Adapters and other odd and end parts
- decided to stick around...
- Joined: Sun Mar 28, 2010 1:27 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
http://www.proto-advantage.com/store/ has several handy adapters that I found I would share with all of you.
Re: Adapters and other odd and end parts
Very nice Digg, those SMD to DIP adapters would be quite handy for breadboarding.
I haven't really studied their prices but I like what I see.
Are there any adapters that would accept the two main Microchips that this site advocates? One of them is the pic16f628a / pic16f648a microcontroller.
The 16f series I have been using are just the standard DIP versions so so you wouldnt need the adapters, but the larger 18f series would be handy to have an adapter because the ones I use are 40 pin
