme code, the other thing to note is that I dont think you need the While loop in your subroutine because then your programme will be stuck so to speak within your subroutine, so in other words your LCD will be constantly updating with your Temp data from the DS18B20. Ive also changed your LCD write command so it should output both TempA and TempB. :)
        While True             ' <- I would remove this while loop
            DS18B20.Convert
            DS18B20.GetTemp(TempA, TempB)
            LCD.WriteAt(1,1,DecToStr(TempA),".",DecToStr(TempB,4), $BA, "C")
       Wend                    ' <- I would remove this aswell
Post by MrDEB » Wed Aug 08, 2012 5:52 am
I may have gotten the TempA and TempB backwards? I tiddied up the code and may have screwed up the TempA and TempB
Will look at that section as well as the other suggestions.
I only want to display the Temperature not the RomID.
Post by MrDEB » Wed Aug 08, 2012 5:54 am
I want to keep updating the temperature.
This is a beer cooler thermostat. Got to keep that beer cold.
Post by bitfogav » Wed Aug 08, 2012 6:44 am
Well this is what ive quickly put together to read a DS18B20 and display the temp on a LCD, please note mrDeb ive changed the PIC and LCD pins to suit my demo board, it also incorporates your subrouting :)
Device = 18F452
Clock = 20
// LCD optional settings
#option LCD_DATA = PORTC.4
#option LCD_RS = PORTE.0
#option LCD_EN = PORTE.1
// include modules...
Include "LCD.bas"
Dim TempB As Word
Public Sub sens_temp()
         DS18B20.Convert
         LCD.WriteAt(1,1,DecToStr(TempA),".",DecToStr(TempB,1), "'C    ")
    Else
        LCD.WriteAt(1,1,"no device")
// setup PIC...
ADCON1 = $07
TRISA = %111111
TRISB = %11111111
TRISC = %00000000
TRISD = %00000000
TRISE = %000
SetPin(PORTC.0)    ' data pin to DS18B20
DelayMS (150)
LCD.Cls
While true
    sens_temp()      ' get temp
    ' REST OF YOUR CODE HERE
    DelayMS(1000)
To show the LCD output:
Post by MrDEB » Wed Aug 08, 2012 9:04 pm
Thanks Bifogav
I saw this on Digital-DIY and going to give it a go.
No problem changing setpin.
Curious how to know where to put say the setpin statement?
I saw David Barker use it in an OPTION statement.
Post by bitfogav » Wed Aug 08, 2012 9:15 pm
Yes you can setup the setpin in several ways, including using #option statement. all the info is in the help topics of Swordfish IDE mrDeb :)
Post by MrDEB » Fri Aug 10, 2012 12:50 am
Making LOTS of progress this morning.
Depending where I put the sens_tep call sub I get the aDC readings then the temp but then it just stays on Temperature reading.
If I put it after the ADC display statements then it displays the ADC display then gets stuck on reading the temp display.
Going to look at swordfish for a RETURN or?
Thanks for all your help Brad
*  Notice  : Copyright (c) 2012 [select VIEW...EDITOR OPTIONS]              *
*  Date    : 8/8/2012                                                       *
*  Notes   :        *
    Device = 18F4520
    Clock = 20
    Include "LCD.bas"
    Include "ADC.bas"
    Dim LED_g As PORTc.4
    Dim LED_r As PORTc.5
    Dim Vref As Word
    Dim Vsensor As Word
    Dim Desired_T As Word          //DESIRED TEMP
    //Dim D_Frost As Word          //DEFROST TIME
   // Dim drf As Word
//  Dim myTemp As Word          //DEFROST TIME
    Function Dsired_T() As Word
     result = (ADC.Read(1) +1) /100  //Read DESIRED TEMP Adjustment
    End Function
     result = (ADC.Read(0) + 1)/100  // 100  //Read DEFROST TIMER ADJUSTMENT
    End Function
    Dim drf As Word
    // I need this routine to read the DS18B20 buit keep getting syntax errors
   Sub sens_tep()
        Dim myTemp As Word
        Dim TempB As Word
            While true
                DS18B20.Convert
                DS18B20.GetTemp(TempA,TempB)
                LCD.Cls
                LCD.WriteAt(1,1,"bx temp",DecToStr(TempA),".",DecToStr(TempB,1), "'C    ")
                myTemp = (TempB)
                DelayMS(3000)
         DS18B20.Convert
    Else
    Low (LED_r)
    ADCON0.7 = 1
    ADCON0.6 = 1
    ADCON1 = $07
    TRISA = %111111
    TRISB = %11111111
    TRISC = %00000000
    TRISD = %00000000
    TRISE = %000
 SetPin(PORTB.3)                  // sensor pin
    DelayMS (150)
    LCD.Cls
     While true
            Vref =Dsired_T ()           //DESIRED TEMP
            Vsensor = sensor()       //DEFROST TIMER
    Select Vref
           Case <1 deg_s = 32
           Case <2 deg_s = 33
           Case <3 deg_s = 34
           Case <4 deg_s = 35
           Case <5 deg_s = 36
           Case <6 deg_s = 37
           Case <7 deg_s = 38
           Case <8 deg_s = 39
           Case <9 deg_s = 40
    End Select
    Select Vsensor
           Case <1 drf = 10
           Case <2 drf = 12
           Case <3 drf = 14
           Case <4 drf = 16
           Case <5 drf = 17
           Case <6 drf = 19
           Case <7 drf = 21
           Case <8 drf = 23
           Case <9 drf = 25
    End Select
          //  sens_tep()                    //put here and only temp display
          //  DelayMS(3000)
            LCD.WriteAt(1,1,"Desired temp= ", DecToStr(deg_s))  // Display DESIRED TEMP
         //   DelayMS(000)
            LCD.Write("DEFROST = ", DecToStr(drf),"    ")   //Display DEFROST TIMER
            DelayMS(3000)
            LCD.Cls
          //  LCD.MoveCursor (2,1)
          //  LCD.Write("bx temp = ", DecToStr(myTemp),"    ")   //Display DEFROST TIMER
           sens_tep()                     // put here and ADC displays but then only temp displays
           // need to get outta the sub back to the main code
Post by MrDEB » Fri Aug 10, 2012 1:18 am
Found that putting EXIT in the right place works!!
noinline   Sub sens_tep()
        Dim myTemp As Word
        Dim TempB As Word
            While true
                DS18B20.Convert
                LCD.Cls
                myTemp = (TempB)
                DelayMS(3000)
                exit    //[b][b] this works[/b][/b]
Post by MrDEB » Fri Aug 10, 2012 2:07 am
SLIGHT issue with temp conversion Bitfogav
according to your picture of 26C your temperature is a chilling 46.8F
C * 9 / 5
at least thats what I think the cal is??
maybe wrong its got to be incorrect??
mine says 23C but its got to be around 70+F
Post by MrDEB » Fri Aug 10, 2012 2:11 am
MY BAD
found a different calculation
C * 1.8 +32
Post by bitfogav » Fri Aug 10, 2012 2:21 am
Yeah your calculation was wrong, you could also use 26C Multiply by 9, then divide by 5, then add 32
26 * 9 / 5 + 32
