PWM to control 8 LEDS using SF Basic
Post by bitfogav » Sun Aug 15, 2010 8:17 pm
Heres a way of controlling 8 LEDs connected to one PORT, some of this code was from digital-diy.com but I made it so it controlled 8 leds and added more functions, the code might not be very efficient but its works and it would make a great lighting effect if you was to make Led arrays from it. :)
Device = 18F4550    // this is what microchip we are using
Clock = 48          // makes the micro work at 12 million instructions per sec (using a 20mhz crystal)
Config  PLLDIV = 5,         // configure PPL and our OSC settings
        CPUDIV = OSC1_PLL2,
        USBDIV = 2,
        FOSC = HSPLL_HS
Include "RandGen.bas"     // this module will give us a random numbers between 0 - 255
// Our Variables
Dim TMR2IE As PIE1.1,           // TMR2 interrupt enable
    TMR2IF As PIR1.1,           // TMR2 overflow flag
    TMR2ON As T2CON.2,          // Enables TMR2 to begin incrementing
    Signal_Pin As PORTD.0           // Signal output to frequency meter (debugging)
Dim one_Pin As PORTB.0,         // Out control pins...
    two_Pin As PORTB.1,
    three_Pin As PORTB.2,
    four_Pin As PORTB.3,
    five_Pin As PORTB.4,
    six_Pin As PORTB.5,
    seven_Pin As PORTB.6,
    eight_Pin As PORTB.7
Dim one_Duty As Byte,           // user pwm control
    two_Duty As Byte,
    three_Duty As Byte,
    four_Duty As Byte,
    five_Duty As Byte,
    six_Duty As Byte,
    seven_Duty As Byte,
    eight_Duty As Byte,
    all_Duty As Byte,
    one_DutyVal As Byte,
    two_DutyVal As Byte,
    three_DutyVal As Byte,
    four_DutyVal As Byte,
    five_DutyVal As Byte,
    six_DutyVal As Byte,
    seven_DutyVal As Byte,
    eight_DutyVal As Byte,
    all_DutyVal As Byte,
    RandomVal As Byte           // used to store the random number
Dim uS As Word,
    mS As Word
// Our Interrupt Routine
Interrupt TMR2_Interrupt()
    High(Signal_Pin)            // used for debugging
    Save(0)                     // Back up system variables
    If TMR2IF = 1 Then          // Check if the interrupt was from TMR2
        TMR2IF = 0              // Clear the TMR2 interrupt flag
        uS = uS + 50
        If uS >= 1000 Then
            uS = uS - 1000
            Inc(mS)
            Inc(one_DutyVal)
            Inc(two_DutyVal)
            Inc(three_DutyVal)
            Inc(four_DutyVal)
            Inc(five_DutyVal)
            Inc(six_DutyVal)
            Inc(seven_DutyVal)
            Inc(eight_DutyVal)
            Inc(all_DutyVal)
    If one_DutyVal > one_Duty Or one_Duty = 0 Then
        one_Pin = 0
        Else
        one_Pin = 1
    If two_DutyVal > two_Duty Or two_Duty = 0 Then
        two_Pin = 0
        Else
        two_Pin = 1
    If three_DutyVal > three_Duty Or three_Duty = 0 Then
        three_Pin = 0
        Else
        three_Pin = 1
    If four_DutyVal > four_Duty Or four_Duty = 0 Then
        four_Pin = 0
        Else
        four_Pin = 1
    If five_DutyVal > five_Duty Or five_Duty = 0 Then
        five_Pin = 0
        Else
        five_Pin = 1
    If six_DutyVal > six_Duty Or six_Duty = 0 Then
        six_Pin = 0
        Else
        six_Pin = 1
    If seven_DutyVal > seven_Duty Or seven_Duty = 0 Then
        seven_Pin = 0
        Else
        seven_Pin = 1
    If eight_DutyVal > eight_Duty Or eight_Duty = 0 Then
        eight_Pin = 0
        Else
        eight_Pin = 1
    If all_DutyVal > all_Duty Or all_Duty = 0 Then
       Toggle (Signal_Pin)  // used for debugging or can be
        Else
        one_Pin = 1
        two_Pin = 1
        three_Pin = 1
        four_Pin = 1
        five_Pin = 1
        six_Pin = 1
        seven_Pin = 1
        eight_Pin = 1
        Restore             // Restore system variables
        Low(Signal_Pin)     // used for debugging
End Interrupt
// Our Timer2 setup
Private Sub TMR2_Initialize()       // setting up TMR2 for a 15micro-sec interrupt
        TMR2ON = 0                  // Disable TMR2
        TMR2IE = 0                  // Turn off TMR2 interrupts
        PR2 = 149                   // TMR2 Period register PR2
        T2CON = %00000001           // T2CON 0:1 = Prescale
                                    //        00 = Prescale is 1:1
                                    //        01 = Prescale is 1:4
                                    //        1x = Prescale is 1:16
                                    //      3:6 = Postscale
                                    //     0000 = 1:1 postscale
                                    //     0001 = 1:2 postscale
                                    //     0010 = 1:3 postscale...
                                    //     1111 = 1:16 postscale
        TMR2 = 0                  // Reset TMR2 Value
        TMR2IE = 1                // Enable TMR2 interrupts
        TMR2ON = 1                // Enable TMR2 to increment
        Enable(TMR2_Interrupt)
// Our Initializations
Low(one_Pin)
Low(two_Pin)
Low(three_Pin)
Low(four_Pin)
Low(five_Pin)
Low(six_Pin)
Low(seven_Pin)
Low(eight_Pin)
one_Duty = 0
two_Duty = 0
three_Duty = 0
four_Duty = 0
five_Duty = 0
six_Duty = 0
seven_Duty = 0
eight_Duty = 0
all_Duty = 0
one_DutyVal = 0
two_DutyVal = 0
three_DutyVal = 0
four_DutyVal = 0
five_DutyVal = 0
six_DutyVal = 0
seven_DutyVal = 0
eight_DutyVal = 0
all_DutyVal = 0
uS = 0
mS = 0
RandGen.Initialize(128)             // Initialize the Random Number generator (set to 128 but can be changed)
TMR2_Initialize                     // Setup and enable TMR2
// Start Of Program...
While True                          // Create an infinite loop
        RandomVal = RandGen.Rand    // Grab a random number from 0 to 255
            Select RandomVal        // Find out what colour to increase/decrease
            // Led One
                Case 0 To 15
                    While one_Duty <255> 0
                        mS = 0
                        Repeat
                        Until mS = 19  // this it the time it takes for the led to get to full dim
                        Dec(one_Duty)
            // Led Two
                Case 31 To 46
                    While two_Duty <255> 0
                        mS = 0
                        Repeat
                        Dec(two_Duty)
            // Led Three
                Case 62 To 77
                    While three_Duty <255> 0
                        mS = 0
                        Repeat
                        Dec(three_Duty)
            // Led Four
                Case 93 To 108
                    While four_Duty <255> 0
                        mS = 0
                        Repeat
                        Dec(four_Duty)
            // Led Five
                Case 124 To 139
                    While five_Duty <255> 0
                        mS = 0
                        Repeat
                        Dec(five_Duty)
            // Led Six
                Case 155 To 170
                    While six_Duty <255> 0
                        mS = 0
                        Repeat
                        Dec(six_Duty)
            // Led Seven
                Case 186 To 202
                    While seven_Duty <255> 0
                        mS = 0
                        Repeat
                        Dec(seven_Duty)
            // Led Eight
                Case 218 To 233
                    While eight_Duty <255> 0
                        mS = 0
                        Repeat
                        Dec(eight_Duty)
            // All Leds
                Case 250 To 255         // if we come here then all leds slowly dim (one by one)
                    If (PORTB.0) = 1 Then
                        While one_Duty > 0
                            mS = 0
                            Repeat
                            Dec(one_Duty)
                    If (PORTB.1) = 1 Then
                        While two_Duty > 0
                            mS = 0
                            Repeat
                            Dec(two_Duty)
                    If (PORTB.2) = 1 Then
                        While three_Duty > 0
                            mS = 0
                            Repeat
                            Dec(three_Duty)
                    If (PORTB.3) = 1 Then
                        While four_Duty > 0
                            mS = 0
                            Repeat
                            Dec(four_Duty)
                    If (PORTB.4) = 1 Then
                        While five_Duty > 0
                            mS = 0
                            Repeat
                            Dec(five_Duty)
                    If (PORTB.5) = 1 Then
                        While six_Duty > 0
                            mS = 0
                            Repeat
                            Dec(six_Duty)
                    If (PORTB.6) = 1 Then
                        While seven_Duty > 0
                            mS = 0
                            Repeat
                            Dec(seven_Duty)
                    If (PORTB.7) = 1 Then
                        While eight_Duty > 0
                            mS = 0
                            Repeat
                            Dec(eight_Duty)
                    // now we turn on all leds to full brightness and then dim them
                        DelayMS(100)
                    While all_Duty <255> 0
                        mS = 0
                        Repeat
                        Until mS = 22  // this it the time it takes for the led to get to full dim
                        Dec(all_Duty)
            End Select
Post by brad » Sun Aug 15, 2010 9:36 pm
Nice piece of code, It looks like you are zooming ahead with SF basic programming :)
Actually one thing I didn't know you could do is use case statements in the way that you did. e.g.
Case 93 To 108
I thought you could only specify one case for each statement. Thanks for that!
Post by bitfogav » Sun Aug 15, 2010 9:39 pm
Yeah I found that you can use CASE in this way, rather than using something like this:
If counter >= 100 And counter <= 200 Then
