AVR - Flash a single LED
Post by bitfogav » Fri May 06, 2011 2:05 am
Heres a simple AVR code using C language to flash a single LED on PORTB :)
// F_CPU tells util/delay.h our clock frequency
#define F_CPU 8000000UL	// Clock frequency (8MHz)
#include <avr/io.h>            // avr input and output header
#include <util/delay.h>       // avr delay header
 int main (void)
		 DDRB = 0xFF;	// all PORTB Outputs
			 while(1) // do forever...
                PORTB |=  1 << PB0;	// LED on
                _delay_loop_2(40000);
				   PORTB &= ~(1 << PB0);	// LED off
 return 0;
Re: AVR - Flash a single LED
Post by brad » Sat May 07, 2011 10:52 am
I started looking into programming PIC's with C a couple of years ago and can see that the syntax is quite similar.
Be sure to keep us posted of your future endeavors!
odessa
Post by odessa » Sat May 07, 2011 4:13 pm
Hi Gav,
What do the annotations |,& and ~ mean ?
PORTB |= 1
PORTB &= ~
I ask as this looks essentially C to me and may be a good way for me to learn it ( Damn ... I just know I'm going to get an arduino now )
Jay
(\_/)
Post by bitfogav » Sat May 07, 2011 8:33 pm
Hi Jay
Has far as Im aware there is a slight difference between AVR and Arduino, the Arduino includes a cross platform IDE which will get you started quicker. Both use the C language but with some differences. (abit like Swordfish and Proton both Basic languages but slight differences)?.
PORTB |=
PORTB &= ~
The code that you pointed out Jay are bitwise operators in C as all I wanted to do was change bit0 of PORTB, the diagram below might help explain the bitwise operators in C better.
The one bitwise operator that confused me when I saw it was "~" bitwise operator but once you understand how it works its easy enough. The "~" is a bitwise complement (bitwise NOT), in other words this operator works like this:
So if we take the binary value 1.
00000001
Then if we ~1 using the "~" operator, this will flip the bits so the value is now.
11111110
Hope that helps you understand how the "~" operator works. the others which are "&" is a bitwise AND, and the "|" is bitwise OR operator.
You could also write C code like this:
PORTB = 0x01;  (which is Hex)
or
PORTB = 0b00000001; (which is binary)
or
PORTB = 1; (which is decimal)
all will set PORTB bit 0 high (logic 1). :)
odessa
Post by odessa » Mon May 09, 2011 5:16 pm
Thanks Gav thats very helpful, I've yet to find any really good tutorials on C, I find it's syntax quite confusing what with all the parenthesis brackets etc.
Also can you recommend a starter board for and AVR ?
Jay
(\_/)
Post by bitfogav » Tue May 10, 2011 3:59 am
odessa wrote:I've yet to find any really good tutorials on C, I find it's syntax quite confusing what with all the parenthesis brackets etc.
Your right Jay I found it difficult finding a good tutorial on C too, spent alot of time searching google and just picked up bits of the syntax along the way, I can share some PDF files Ive come across which might come useful? :)
C language help.rar
(1.56 MiB) Downloaded 1326 times
odessa wrote: Also can you recommend a starter board for and AVR ?
My knowledge of AVR development/starter boards are very slim if im honest, a friend of mine has the AVR STK500 board (cheaper on ebay),
comes with a built in programmer and alot of options for different types of Atmel microchips, but the board only comes with 8 buttons/leds, but I think there is a replacement out for this board now called STK600.
Heres the introduction PDF file for the STK500 if you are interested?:
Introduction to the STK500.rar
(3.08 MiB) Downloaded 1140 times
From a personal view I would recommend getting the AVR ISP mkII programmer, very cheap (abit like the Pickit2, hence the word "abit") but there is one down-side of this programmer :( it doesn't supply power to your projects unlike the pickit2.. but easy enough to connect to a bread board, One other note that I have found with this programmer is that all your projects need a on board power supply (a simple voltage reg would do the trick) As there is what is known as a power supply buffer on the programmer, basically so the programmer knows if your Atmel microchip is a 3.3volt or 5v microchip.
odessa
Post by odessa » Tue May 10, 2011 5:54 am
Thanks Gav they are very very helpful and appreciated :D
I'll check out ebay and get a programmer this evening, any recommends for a good Atmel starter chip ?
With regards to the AVR programmer you might like this
Its by Dave Jones .... I love his channel on you tube ... He's a nutcase :lol: ... Very clever guy though,
(\_/)
Post by bitfogav » Tue May 10, 2011 6:37 am
HaHa yeah Dave Jones, I like watching his Blogs.. Quite interesting! :) (funny enough I was going to post that video).
Ummm ive just been using a 28pin - ATmega168 (ATMEGA168-20PU) seems to be good enough for what ive been messing with :)
Post by bitfogav » Tue May 10, 2011 7:04 am
Post by brad » Tue May 10, 2011 10:21 pm
How have you found the learning curve of using AVR's with C as opposed to pics in basic?
Post by bitfogav » Wed May 11, 2011 4:46 am
brad wrote:How have you found the learning curve of using AVR's with C as opposed to pics in basic?
Still prefer Basic (Swordfish) I have to say and PIC microchip, this was just an adventure. C language is harder to learn. The syntax of C as Jay pointed out is confusing, there seems alot of librarys out there for AVR C language to a company you with building your projects but a personal view I would'nt say I found one I was overwhelmed with, especially when trying to add a LCD to one of my project. In that case I guess you cant beat the support you get with Basic (Swordfish) and the librarys (modules) that you get.
I dont really want to go into the Pros and Cons of the two microchips but heres a good video :)
Post by brad » Wed May 11, 2011 6:14 am
Thanks for that extra info Gav. I am certainly not someone who shuns Atmel microcontrollers or arduino's or anything. For me, I just started out with pics and it has worked very nicely! I am sure that if I had started out with AVR's that I would still be in the same sort of position :)
Post by bitfogav » Wed May 11, 2011 6:44 am
brad wrote:Thanks for that extra info Gav. I am certainly not someone who shuns Atmel microcontrollers or arduino's or anything. For me, I just started out with pics and it has worked very nicely! I am sure that if I had started out with AVR's that I would still be in the same sort of position :)
Same here Brad I started with pics and its working nicely!, just thought I would try the grass on the other side as they say!! hehe! :)
