by Chuckt » Sun Apr 09, 2017 9:02 am
DS1804-010
Digital Potentiometer ICs NV Trimmer
http://www.mouser.com/ProductDetail/Max ... v%252b%2f7
DESCRIPTION
The DS1804 NV trimmer potentiometer is a nonvolatile digital potentiometer that has 100 positions. The
device provides an ideal method for low-cost trimming applications using a CPU or manual control input
with minimal external circuitry. Wiper position of the DS1804 can be stored in EEPROM memory on
demand. The device’s wiper position is manipulated by a three-terminal port that provides an increment/
decrement counter controlled interface. This port consists of the control inputs CS , INC , and U/ D . The
DS1804 is available in three resistor grades, which include a 10kΩ, 50kΩ, and 100kΩ. The device is
provided in an industrial temperature grade. Additionally, the DS1804 will operate from 3V or 5V
supplies and is ideal for portable application requirements. Three packaging options are available and
include the 8-pin (300 mils) DIP, 8-pin (150 mils) SO, and 8-pin (118 mils) μSOP.
http://www.mouser.com/ds/2/256/DS1804-99557.pdf
This chip is in dip form.
