Any info on the LED display layout?
I see lots of SMD within the LEDs but need to figure out how to open the spreadsheet for the BOM.
I am using openoffice. Will get it figured out hopefully
THANKS for the great game.
Does Sneed studios or Itead have available the PCboards?
RetroBall - The new Super Pong Table
Re: RetroBall - The new Super Pong Table
Heres a List of BOM:
1x PIC18F25K20-I/SO PIC 18F25K20 Microcontroller SOIC 300mil SMT $1.93 $1.93 http://www.microchipdirect.com/ProductS ... IC18F25K20
1x PIC18F2550-I/SO PIC 18F2550 Microcontroller SOIC 300mil SMT $4.13 $4.13 http://www.microchipdirect.com/ProductS ... PIC18F2550
2x LM317T LM317T TO-220 Through Hole $0.20 $0.40 http://www.aliexpress.com/product-fm/58 ... alers.html
2x DC3 16Pin 16 Pin Male Shrouded Header Connector Through Hole $0.15 $0.30 http://www.aliexpress.com/product-fm/60 ... alers.html
2x 2N2222A 2N2222A NPN Transistor SOT-23 SMT $0.02 $0.04 http://www.aliexpress.com/product-fm/47 ... alers.html
1x IC Heatsink TO-220 Heatsink 25mm x 24mm x 16mm $0.52 $0.52 http://www.aliexpress.com/product-fm/54 ... alers.html
1x WWEL-0385 Mini Speaker 1.6cm $0.60 $0.60 http://www.aliexpress.com/product-fm/48 ... alers.html
2x P10 RED 16 x 32 Pixel RED LED Display Panel $9.05 $18.10 http://www.aliexpress.com/product-fm/52 ... alers.html
1x 0805 470 Ohm SMD Resistor 5% Tolerance 0805 SMT $0.01 $0.01 http://www.aliexpress.com/product-fm/44 ... alers.html
1x 0805 270 Ohm SMD Resistor 5% Tolerance 0805 SMT $0.01 $0.01 http://www.aliexpress.com/product-fm/44 ... alers.html
1x 0805 180 Ohm SMD Resistor 5% Tolerance 0805 SMT $0.01 $0.01 http://www.aliexpress.com/product-fm/44 ... alers.html
1x 0805 560 Ohm SMD Resistor 5% Tolerance 0805 SMT $0.01 $0.01 http://www.aliexpress.com/product-fm/44 ... alers.html
2x 0805 100 Ohm SMD Resistor 5% Tolerance 0805 SMT $0.01 $0.02 http://www.aliexpress.com/product-fm/44 ... alers.html
3x 0805 10K Ohm SMD Resistor 5% Tolerance 0805 SMT $0.01 $0.03 http://www.aliexpress.com/product-fm/44 ... alers.html
3x 0805 104K 0.1 uF SMD Capacitor 10% Tolerance 0805 SMT $0.01 $0.03 http://www.aliexpress.com/product-fm/52 ... alers.html
1x 0.1uF 0805 1 uF SMD Capacitor 10% Tolerance 0805 SMT $0.01 $0.01 http://www.aliexpress.com/product-gs/61 ... alers.html
8x 3m 10mm 3mm diameter x 10mm long screw $0.08 $0.64 http://www.aliexpress.com/product-fm/57 ... alers.html
8x 3m 25mm 3mm Internal Diameter x 25mm long Hexagonal Pillar $0.30 $2.40 http://www.aliexpress.com/product-fm/60 ... alers.html
1x PBS-33B Push Button black Momentary push on / release off $0.58 $0.58 http://www.aliexpress.com/product-fm/52 ... alers.html
1x R13-507 Push Button black Latching Push on / Push off $0.28 $0.28 http://www.aliexpress.com/product-gs/34 ... alers.html
1x 2.1mm DC Power DC Jack 2.1mm / 5.5mm $0.32 $0.32 http://www.aliexpress.com/product-fm/48 ... alers.html
4x 16100NO 10k Rotary Linear Potentiometer (need to be high quality) $0.17 $0.68 http://www.aliexpress.com/product-fm/40 ... alers.html
4x Potentiometer Knob, Black Chrome $1.25 $5 http://www.aliexpress.com/store/product ... 83892.html
1x 9V 1.5A 9Volt 1.5Amp Power Supply 2.1mm x 5.5mm Plug $3.23 $3.23 http://www.aliexpress.com/product-fm/56 ... alers.html
Never had experience with 805 but I guess I could give it a whirl.
I see you are using a 16 x 32 led display. I need to locate similar in the states or China.
THANKS for the BOM.
I want to build one maybe two (son and myself?) just need to complete my turn signal and reindeer salt/pepper shaker.
THANKS for the BOM.
Those P10 RED 16 x 32 displays are expensive on Ebay. $25 + shipping
Has anyone built a Retroball or LED matrix using 1024 separate LEDs?
I recall seeing you had built one w/ 900. How did that work out. Wonder if LED drivers are called for seeing there are alot of LEDs.
Curious about your experience in this area?
The rest of the parts can be had from Mouser or Digikey fairly reasonable.
Was thinking along the lines of the 8 x 8 matrix idea you had but cost?? then perhaps pegboard.
Sorry for the late reply - here is the cheapest that I have found:MrDEB wrote:Those P10 RED 16 x 32 displays are expensive on Ebay. $25 + shipping
http://www.aliexpress.com/item/P10-full ... 80749.html
They are $16.64 (including shipping) so around $33 for two of them delivered
YES a better price.
As soon as I get my SSI check I will have to order some.
THANKS again
THANKS again
No problem
