RPI 1031 Breakout board
MrDEB
Post by MrDEB » Sun Mar 31, 2013 1:53 pm
trying to configure this chip to detect tilt but keep having to reset the pic to determine tilt but then not sure if its right.
Using a Tap-28 board where the LEDs are enabled when port is low.
Device = 18f2420
Clock = 8
//Config OSC=HS
Include "InternalOscillator.bas"
Include "utils.bas"
//Include "convert.bas"
Dim s1 As PORTC.4
Dim s2 As PORTC.5
Dim led2 As PORTB.3
Dim led1 As PORTA.3
Dim x As Byte
Dim tilt As word
Dim position As Word
dim tilt_pos as integer
dim index as integer
Input (s1)
Input (s2)
led1=1
led2=1
//tilt_s1 = 2
//tilt_s2 = 3
Output (led1)
Output (led2)
SetAllDigital
While true
      If s1 =0 and s2 = 0 Then tilt = 1     //
      If s1 =1 and s2 =0 Then tilt = 2
      If s1 =1 and s2 = 1 Then tilt = 3
      If s1 =0 and s2 = 1 Then tilt = 4
    if tilt = 1 then led1 = 1
       led2 = 0
      delayms (1000)
      led2 = 1            // leds off
      led1 = 1
    endif
    tilt = 0
    if tilt = 2 then led2 = 0
       led2 = 0
       delayms (1000)
       led1 = 1
    endif
    tilt = 0
    if tilt = 3 then led1 = 0     // both on
        led2 = 0
        delayms (1000)
        led1 = 1
    endif
     tilt = 0
    if tilt = 4 then led1 = 1 //and led2 = 1
      delayms(1000)        // blink once
      toggle (led1)
      toggle (led2)
      delayms(1000)
    endif
    tilt = 0
     Wend
I need direction. The code at Sparkfun is for adrino but I am using SWORDFISH.
The two outputs on the board (s1, s2) output LOW/ LOW , LOW/ HIGH , HIGH/ HIGH , HIGH/ LOW
using the code from sparkfun as example, I kinda figured just add the outputs to determine tilt.
Re: RPI 1031 Breakout board
Post by brad » Tue Apr 02, 2013 11:17 am
I'll have a good look when I get home, but what do you mean exactly where you say that you need to reset the PIC?
It looks as though the sensor out puts 00, 01, 10 or 11 depending on where the little ball is within the sensor (which wall it is on).
I found some info here:
http://bildr.org/2012/02/rpi-1031_arduino/
Post by brad » Tue Apr 02, 2013 8:10 pm
Just from a short look through your code, there is one problem where you keep making tilt = 0 and then you run an if statement to see if it something other than 0.
for example:
      led2 = 0
      delayms (1000)
      led1 = 1
endif
tilt = 0
       led2 = 0
       delayms (1000)
       led1 = 1
    endif
    tilt = 0
you check to see if tilt is equal to 1. if it is, then you run the code in the if statement, then you exit the IF statement and straight away make tilt equal to 0. Then you check to see if tilt is equal to 2 (which of course it will not be), so it skips the code in this IF statement then you make tilt equal to 0 again etc...
the key thing here is that whether or not any of the IF statements turn out to be true or not (which the only possible one that could be true is the first one) you are always making tilt 0. so you are ruling out any of the other IF statements.
Post by bitfogav » Wed Apr 03, 2013 3:08 am
Brad's right it will never get past your first IF statement..
just for an example ill probly have an Select statement for this, makes it easier to follow. something this:
Select tilt
	case 1
	   led1 = 1
      led2 = 0
      delayms (1000)
      led1 = 1
	case 2
       led2 = 0
       led2 = 0
       delayms (1000)
       led1 = 1
	case 3
        led1 = 0     		// both on
        led2 = 0
        delayms (1000)
        led1 = 1
	case 4
      toggle (led1)
      toggle (led2)
      delayms(1000)
End Select
