24 Hour Nixie tube clock w/o microcontroller
- Saimaster13
Re: 24 Hour Nixie tube clock w/o microcontroller
The holes move because the electrons jump into the holesSaimaster13 wrote:They can't start from two places though? I mean, it is kind of like 2 circuits almost independent of each other... except for the fact that the timer output does not go through the transistor.
That is why, isn't it? The 555 timer outputs to the transistor, but the electrons do not move through that wire, so it does not activate the transistor.
Whereas if you connected the grounds, holes would be going from the positive output of the 555 through to the negative emmiter of the transistor, turning it on.
Great to see it now works - how about a photo?
- Saimaster13
Well, I was just testing the concept. I connected a bunch of wires to loose resistors, a transistor, 2 batteries, a 555 circuit and a camera power module, so its not very photogenic. I did take a video of the tube blinking, its in my previous post, the link is called "Facebook video".
Joshua
Sorry, disregard my last post, I completely missed that you had a facebook video!Saimaster13 wrote:Well, I was just testing the concept. I connected a bunch of wires to loose resistors, a transistor, 2 batteries, a 555 circuit and a camera power module, so its not very photogenic. I did take a video of the tube blinking, its in my previous post, the link is called "Facebook video".
Just checked it out and that is one nice flashing number 9!
Do you plan to make it and hours, minutes and seconds clock?
PS I added you as a friend on facebook.
- Saimaster13
Cool, and I plan on making an hours and minutes minutes clock, possibly seconds too, we will see what happens. Problem is though, I have no sockets currently, but I did just order some pins for them. Hopefully they will work. Until then I will probably working on the Logic simulator code.
Joshua
It's all good, I have multiple projects on that go too
- Saimaster13
So I started working on it again. Sadly, when I tested using multiple nixie tubes with my hacked camera power supply, the nixie tubes dimmed. I decided I would only have one nixie tube on at a time, and to do this I am now using a microcontroller.
Joshua
- Saimaster13
Pictures of a work in progress.
(Pictures re- sized to 1/10 size so they can actually fit in the post.)
Ask if you want any more details or higher resolution pictures.
I am currently working on this, and once I finish and make sure that everything works alright, I will make and post schematics.
- 100_1401.jpg (108.35 KiB) Viewed 23173 times
- 100_1402.jpg (126.22 KiB) Viewed 23173 times
- 100_1404.jpg (156.04 KiB) Viewed 23173 times
- 100_1405.jpg (133.26 KiB) Viewed 23173 times
- 100_1406.jpg (134.96 KiB) Viewed 23173 times
Joshua
Very nice Joshua!
Plugging in them tubes must be abit fiddly??
- Saimaster13
Ya, it is. After you do it the first few times the pins form to the nixie's shape, but then you solder the bottom of them and they move...Plugging in them tubes must be abit fiddly??
Joshua
- Saimaster13
Looking good - although you must have been sitting there recording for hours!
- Saimaster13
It was worth it though, definitely worth it to see it actually running.
Joshua
And that's why we make projects!
