Hi Brad,
I was wondering as the hall effect sensor is spinning is it ON by that I mean producing a V out and when it passes over the magnet it is temporarily turned OFF (no V out) then ON again. Or is the hall effect sensor OFF (no V out) for the majority of the rotation and when it passes over the magnet it is temporarily turned ON.
Hall Effect Sensor Signal
Re: Hall Effect Sensor Signal
Sorry for the late reply.
From memory it is on until it passes the sensor. Although it doesn't matter because it is super simple to change the code to suit either type of sensor.
- newbie
- Joined: Sat Sep 10, 2011 8:55 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Thanks Brad!
No problem
