DMX Controller
Re: DMX Controller
That's right, now I remember your other post!
I remember commenting on how perfect your boards look, mine don't come out quite so nice...
Re: DMX Controller
Yeah come to think about it you did comment about how my boards look Brad, thank you for the grateful comments.brad wrote: I remember commenting on how perfect your boards look, mine don't come out quite so nice...
I guess it comes from the amount of time I spend on them or shall I say Diptrace? lol. as for the pcb I just use press&peel and making sure the iron is on max heat, press it for a few mins and then wait for it to cool down before removing the press&peel top cover.
sum more pics to share:
LCD display just shows some testing values
Making all them wires with header connectors took awhile aswell lol.
Re: DMX Controller
Very professional!
Do you think there would be a market for you to sell these?
Re: DMX Controller
Well I dont really know to be honest Brad?, theres alot of DMX Controllers around, and this is just something I fabricated and programmed myself, giving me many hours of fun!. I guess I could make it an open source DMX Controller?, I could add a Bootloader and then use the USB connector to upload the user programmes? I dont think theres many of those on the market?.brad wrote:Very professional!
Heres a pic of the back of my controller, ICSP socket, USB, Power, power led.
Heres some DMX controllers on the market:
Re: DMX Controller
Maye you could put It on that website that chuck showed where you tell people about your projects and they them back it with money. You then send them each one when you have completed it.
Re: DMX Controller
brad wrote:Maye you could put It on that website that chuck showed where you tell people about your projects and they them back it with money. You then send them each one when you have completed it.
Yeah that sounds like a good idea
Link to that site is here:http://www.kickstarter.com/start
Re: DMX Controller
Thanks for the link!
Re: DMX Controller
Heres first release of my DMX Console Code, not included the Swordfish Modules I have created to support it
// Main Programme for Bitfogav's DMX Controller Console
// Swordfish basic (requires V2.2.0.6 or higher)
// - author: Gavin Wiggett
// - date: 24/02/2011
// Version 1.0
// Notes
// DMX Controller using a 18f4550 at 48mhz
// USB equipped for future add ons
// DMX TX Pin = user optional (default portb.0)
// IMPORTANT - DMX_TX Pin is tied together with usart TX pin
// Device and Clock
Device = 18f4550
Clock = 48
// LCD optional settings
#option LCD_DATA = PORTD.4 // LCD setup data port (sets it to 4 data lines only)
#option LCD_RS = PORTE.2
#option LCD_EN = PORTE.1
// DMX_TX optional settings
#option dmxTx_Pin = PORTD.3 // DMX_TX set output pin for dmx (transmitter)
// Modules
Include "LCD.bas"
Include "ADC.bas"
Include "convert.bas"
Include "DMX_TX.bas"
Include "RandGen2.bas"
Include "Setup_bsp.bas"
// Main Variables
Dim barrelSpeed As Byte,
barrelPos As Byte,
range As Byte,
colourChanger As ShortInt,
i As Word
// Gobo colours setup
Dim colourValue, colour, white, red, multi, magenta, green, yellow, blue, pink, cyan As Byte
Dim resetValue As Byte // store dmx channel reset value
Dim beatCounter As Byte // beat counter and delay
Dim beatDelay As Byte
Dim noBeat As Word
Dim fakeBeat As Word
Dim BPM_Interval As Word
Dim BPM_approx As Byte
Dim trueBeat_Flag As Bit
Dim j As Word
Dim secondBeat As Boolean
Dim function_value As Word // ADC function data
Dim button_1, // button booleans
button_2,
button_3 As Boolean
Dim menu_cycle As Byte // menu selections
Dim CHfunction As ShortInt
Dim CHfunctionLCD As Byte
Dim buttonDelay, // button debounce
buttonDebounce As Byte
// Subroutines ==================================
// Delay for beat detection and no beat detected
Sub beat_delay ()
If beatDelay <> 0 Then
Dec(beatDelay)
If noBeat <> 0 Then
Dec(noBeat)
// get ADC value from AN0
Function Get_ADC_Value () As Word // Function to get the ADC value
result = ADC.Read(0) // Get ADC value from channel 0
result = result / 4 // Scale the answer down by a factor of 4 (0 to 255)
End Function
// check our Button Booleans
Sub checkButtons ()
If buttonDelay = 0 Then
// button 1
If button1 = 0 Then
If button_1 = true Then
button_1 = false
Else
button_1 = true
buttonDelay = buttonDebounce // need to debounce button
// button 3
If button3 = 0 Then
If button_3 = true Then
button_3 = false
Else
button_3 = true
ElseIf buttonDelay <> 0 Then
Dec(buttonDelay) // decrease Delay for Button Debounce
Sub lcd_Update ()
// Check for menu button press
If button4 = 0 And buttonDelay = 0 Then
Inc(menu_cycle)
If menu_cycle = 4 Then
menu_cycle = 0
LCD.Cls // clear LCD Display
// Update the LCD Display
Select menu_cycle
Case 0
LCD.WriteAt(1,1,"DMX Console")
LCD.WriteAt(2,1," Prototype v1.0")
LCD.WriteAt(3,1," by bitfogav 2011")
LCD.WriteAt(4,1,"Beat= ",DecToStr(beatCounter,3)," BPM= ",DecToStr(BPM_approx,3))
Case 1
LCD.WriteAt(1,1,"CH1 = ",DecToStr(DMX_TX.DMX_Channel(0),3)," CH5 = ",DecToStr(DMX_TX.DMX_Channel(4),3))
LCD.WriteAt(2,1,"CH2 = ",DecToStr(DMX_TX.DMX_Channel(1),3)," CH6 = ",DecToStr(DMX_TX.DMX_Channel(5),3))
LCD.WriteAt(3,1,"CH3 = ",DecToStr(DMX_TX.DMX_Channel(2),3)," CH7 = ",DecToStr(DMX_TX.DMX_Channel(6),3))
LCD.WriteAt(4,1,"CH4 = ",DecToStr(DMX_TX.DMX_Channel(3),3)," CH8 = ",DecToStr(DMX_TX.DMX_Channel(7),3))
Case 2
LCD.WriteAt(1,1,"Analog = ",DecToStr(function_value,3))
LCD.WriteAt(2,1,"Fast mode = ",DecToStr(button_3))
// approx delay times depending on clock speed (no timers are used)
If fakeBeat = 629 Then '5 sec delay
LCD.WriteAt(3,1,"nobeat timer = 5sec")
ElseIf fakeBeat = 1257 Then '10 sec delay
LCD.WriteAt(3,1,"nobeat timer = 10sec")
ElseIf fakeBeat = 1886 Then '15 sec delay
LCD.WriteAt(3,1,"nobeat timer = 15sec")
ElseIf fakeBeat = 2515 Then '20 sec delay
LCD.WriteAt(3,1,"nobeat timer = 20sec")
ElseIf fakeBeat = 3144 Then '25 sec delay
LCD.WriteAt(3,1,"nobeat timer = 25sec")
ElseIf fakeBeat = 3773 Then '30 sec delay
LCD.WriteAt(3,1,"nobeat timer = 30sec")
LCD.WriteAt(4,1,"Beat = ",DecToStr(beatCounter,3))
Case 3
LCD.WriteAt(1,1,"noBeat = ",DecToStr(noBeat,4))
LCD.WriteAt(2,1,"BPM Value = ",DecToStr(BPM_Interval,4))
LCD.WriteAt(3,1,"BPM = ",DecToStr(BPM_approx,3))
End Select
Sub checkColourButton()
// button5 changes color randomly and resets our colour changer
If button5 = 0 And buttonDelay = 0 Then
RandGen2.SetRndMax(8) // set MAX random gen value
colour = RandGen2.rand () // Get a random number
Select colour
Case 0 //
colourValue = white //
Case 1 //
colourValue = red //
Case 2 //
colourValue = multi //
Case 3 //
colourValue = magenta //
Case 4 // Select which colour to display
colourValue = green //
Case 5 //
colourValue = yellow //
Case 6 //
colourValue = blue //
Case 7 //
colourValue = pink //
Case 8 //
colourValue = cyan
End Select
colourChanger = 15 // reset our colour changer value
DMX_TX.DMX_Channel(2) = colourValue // set dmx channel 3 to colour value
Sub CHfunctionTest() // to test 16 channels using the pot to set values
While (button8 = 1) // exit button not pressed (Exit when pressed)
function_value = Get_ADC_Value // get our ADC value from channel 1
If button7 = 0 And buttonDelay = 0 And CHfunction >= 0 Then
Inc(CHfunction)
If button6 = 0 And buttonDelay = 0 And CHfunction <= 15 Then
Dec(CHfunction)
If CHfunction >= 16 Then
CHfunction = 0
ElseIf CHfunction <= -1 Then
CHfunction = 15
// adjust channel according to CHfunction value
Select CHfunction
Case 0
DMX_TX.DMX_Channel(0) = function_value
Case 1
DMX_TX.DMX_Channel(1) = function_value
Case 2
DMX_TX.DMX_Channel(2) = function_value
Case 3
DMX_TX.DMX_Channel(3) = function_value
Case 4
DMX_TX.DMX_Channel(4) = function_value
Case 5
DMX_TX.DMX_Channel(5) = function_value
Case 6
DMX_TX.DMX_Channel(6) = function_value
Case 7
DMX_TX.DMX_Channel(7) = function_value
Case 8
DMX_TX.DMX_Channel(8) = function_value
Case 9
DMX_TX.DMX_Channel(9) = function_value
Case 10
DMX_TX.DMX_Channel(10) = function_value
Case 11
DMX_TX.DMX_Channel(11) = function_value
Case 12
DMX_TX.DMX_Channel(12) = function_value
Case 13
DMX_TX.DMX_Channel(13) = function_value
Case 14
DMX_TX.DMX_Channel(14) = function_value
Case 15
DMX_TX.DMX_Channel(15) = function_value
End Select
If CHfunction >= 0 And CHfunction <= 7 Then
CHfunctionLCD = 0
Else
CHfunctionLCD = 1
Select CHfunctionLCD
Case 0
Case 1
LCD.WriteAt(1,1,"CH9 = ",DecToStr(DMX_TX.DMX_Channel(8),3)," CH13 = ",DecToStr(DMX_TX.DMX_Channel(12),3))
LCD.WriteAt(2,1,"CH10= ",DecToStr(DMX_TX.DMX_Channel(9),3)," CH14 = ",DecToStr(DMX_TX.DMX_Channel(13),3))
LCD.WriteAt(3,1,"CH11= ",DecToStr(DMX_TX.DMX_Channel(10),3)," CH15 = ",DecToStr(DMX_TX.DMX_Channel(14),3))
LCD.WriteAt(4,1,"CH12= ",DecToStr(DMX_TX.DMX_Channel(11),3)," CH16 = ",DecToStr(DMX_TX.DMX_Channel(15),3))
End Select
// Transmit all DMX packets
DMX_TX.DMX_Packets
Wend
Sub nobeatTimer() // no beat timer (if no beat then make fake beat)
noBeat = 1 // clear noBeat timer
DelayMS(200) // debounce buttons
LCD.Cls // clear LCD display
If button7 = 0 And buttonDelay = 0 And noBeat >= 1 Then
Inc(noBeat)
buttonDelay = 190 // need to debounce button
If button6 = 0 And buttonDelay = 0 And noBeat <= 6 Then
Dec(noBeat)
If noBeat >= 7 Then
noBeat = 1
ElseIf noBeat <= 0 Then
noBeat = 6
Select noBeat // approx delay times depending on clock speed (no timers are used)
Case 1 // 5 sec delay
fakeBeat = 629 '5 sec delay
LCD.WriteAt(1,1,"nobeat timer = 5sec")
Case 2 // 10 sec delay
fakeBeat = 1257 '10 sec delay
LCD.WriteAt(1,1,"nobeat timer = 10sec")
Case 3 // 15 sec delay
fakeBeat = 1886 '15 sec delay
LCD.WriteAt(1,1,"nobeat timer = 15sec")
Case 4 // 20 sec delay
fakeBeat = 2515 '20 sec delay
LCD.WriteAt(1,1,"nobeat timer = 20sec")
Case 5 // 25 sec delay
fakeBeat = 3144 '25 sec delay
LCD.WriteAt(1,1,"nobeat timer = 25sec")
Case 6 // 30 sec delay
fakeBeat = 3773 '30 sec delay
LCD.WriteAt(1,1,"nobeat timer = 30sec")
End Select
// Transmit all DMX packets (make sure we keep sending dmx packets)
DMX_TX.DMX_Packets
Wend
noBeat = 0 // clear noBeat timer
LCD.Cls // clears LCD display
// Delay for LCD ==================================
DelayMS(200) // Allow LCD to warm up
// Initialize Variables ==================================
colourChanger = 0
beatCounter = 0
beatDelay = 0
fakeBeat = 1257 '10 sec delay default
noBeat = fakeBeat
BPM_Interval = 0
BPM_approx = 0
trueBeat_Flag = 0
j = 0
secondBeat = false
// Set Colour Values
colour = 0
white = 0
red = 18
multi = 26
magenta = 34
green = 67
yellow = 83
blue = 99
pink = 115
cyan = 124
resetValue = 0
// DMX array setup
DMX_TX.DMX_Channel(3) = 16 // shutter = Open (ACME Light)
// Random Gen
range = 40
RandGen2.Initialize(2) // Initialize the Random Number generator.
RandGen2.SetRndMax(range) // Set random MAX number
button_1 = false // BlackOut Off
button_2 = false // Strobe off
button_3 = true // set fast mode
buttonDelay = 0 // button debounce
buttonDebounce = 80 // button debounce
menu_cycle = 0 // LCD menus
CHfunction = 0 //
// Main Program ==================================
While true
checkButtons // check buttons Or Debounce buttons
lcd_Update // update LCD Display
checkColourButton // check colour button to change colour (user input)
// button6 is set then use the Pot to operate CH function value
If button6 = 0 And buttonDelay = 0 Then
CHfunctionTest
If button7 = 0 And buttonDelay = 0 Then
DelayMS(200) // added button bounce
nobeatTimer
// Fast or Slow Function
range = 180
Else
range = 80
RandGen2.SetRndMax(range) // set MAX random gen value
If beatInput = 1 And beatDelay = 0 Or noBeat = 0 Then
If noBeat = 0 Then // test to see if no beat
range = 60 // set range low (motors etc slow)
colourChanger = 0 // change colour
trueBeat_Flag = 0 // stop true beat counter
BPM_Interval = 0 // reset true beat counter
BPM_approx = 0 // reset BPM
secondBeat = false
Else
trueBeat_Flag = 1 // if beat is a true beat (turn on beat counter)
// BPM counter (First beat bpm interval counter set, second beat set j = bpm interval
// third beat bpm approx updated and then updated every beat after unless no beat then all reset)
If secondBeat = true And j = 0 Then
j = BPM_Interval // on second beat
ElseIf secondBeat = true Then // on third beat and then every beat after (unless no beat)
j = ((j * 7) + BPM_Interval) / 8 // get average value based on 8
BPM_approx = ((60 * 103) / j) //
BPM_Interval = 0 // reset beat interval counter
Else
secondBeat = true // on first beat
noBeat = fakeBeat // reset our no beat value
barrelPos = RandGen2.rand () // Get a random number
barrelPos = 128 + ((barrelPos) - (range / 2) ) // set barrel pos depending on our range
DMX_TX.DMX_Channel(0) = barrelPos // set channel with value
barrelSpeed = RandGen2.rand () // Get a random number
barrelSpeed = 128 + ((barrelSpeed) - (range / 2) ) // set barrel speed depending on our range
DMX_TX.DMX_Channel(1) = barrelSpeed // set channel with value
If colourChanger <= 0 Then
Select colour
Case 0 //
Case 1 //
Case 2 //
Case 3 //
Case 5 //
Case 6 //
Case 7 //
Case 8 //
colourValue = cyan
End Select
Dec(colourChanger) // Decrease our colour changer value
Inc(beatCounter) // Increase our beat counter value
If beatCounter >= 200 Then // Reset out beat counter
beatCounter = 0
beatDelay = 40 // set our delay beat detector to help stop false beats
// true beat counter (counter starts after first beat)
If trueBeat_Flag = 1 Then
Inc(BPM_Interval)
If BPM_Interval = 200 Then
BPM_Interval = 0
// Transmit BlackOut DMX Packet
DelayMS(300) // debounce our button
LCD.WriteAt(1,1,"BlackOut Active")
Repeat
DMX_TX.DMX_BlackOut
If button1 = 0 Then // check our button
button_1 = false
Until button_1 = false
buttonDelay = buttonDebounce // need to debounce button1
// reset all DMX channels
For i = 0 To Bound(DMX_TX.DMX_Channel)
DMX_TX.DMX_Channel(i) = 128
If i = 3 Then
Next
Else
DMX_TX.DMX_Packets
// Strobe Function Set (operational ONLY when button is pressed and held)
If button2 = 0 Then
LCD.WriteAt(1,1,"Strobe")
resetValue = DMX_TX.DMX_Channel(2) // store our dmx channel 3 data
RandGen2.SetRndMax(255) // set MAX random gen value
DMX_TX.DMX_Channel(2) = 255 // set our dmx channel 3 to strobe setting
Repeat
DMX_TX.DMX_Channel(0) = RandGen2.rand () // Get a random number
DMX_TX.DMX_4Channel (DMX_Channel(0),DMX_Channel(1),DMX_Channel(2),255) 'DMX_4Channel
Until button2 = 1
DMX_TX.DMX_Channel(2) = resetValue // we need to reset our dmx channel back to the original data
beat_delay // decrease beat delay (help stop false beats)
Wend
Re: DMX Controller
Don't you love it when you have that much code and it actually works!
Re: DMX Controller
Your spot on there Brad!.. dont think ive used this many variables or program memory before!!..
- odessa
Re: DMX Controller
Ace project matey
Where do you get the connectors from that you use on your board Gav ?
The 2/4 way one that connect the pots etc to the PCB .. what are they called ?
Cheers
Jay
Cheers
Jay
(\_/)
Re: DMX Controller
Thank you Jay
I got them from ebay, from this seller
They are called Header connectors.
not sure if hes got any 4 way headers on there at the moment?.
http://cgi.ebay.co.uk/5x-3-Way-Latching ... 1e61f6cb96
Re: DMX Controller
I am looking to make some PCB's which will be for a large LED display. I want to be able to connect multiple boards together, so connectors like these might be the answer...
- odessa
Re: DMX Controller
Thanks Gav, bought a selection of them.
Much better than plain old headers !
Jay
Jay
(\_/)
Re: DMX Controller
No Problems to you both
They are perfect headers with a plastic latch to keep the connector in place and with a good 0.1″ (2.54mm) pitch.
