I have started working on a POV Globe and was wondering what calculations you used to design your images.
Did you start by breaking down the RPM to microseconds per rotation
then figure out what kind of "pixel resolution" the POV has
and continue on that path to figure out the proper timing for the duration of on time of the LEDs?
Or what method did you use? (i am sure you have mentioned it some where i just have not found it yet)
Keep up the good work!
I am open to any input even if some one out there has a good guess
It has been a slight headache for me but i could be making it harder than it needs to be (one of my bad habits)
If you wish to see a pic of the primitive prototype
http://s3.amazonaws.com/data.tumblr.com ... 47QfuW4%3D
Sorry about the Unrotated image and you can ignore the pickit dangling ohh and ignore the 1 unwired LED thats been fixed.
I am using a 16f690 for the MCU, 2x 3V lith button cells for power, a glass tube for my "axel" that was flared and....(kill me) hot glued onto the motor shaft, 28 green RA LEDs (14 on each side and they are mirrored, look at the pic and the wires if you dont quite understand)
ohh and the motor is a 110VAC fan motor (incase anyone wondered)
