by Chuckt » Thu Aug 07, 2014 1:04 am
World’s smallest Arduino ever 16.9 x 12.7 mm
There are a couple that are a little bigger.
OLIMEXINO-85S is smallest Arduino compatible board in the world with only 16.9 x 12.7 mm it’s with microSD card like size.
http://olimex.wordpress.com/2014/02/21/ ... x-12-7-mm/
by brad » Sat Aug 09, 2014 11:56 pm
I thought the digispark would have been the smallest:
Until i followed your link!
by Chuckt » Fri Apr 24, 2015 1:10 pm
The Smallest Arduino made by Olimex costs $7.45.
http://www.mouser.com/ProductDetail/Oli ... 0N0g%3d%3d
I wonder how much the Digispark costs.
by brad » Sun Apr 26, 2015 10:03 pm
Well it looks as though the Olimex is the winner, the Digispark is $8.95
http://digistump.com/products/1
In fact, Digistump (the maker of the digispark) has just brought out a new microcontroller. It has built in WIFI and everything about it is wireless, you can update the firmware over WIFI, you can program it over WIFI, you can read data from it (for example, from sensors attached to it) over WIFI and you can debug over WIFI!
https://www.kickstarter.com/projects/di ... duino-comp
