brad wrote:The red boards are definitely my favourite. Nice choice - they have come up just perfectly bitfogav.
Now it looks as though you've got yourself a home made reflow oven, how is that controlled? is there any problem with the sensing element coming desoldered in there?
The red boards do look great
I do have a reflow oven at home, I brought it nearly 2 years ago and it's been well worth it!.. I enjoy watching the solder paste reflow and all the components self a line.. No problems with the sensing element because it's just a Thermocouple type temperature sensor which I just attach to a piece of pcb board..
The reflow oven was one of the cheapest I could find and the controller is one that you can interface with using a PC (RS232), it's really great for adjusting the correct oven temperatures, to get the correct reflow.. If you want to check out the reflow oven and controller then the links are below.
Beta-Layout
Reflow oven
Beta-Layout
Reflow oven controller
Also I did find out that David also uses the same reflow controller as myself (for the Firewing boards), and he has put together a fantastic graphical user interface (GUI). check it out
here.
