Implementing DS18B20.bas into code w/ ADC
Re: Implementing DS18B20.bas into code w/ ADC
Post by MrDEB » Fri Aug 10, 2012 3:40 am
my problem now is comparing the sensor temp to the ADC reading
Hoping myTemp = DecToStr(TempA),Dectostr(TempB) would have done the trick but I guess not.
Perhaps compare the Dec of Temp to ??
NoInline   Sub sens_tep()
        Dim myTemp As Word
        Dim TempA As ShortInt
        Dim TempB As Word
            If DS18B20.Find Then
            While true
                DS18B20.Convert
                DS18B20.GetTemp(TempA,TempB)
                LCD.Cls
                LCD.WriteAt(1,1,"bx temp",DecToStr(TempA),".",DecToStr(TempB,1), "'C    ") // displays temp in C
                myTemp = (DecToStr(TempA),".",DecToStr(TempB,1))     // trying to compare to deg_s (ADC.read(1)
                DelayMS(3000)
              //  LCD.writeat(1,1,dectostr( TempB))
              //  delayms(3000)
             if myTemp > deg_s
             then
                  LED_g = 1
                  LED_r=0
             else
                 LED_g = 0
                  LED_r=1
             end if
                Exit
Post by bitfogav » Fri Aug 10, 2012 3:57 am
Ill probably change your code to something like this?:, get rid of myTemp and the While.. Loop and Exit..
But note TempA is going to be the value in Celsius, So your have to change deg_s to suit or convert TempA value into Fahrenheit. you've just got to uncomment the line of code as indicated in my code.
Sub sens_tep()
        Dim TempB As Word
                DS18B20.Convert
                LCD.Cls
                DelayMS(3000)
// just uncomment the line below, it will convert C to F
 //        TempA = TempA * 9 / 5 + 32
             If TempA > deg_s Then
                  LED_g = 1
                  LED_r=0
             Else
                 LED_g = 0
                  LED_r=1
Post by MrDEB » Fri Aug 10, 2012 5:10 am
Will try your suggestion
BUT hopefully with out the EXIT it won't stop in the sub route.
This is what it WAS doing before I added the EXIT.
Post by MrDEB » Fri Aug 10, 2012 8:14 am
Your suggestion worked GREAT. Not real happy that the display is what it is. Am sure there is a way to get degree fractions but Celius is better. Display shows Box temp in Celius and Desired temp in F.No big deal at this point.
Here is the SUB routine you suggested. I added a delay for DEFROST (1000 * drf)
drf is derived from the ADC routine for defrost timer.
not really happy with it but it seems to work.
[code]Public Sub sens_temp()
        Dim TempB As Word
                DS18B20.Convert
                LCD.Cls
                LCD.WriteAt(1,1,"bx temp",DecToStr(TempA),".",DecToStr(TempB,1), "'C    ") // displays temp in C box temp
                DelayMS(3000)
             TempA = TempA * 9 / 5 + 32                //tempA is box temp
             If TempA < deg_s Then
                  LED_g = 0                              // cooling off
                  LED_r=1                                //defrost cycle
              DelayMS(1000*drf)                          //defrost cycle timer time = dfx X 1000
                 Else
                  LED_g = 1                              //cooler on
                  LED_r = 0
Post by brad » Fri Aug 10, 2012 1:22 pm
After not logging on here for a couple of days, it's great to see you guys getting right in there and solving problems - just like the good old days!
Post by bitfogav » Fri Aug 10, 2012 7:10 pm
brad wrote:After not logging on here for a couple of days, it's great to see you guys getting right in there and solving problems - just like the good old days!
Late again to the party Brad? :lol: hehe..
mrDeb, do you have any pictures to share of your beer cooler? or the what the LCD display looks like? :)
Post by MrDEB » Fri Aug 10, 2012 9:20 pm
Will be going out to the Fairgrounds next week and will take some pics and perhaps enjoy a beer when I get back to town.
YES I can snap a pic of the LCD display perhaps a short clip as the display changes from displaying the DESIRED TEMP/ Defrost time to Box temp.
i am working on changing the DESIRED TEMP to Celius but I can only use whole numbers. Perhaps just convert the Faheringh numbers to Celius but the result is not an integer.
Working on solution after I confirm the DELAYMS(1000 * drf) works well.
Contemplating perhaps a loop with a counter, somethingf like UNTIL COUNTER = drf (drf is derived from the DEFROST ADC routine.
Post by MrDEB » Sat Aug 11, 2012 8:46 am
Been trying to get a simple timer for the DEFROST cycle.
Looked at lots of different codes as well as the Swordfish manuals.
Well I think I got it. Found I could not put the D_counter = 0 in the sub. WHY ???
Anyway it appears to work Have it running right now and it FREEZES on the Box Temp display which is understandable.
Need to tiddy up etc but it appears to STOP when the BOX temp is lower than the DESIRED TEMP. Changing the DELAYms() for a ten minute delay then hopefully the variable drf will adjust as desired.
*  Author  : [select VIEW...EDITOR OPTIONS]                                 *
*  Notice  : Copyright (c) 2012 [select VIEW...EDITOR OPTIONS]              *
*  Date    : 8/8/2012                                                       *
*  Notes   :        *
    Device = 18F4520
    Clock = 20
    // some LCD options...
    #option LCD_DATA = PORTD.4
    #option LCD_RS = PORTD.2
    #option LCD_EN = PORTD.3
    // uses LCD and AD libraries...
    Include "LCD.bas"
    Include "ADC.bas"
    Include "convert.bas"
    Include "DS18B20.bas"
    Dim LED_g As PORTC.4
    Dim LED_r As PORTC.5
    Dim Vref As Word
    Dim Vsensor As Word
    Dim Desired_T As Word          //DESIRED TEMP
    Dim D_Frost As Word          //DEFROST TIME
    Dim deg_s As Word
    Dim D_counter As Word
    Dim count_down As Integer
            //DESIRED TEMP
    // Read the AD ports and scale
    Function Dsired_T() As Word
     result = (ADC.Read(1) +1) /100  //Read DESIRED TEMP Adjustment
    End Function
    Function sensor() As Word
     result = (ADC.Read(0) + 1)/100  // 100  //Read DEFROST TIMER ADJUSTMENT
    End Function
    Dim drf As Word
    //xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    // I need this routine to read the DS18B20 buit keep getting syntax errors
    // the LCD, ADC sections all worked before putting the DS18B20 into the code
    //syntax says a sub routine or  or function is expected
        Dim TempB As Word
                DS18B20.Convert
                LCD.Cls
                DelayMS(3000)
                  LED_r=1
                  repeat
                  delayms(1000)
                  inc (D_counter)
                  until D_counter = drf*60                                //defrost cycle
                 Else
                  LED_r = 0
    //xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    // Start Of Program...
    Input(PORTA.0)                  // DESIRED TEMP
    Input(PORTA.1)                  // DEFROST TIMER
    Low (LED_g)                     //set lEDs OFF
    Low (LED_r)
    ADCON1 = %10000000              //set up ADC regesters
    ADCON0.7 = 1
    ADCON0.6 = 1
    ADCON1 = $07
    TRISA = %111111
    TRISB = %11111111
    TRISC = %00000000
    TRISD = %00000000
    TRISE = %000
 SetPin(PORTB.3)                  // sensor pin
    DelayMS (150)
    LCD.Cls
     While true
            // call function REF_V() and assign the result to word variable 'Vref'
            Vref =Dsired_T ()           //DESIRED TEMP
            Vsensor = sensor()       //DEFROST TIMER
    Select Vref
           Case <1 deg_s = 50
           Case <2 deg_s = 51
           Case <3 deg_s = 52
           Case <4 deg_s = 53
           Case <5 deg_s = 65
           Case <6 deg_s = 70
           Case <7 deg_s = 75
           Case <8 deg_s = 76
           Case <9 deg_s = 77
    End Select
    Select Vsensor
           Case <1 drf = 10
           Case <2 drf = 12
           Case <3 drf = 14
           Case <4 drf = 16
           Case <5 drf = 17
           Case <6 drf = 19
           Case <7 drf = 21
           Case <8 drf = 23
           Case <9 drf = 25
    End Select
    // main program loop...
             sens_temp()             // get temperature
            LCD.MoveCursor (1,1)
            LCD.WriteAt(1,1,"Desired temp=", DecToStr(deg_s),"F")  // Display DESIRED TEMP
     // call function sensor() and assign the result to word variable 'drf'
            LCD.MoveCursor (2,1)
            LCD.Write("DEFROST = ", DecToStr(drf),"    ")   //Display DEFROST TIMER
            DelayMS(3000)
              D_counter = 0
            if led_r = 1 then
               D_counter = 0
                  Repeat
                  DelayMS(1000)
                  Inc (D_counter)
                  Until D_counter = drf*6000
                       //drf is case select Vsensor
                 endif
        //   If LED_r = 1 Then
          //    DelayMS(1000*drf)
Post by brad » Sun Aug 12, 2012 10:58 pm
Yeah, fair enough!
Although, I have been eye deep in my first commercial project - which will be launched very soon now (Just waiting on quotes from manufacturers...)
Details to come soon!
Post by bitfogav » Mon Aug 13, 2012 5:40 am
I'm fascinated to what you've have been working on Brad, look forward to seeing it. :)
Post by brad » Mon Aug 13, 2012 10:03 pm
I think you'll like it!
Post by MrDEB » Tue Aug 21, 2012 9:17 pm
BEER COOLER is up and running. It is kinda crude as the code could use some tweeking and would like the display to scroll across the screen. Ran out of time. No big deal right now.
Will take some pics today as the beer is being delivered today.
During the 4 days our KoC beer booth is open well sell 18-20 kegs, 30_+ cases of caned beer and 10-15 cases of wine coolers. You have a hard time getting a beer after the Rodeo on Thursday and Friday night.
Beer on tap = Coors Light biggest seller
PBR, Koenknee, Bohra Ale(local brew pub) and Alaskan Amber.
My favorite is Alaskan Amber
ALL the beer is poured at a COLD 34 degrees
Post by brad » Wed Aug 22, 2012 6:33 am
Great to hear you got it all up and running!
Any pics of the completed project?
Post by MrDEB » Tue Aug 28, 2012 10:44 am
The code was hanging up in the sub routine so made a few minor changes.
        Dim TempB As Word
                DS18B20.Convert
                LCD.Cls
                TempA = ((TempA * 9) / 5)+ 32               // converts from Celius to F
                LCD.WriteAt(1,1,"box temp =",DecToStr(TempA ),".",DecToStr(TempB,1), "F") // displays temp in C box temp
                DelayMS(3000)
             //tempA is box temp
             If TempA <= deg_s Then                         // compare box temp w/ desired temp
                  LED_g =0                                  // cooling off
                  LED_r=1
                  High(ctr)                                 //Defrost relay ON
                  //xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                  //xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                  // defrost counter If box is < DESIRED TEMP
                  Repeat
                  DelayMS(5000)             [b] THIS SECTION WAS HANGING thus stopping and leaving the cooler ON[/b]
                  Inc (D_counter)
                  delayms(5000)
                  Until D_counter = drf *6             //drf is case select Vsensor
                  Else
                  LED_r = 0
                  Low(ctr)                               //relay OFF
