Didnt Work
Re: Didnt Work
Post by bitfogav » Wed Oct 12, 2011 2:40 am
I know how frustrating it can be when something you've put together dont work.. you say you think it might be the power supply on the tracks on the left of the board?? :roll:
If you mean the ones on the front of the board then these power up the transitors, you can check power supply to the pins on the transitors has shown in this picture below:
The other thing what 8x8 matrix are you using?, did Brad supply you with the 8x8matrix? Or where did you get it from?.
1kiko1
Re: Didnt Work
Post by 1kiko1 » Wed Oct 12, 2011 9:47 am
i bought the 8x8 led common anode in a web called futurlec.com i have bought many things from there and brad did not supply me the 8x8
Re: Didnt Work
Post by bitfogav » Thu Oct 13, 2011 2:26 am
Ive looked on futurlec.com but I cant seem to find a red and green 8x8 matrix that would fit the specs of the 8x8 game system board?..
http://www.futurlec.com/LEDMatrix.shtml Can you post a link to it or the link to the datasheet, I just wanted to make sure that the 8x8 matrix pins etc matched the 8x8 game system specs :)
rd1196
Re: Didnt Work
Post by rd1196 » Thu Oct 13, 2011 11:37 am
Hey gavin, there is a link to the datasheet of the 8x8 screens with the same dimensions on the board on a topic of the great race viewtopic.php?f=2&t=250&start=15
Re: Didnt Work
Post by bitfogav » Fri Oct 14, 2011 1:25 am
Thanks for that, I forgot about that topic. well it cant be a 8x8 matrix problem then?
what makes you think that its the lines on the left of the board?
rd1196
Re: Didnt Work
Post by rd1196 » Fri Oct 14, 2011 1:38 pm
Is a 74ls373 the same as a 74373n?
Re: Didnt Work
Post by bitfogav » Sat Oct 15, 2011 9:35 am
All 74373 function in that same way. the "N" at the end of the 74373N is just a package type depending on manufacturer for example:
J = CERAMIC
N = PLASTIC
DW = SOIC
Re: Didnt Work
Post by brad » Mon Oct 17, 2011 8:47 pm
rd1196 wrote:Is a 74ls373 the same as a 74373n?
It is the same in that it performs the same function. However, the LS denotes that it is lowpower (L) and has a schottky diode connected between the base and collector of the insternal transistors that make up the gates in the chip. What this means for you is that the schottky diode makes the chip faster (can handle high speed clocks) and the low power means that it is not good for driving LED's. Although it will work, the LED's will probably be pretty dim. You would want to use an HC instead.
