Programming Pics using C
odessa
Post by odessa » Fri Jun 17, 2011 11:26 pm
Hi People :D
Sorry I've not been around much, been on holiday, and very very busy with a new project.
I posted a while back I was given a Picdem.net2 board to play with.
Well.............. to cut a long story short, the progress I made getting a site working on it and the site interacting with physical hardware
has meant Ive been given a contract to help develop a project on it :D :D :D
BUT ..... this meant learning C, specifically C18 which the Microchip TCPIP stack is written in :(
However :) ... I'm getting on really well with it.
Seeing as its not quite as user friendly as Swordfish although similar in structure it has forced me to face my biggest hurdles/fear of:-
A: Correctly understanding and working out clock cycles
B: Using and configuring Timers
C: Using and understanding Interupts
All of which after a good week of thrashing have now clicked into place :) ... I'm over the moon
This is a sample code I wrote myself in C18 to get a timer to run a simple clock that could be displayed on an LCD
The way of counting I used is from Graham over at Digital DIY, scaling the ms by 1000 then deducting 10000 and leaving a carry over.
I could have done this a different way, but I thinks its so well done I had to use it here :)
You can see how much Swordfish is like C
I just wish using things like LCD's were as easy in C though. I have yet to get the inlcuded xlcd modules in C18 to work with a single LCD
set up ... This is probably down to my Noobness but I've found a lot of people with the same LCD problems.
What makes the above funny is that I can get my GLCD running perfectly :lol:
Anyway heres my working code... As usual any tips comments appreciated :)
// Timer0 Test Routine //
#include <p18f4520.h>
#include <timers.h>
#pragma config WDT = OFF, OSC = HS
// Declare Variables Used
#define LEDTRIS TRISBbits.TRISB3	// Led Tris
#define LEDIO LATBbits.LATB3		// Led IO Pin
int ms;
int sec;
int min;
int hr;
int tick;
void introut (void)
		INTCONbits.TMR0IF = 0;   // Clear interupt flag
		ms = ms + 1638;			// Inc ms by 1.638 scale by 1000 for ease of use
		if (ms >= 10000) ms = ms - 10000, tick = tick +1; // deduct 10000 from ms Var and leave carry over
void inittimer (void)
//Setup Timer0
	T0CONbits.T0PS0 =0;
	T0CONbits.T0PS1=0;		// Prescaler set to 1:32
	T0CONbits.T0PS2=1;
	T0CONbits.PSA=0;       // Timer Clock Source is from Prescaler ( 0 = prescaler enabled )
	T0CONbits.T0CS=0;      // Prescaler gets clock from FCPU ( 20mhz / 4 = 5mhz )
	T0CONbits.T08BIT=1;    // 8 BIT MODE
	INTCONbits.TMR0IE=1;   // Enable TIMER0 Interrupt
	INTCONbits.PEIE=1;     // Enable Peripheral Interrupt
	INTCONbits.GIE=1;      // Enable global interrupt
void main (void)
//Declare Variable values
ms = 0;
sec = 0;
min = 0;
hr = 0;
tick = 0;
// Initialiase main program
inittimer();
LEDTRIS = 0;
LEDIO = 0;
TIMER_INT_ON;
T0CONbits.TMR0ON=1;						// Start Timer
ADCON1 = 7;				// Set All Digital
while(1)
   	if (INTCONbits.TMR0IF == 1)			// If timer 0 hits 255 then goto interupt
		introut();
	 if (tick >=100)
		sec = sec + 1, tick = 0, LEDIO ^=1;		// 100 tick = 10ms * 100 = 1 second
	 if (sec >= 60)
		min = min +1, sec = 0;
     if (min >= 60)
		hr = hr +1, min = 0;
	 if (hr >=24)
		 hr = 0;
Edited to fix the LED toggle being in the wrong place
(\_/)
Re: Programming Pics using C
Post by bitfogav » Sat Jun 18, 2011 3:57 am
Hi Jay, hope you had a nice holiday? go anywhere nice?
Thanks for posting the code too, I will give this ago. :)
Post by brad » Sat Jun 18, 2011 8:00 am
Well done! That's really great news :D
What's the contract all about or are you not able to say just at the moment?
counting clock cycles and interrupts are still something I have mostly kept away from. I do want to get into generating video games on an actual tv which will require these skills so one day I will need to learn!
Hows the user base behind C18? I may very well have to get into some C myself and we could have a new forum here just for it!
odessa
Post by odessa » Sat Jun 18, 2011 5:51 pm
Hi Brad,
Thx :D :D :D
I can't believe I'm going to be paid for something I love doing :lol:
I can't say exactly what it is as I had to sign a non disclosure agreement, but I can say I am in the Security business and its along that line, an access control type thing.
What do you mean by User Base ? If you mean common Libraries for functions there are plenty both included and shared by people online... Not quite as simple as say Swordfish but not hard
If you mean C help forums etc there are plenty but C differs slightly platform to platform but all follow the same syntax rules.
I really though I would hate C but I must admit I'm loving it, plus its a portable code too....
Jay
(\_/)
odessa
Post by odessa » Sat Jun 18, 2011 6:05 pm
Hi Gav ..... NO !!! :lol:
It was only a short break in Bournemouth, Got a chest infection and the weather sucked :(
Still, going to Portugal in August .... Can't wait :D
Jay
(\_/)
Post by brad » Sun Jun 19, 2011 8:36 pm
Well, once the product is complete be sure to post full details!
