24x24 led matrix
Post by brad » Thu Sep 09, 2010 10:19 pm
It's just crazy isn't it!
Such a time saver - it allows you to get on with your program without having to worry about all the little bits and pieces that really can take up alot of time.
Post by bitfogav » Fri Sep 10, 2010 9:28 am
brad wrote:It's just crazy isn't it!
Brad I need some help with this?
    temp_byte = %00000000
    For k = 0 To 7
        Select k
        Case 0
            Select random_gen_line(k)
                Case 1
                    temp_byte = temp_byte Or %10000000
            EndSelect
        Case 1
                Case 1
                    temp_byte = temp_byte Or %01000000
            EndSelect
        Case 2
                Case 1
                    temp_byte = temp_byte Or %00100000
            EndSelect
        Case 3
                Case 1
                    temp_byte = temp_byte Or %00010000
            EndSelect
        Case 4
                Case 1
                    temp_byte = temp_byte Or %00001000
            EndSelect
        Case 5
                Case 1
                    temp_byte = temp_byte Or %00000100
            EndSelect
        Case 6
                Case 1
                    temp_byte = temp_byte Or %00000010
            EndSelect
        Case 7
                Case 1
                    temp_byte = temp_byte Or %00000001
            EndSelect
        EndSelect
    Next
    left_block_new_road_line = temp_byte
Im trying to check each bit of a byte and this is the only way I could do it, there must be a easier way? what do you think?
random_gen_line as been declared as
dim random_gen_line (8) as bit
Post by brad » Fri Sep 10, 2010 3:38 pm
Hmm, you really are going about that in an interesting way!
from what I can see, you are checking to see if a certain bit is set in random_gen_line. if it is set, then you set a certain bit in temp_byte. The bit you set seems to be opposite to what you are checking I.E. if you check bit 0 you will then set bit 7, if you check bit 1 you then set bit 6 etc...
However if you just want to set the same bit that you check then it can be as simple as this:
temp_byte = random_gen_line
You could also do this sort of thing which may help you:
temp byte = 0
for x = 0 to 7
     if random_gen_line.bits(x) = 1 then
          temp_byte.bits(x) = 1
next
Or I may be missing your point totally - if so then let me know!
Post by bitfogav » Sat Sep 11, 2010 2:48 am
This is abit weird :?
I have tried your bit of code Brad and for some reason my swordfish ide locksup, if I remove your bit of code it works fine :?
temp_byte = 0
for x = 0 to 7
     endif
next
I have changed your code slightly to the code above.
Post by bitfogav » Sat Sep 11, 2010 3:44 am
I think ive got a solution Brad,
The bit of code
well random_gen_line has already been declared as a bit for example:
so I changed it to this:
	For k = 0 To 7
			If random_gen_line(k) = 1 Then
			   temp_byte.bits(k) = 1
	Next
It works but like you said before I need the bits in the byte tobe opposite, for example if you check bit 0 you will then set bit 7, if you check bit 1 you then set bit 6 etc...
Post by brad » Sat Sep 11, 2010 8:15 pm
Oops! I forgot that you had declared it as eight separate bits (in an array)
To fix your other problem, I guess you could do this:
temp byte = 0
for x = 0 to 7
          select x
               case 0
                    temp_byte.bits(7) = 1
               case 1
                    temp_byte.bits(6) = 1
               case 2
                    temp_byte.bits(5) = 1
               case 3
                    temp_byte.bits(4) = 1
               case 4
                    temp_byte.bits(3) = 1
               case 5
                    temp_byte.bits(2) = 1
               case 6
                    temp_byte.bits(1) = 1
               case 7
                    temp_byte.bits(0) = 1
          EndSelect
     Endif
next
It first checks to see if a particular bit is a logic 1, it then uses case statements to set your required bit in temp_byte
Post by bitfogav » Sat Sep 11, 2010 8:59 pm
That looks spot on Brad, I will give it ago today in my program.
I think you would be very interested in what this bit of code does, I am actually drawing a random road across 24 bits which equals one row on my matrix, this bit of code is used to draw just 8 bits of my 24 bits (which is one 8x8 matrix), so I might have to copy and paste this piece of code 3 times in my program to cover all 24bits.
I am also using the random generator that cames on the user modules on digital.diy.com to generate my random road data.
Post by brad » Sun Sep 12, 2010 8:35 pm
Great idea, so does that mean that the track is just about always different because it draws different bits and pieces here and there?
Post by bitfogav » Sun Sep 12, 2010 9:52 pm
brad wrote:Great idea, so does that mean that the track is just about always different because it draws different bits and pieces here and there?
Yes Brad that is the idea :)
Heres a video of the random track, its also setup to check the distance between left and right track datas and then if left track and right track data is a certain distance apart it will draw two lanes. I have also reworked the Car controls to cover all the matrix's with crash detection included, I have crashed the car in the video to show you how it works and pauses the track to show where you crashed, it then restarts the game :)
I have ran into abit of a problem though, the random generator will draw the track randomly for quite awhile and then it gets into a fixed loop where it keeps drawing the same piece of track, I have tried serveral random primary numbers to initialise the random generator but it still gets into a fixed loop. If anyone has any ideas that would be greatful, or it might be a case of creating a better random generator.
http://www.youtube.com/watch?v=-HPgRdKGlbo
Post by brad » Tue Sep 14, 2010 6:16 am
I cant get too much into it now because I am running late for work, but I have come up with the most basic way of generating a random number. And it really is random!
it involves an LED believe it or not to generate the random number. Will post full details after work...
By the way - cool video!
Post by bitfogav » Tue Sep 14, 2010 6:25 am
brad wrote:I cant get too much into it now because I am running late for work, but I have come up with the most basic way of generating a random number. And it really is random!
Thanks buddy.. you say an LED to generate a random number? has this got something to do with using an LED as a sensor? hehe :)
