What leds do you use on your pov projects
- Joined: Sun Mar 28, 2010 1:27 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
What leds do you use? My yellow and White dont mix right. Also in your other pov it looks like you have smaller ones. I want a higher reselution so I would prefer those.
-Digg-
-Digg-
Re: What leds do you use on your pov projects
I use 5mm common cathode diffused RGB LED'sDigg wrote:What leds do you use? My yellow and White dont mix right. Also in your other pov it looks like you have smaller ones. I want a higher reselution so I would prefer those.
-Digg-
MAKE SURE YOU USE DIFFUSED!!! otherwise there is no 'substance' to hold onto the colour when it is spinning. (if that makes sense)
To get higher resolution in the same area, you would definately want to go for some small surface mount or possible some 3mm RGB LED's (but I dont know if they even exist?)
This is probably useless info but if you cant get diffused LEDs then you can get a spray, If you have LEDs in a clear package you can diffuse them using Plasti-Kote Glass Frosting spray, obviously this maybe called something different in your area? but this works quite well but don't spray the LEDs until they've been assembled in the jig otherwise as you build the jig you can rub the coating off the sides of the LEDs.
heres a website..
http://www.plasti-kote.co.uk/Product/pc ... ode---3620
If you go to "Where to buy" on the website, apparently its available worldwide!!
heres a website..
If you find some LEDs
The ones I have are from radioshack. They are 5mm defused. I would like to enlarge the design to 16+ LEDs. But the 5mm LEDs don't give a good resolution. So I want to go smaller but have not found any that are smaller. If someone can find some small rgb LEDs or an led bar of some sort it would be a great help.
-digg-
-digg-
That's a nifty tip, especially since I think the clear RGB LED's are cheaper than diffused.bitfogav wrote:This is probably useless info but if you cant get diffused LEDs then you can get a spray, If you have LEDs in a clear package you can diffuse them using Plasti-Kote Glass Frosting spray, obviously this maybe called something different in your area? but this works quite well but don't spray the LEDs until they've been assembled in the jig otherwise as you build the jig you can rub the coating off the sides of the LEDs.
heres a website..
Re: If you find some LEDs
Your best bet is to try and get some small surface mount LED's.Digg wrote:The ones I have are from radioshack. They are 5mm defused. I would like to enlarge the design to 16+ LEDs. But the 5mm LEDs don't give a good resolution. So I want to go smaller but have not found any that are smaller. If someone can find some small rgb LEDs or an led bar of some sort it would be a great help.
-digg-
be sure to let us know if you find some cheap ones
- Joined: Sun Apr 04, 2010 5:57 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
RGB LED POV
Here is a SMD LED that might light up an interest for you guys, I have been using these while working on a POV unrelated product.
They can reproduce a wide range of colors and are BRIGHT!, I have not had to use any heat dissipation methods with them either.
The LED's are: SML13RGB_T Series
Or look at the full product listing.
http://www.ledtronics.com/Products/Prod ... P=C421K446
Did i mention they can be a bit hard to find unless you want to buy a full reel (2,000 LED's)
Re: RGB LED POV
he he, nice punTestSubject421 wrote:Here is a SMD LED that might light up an interest for you guys
thanks for the link too!
They don't have a price so I don't know what the quantity you would need to buy and I haven't tried them so I don't know what to tell you.
http://parts.digikey.com/1/parts/151719 ... -013f.html
- waywardson07
- Joined: Wed Nov 24, 2010 5:01 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Hi i was wondering what the led's from radio shack you are using are called? I went to my local radio shack and they didn't know what RGB LED's were :/ so i am unable to find any locally so far..Digg wrote:The ones I have are from radioshack. They are 5mm defused. I would like to enlarge the design to 16+ LEDs. But the 5mm LEDs don't give a good resolution. So I want to go smaller but have not found any that are smaller. If someone can find some small rgb LEDs or an led bar of some sort it would be a great help.
-digg-
I think it's unfortunate that employees at an electronics store don't know what they are!
You could try saying things like red green blue LED's or three color led's or tri-color leds. I really don't know what else you could say to them.
You could always get them online and probably save a bit of money but you would have to wait until they arrived ofcourse.
- waywardson07
Thanks for your reply :]]
i decided to just to drive over there and find out for myself and it turns out they do have them. they are labelled as "Full Color LED's" they seem to have a diffuser coating on them as well. The price for each is $2.99
here is a link:
http://www.radioshack.com/product/index ... PerPage=60
here is a link:
Wow, $2.99 each! That's expensive. You can buy them on ebay for roughly 20 cents each if you buy them in lots of 50 or 100.
here's an ebay link to a lot of 100 including resistors for under $20
http://cgi.ebay.com.au/100-pcs-5mm-RGB- ... 19c1162d38
