24x24 led matrix
Post by bitfogav » Wed Aug 25, 2010 10:22 am
After many hours I have almost finished building the 24x24 matrix.
Heres a video of its first test, sorry for the poor quality.
http://www.youtube.com/watch?v=IJGwNGdy8MM
Post by bitfogav » Thu Aug 26, 2010 12:31 am
Carrying out further tests today on the matrix, had one GREEN led not working, found the fault to a small bit of solder touching the circuits, dont think thats bad for 280 solder joints just on the Matrix board itself hehe! :)
My first power board had 24 transistors BC-635 (1amp), but I found these
didnt work correctly, they would not display the colour Orange (this is done by turning green and red leds on at the same time, so I used some 2N2222 (800ma) this made the matrix dimmer, obviously as they are lower amperage output.
So I have now gone for some MPSA14 (1.2amp) transistors :)
Post by bitfogav » Thu Aug 26, 2010 3:27 am
Heres another test video with the new transistors.
http://www.youtube.com/watch?v=YcCZicRXxl0
And Heres the swordfish code - it is just something ive put together to test the matrix. :)
// Name of Program
Program Led_Grid_Matrix  // useful for documentation purposes
// Device and Clock
Device = 18F4685         // Tell the compiler what chip we are using
Clock = 20               // Tell the compiler what we will be setting the clock to (Mhz)
    Config MCLRE = ON
    // default fuses...
Config
   OSC = HS,
   FCMEN = OFF,
   IESO = OFF,
   PWRT = ON,
   BOREN = BOACTIVE,
   WDT = OFF,
   WDTPS = 128,
   PBADEN = OFF,
   DEBUG = OFF,
   XINST = OFF,
   LVP = OFF,
   STVREN = ON
// Modules
Include "Utils.bas"      // Include this file when we compile so that we can use keywords like "SetAllDigital"
// Const Arrays
// Anodes if we are using ULN2803 Chips (common-cathode Darlington transistor array.)
Const Anode_data(8) As Byte = (%10000000,%01000000,%00100000,%00010000,%00001000,%00000100,%00000010,%00000001)
// use this line to invert the Anodes
'Const Anode_data(8) As Byte = (%00000001,%00000010,%00000100,%00001000,%00010000,%00100000,%01000000,%10000000)
// Setup ALL our PORTS
Dim E_ALL_74573 As PORTC.6               ' setup ALL 74573 enable pins
Dim L_RedB0_74573 As PORTC.4              ' setup our RED CATHODE 74573 latch pin
Dim L_RedB1_74573 As PORTC.0              ' setup our RED CATHODE 74573 latch pin
Dim L_RedB2_74573 As PORTC.1              ' setup our RED CATHODE 74573 latch pin
Dim L_GreenB0_74573 As PORTC.2            ' setup our GREEN CATHODE 74573 latch pin
Dim L_GreenB1_74573 As PORTC.3            ' setup our GREEN CATHODE 74573 latch pin
Dim L_GreenB2_74573 As PORTC.5            ' setup our GREEN CATHODE 74573 latch pin
Dim L_AnodeR0_74573 As PORTE.0            ' setup our ANODE 74573 latch pin
Dim L_AnodeR1_74573 As PORTE.1            ' setup our ANODE 74573 latch pin
Dim L_AnodeR2_74573 As PORTE.2            ' setup our ANODE 74573 latch pin
Dim Anode_port As PORTB                   ' Anode DATA PORT
Dim Graphic_port As PORTD                 ' Graphic DATA PORT (green and red)
' when latch pin = high then data can be latched, when latch pin = low data cannot be stored
' when enable pin = high outputs OFF, when enable pin = low outputs ON
// Variable Declarations
Dim x As Byte
Dim t As Byte
Dim counter As Word
Dim start_counter As Word
Dim block_0_green(8) As Byte
Dim block_0_red(8) As Byte
Dim display_step As Word
// Subroutines ====
Sub update_ram_data()
    Select display_step
        Case 0     ' RED screen
            block_0_red(0) = $ff
            block_0_red(1) = $ff
            block_0_red(2) = $ff
            block_0_red(3) = $ff
            block_0_red(4) = $ff
            block_0_red(5) = $ff
            block_0_red(6) = $ff
            block_0_red(7) = $ff
            block_0_green(0) = $00
            block_0_green(1) = $00
            block_0_green(2) = $00
            block_0_green(3) = $00
            block_0_green(4) = $00
            block_0_green(5) = $00
            block_0_green(6) = $00
            block_0_green(7) = $00
       Case 1       ' ORANGE screen
            block_0_green(0) = $ff
            block_0_green(1) = $ff
            block_0_green(2) = $ff
            block_0_green(3) = $ff
            block_0_green(4) = $ff
            block_0_green(5) = $ff
            block_0_green(6) = $ff
            block_0_green(7) = $ff
       Case 2         ' GREEN screen
            block_0_red(0) = $00
            block_0_red(1) = $00
            block_0_red(2) = $00
            block_0_red(3) = $00
            block_0_red(4) = $00
            block_0_red(5) = $00
            block_0_red(6) = $00
            block_0_red(7) = $00
        Case 3    ' BLACK screen
    EndSelect
            // this is our count of frames
            // increment by 1
        display_step = display_step + 1
            // if we get to end, reset to 0
    If display_step = 4 Then    ' change the number of steps
        display_step = 0
    High (E_ALL_74573)  ' makes enable pin high (all outputs OFF)
        For t = 0 To 250  // 250 = time delay
            For x = 0 To 7
            ' make sure all our data latches are closed
             Low    (L_RedB0_74573)               ' setup our RED CATHODE 74573 latch pin
             Low    (L_RedB1_74573)               ' setup our RED CATHODE 74573 latch pin
             Low    (L_RedB2_74573)               ' setup our RED CATHODE 74573 latch pin
             Low    (L_GreenB0_74573)             ' setup our GREEN CATHODE 74573 latch pin
             Low    (L_GreenB1_74573)             ' setup our GREEN CATHODE 74573 latch pin
             Low    (L_GreenB2_74573)             ' setup our GREEN CATHODE 74573 latch pin
             Low    (L_AnodeR0_74573)             ' setup our ANODE 74573 latch pin
             Low    (L_AnodeR1_74573)             ' setup our ANODE 74573 latch pin
             Low    (L_AnodeR2_74573)             ' setup our ANODE 74573 latch pin
            ' green data
             High   (L_GreenB0_74573)             ' setup our GREEN CATHODE 74573 latch pin
             High   (L_GreenB1_74573)             ' setup our GREEN CATHODE 74573 latch pin
             High   (L_GreenB2_74573)             ' setup our GREEN CATHODE 74573 latch pin
                Graphic_port = block_0_green(x)
             ' red data
             High   (L_RedB0_74573)               ' setup our RED CATHODE 74573 latch pin
             High   (L_RedB1_74573)               ' setup our RED CATHODE 74573 latch pin
             High   (L_RedB2_74573)               ' setup our RED CATHODE 74573 latch pin
                Graphic_port = block_0_red(x)
             ' anodes data
             High   (L_AnodeR0_74573)           ' setup our ANODE 74573 latch pin
             High   (L_AnodeR1_74573)           ' setup our ANODE 74573 latch pin
             High   (L_AnodeR2_74573)           ' setup our ANODE 74573 latch pin
                Anode_port = Anode_data (x)
             ' Enable our Matrix
             Low    (E_ALL_74573)  ' makes enable pin low (all outputs ON)
                DelayMS(2)
            Next
            Inc(t)
        Next
// Set Ports
SetAllDigital       // Make all Pins digital I/O's
TRISA = %11111111   // Make PORTA all inputs
TRISB = %00000000   // Make PORTB all outputs
TRISC = %00000000   // Make PORTC all outputs
TRISD = %00000000   // Make PORTD all outputs
TRISE = %00000000   // Make PORTE all outputs
    PORTB = $00      ' clear all ports
    PORTC = $00
    PORTD = $00
    PORTE = $00
    // this clears all data in all 74573 data latches
        // and this makes all outputs off
// Initialize Variables
counter = 0
start_counter = 0
display_step = 0
// Main Program
While True()
          update_ram_data
Wend
// end of program.
End
Post by brad » Thu Aug 26, 2010 10:39 pm
Nice videos bitfogav, Isn't it great to see something happen for the first time after spending hours on a circuit :)
Am keen to see where this one goes - and would like to contribute code where I can also.
Post by bitfogav » Thu Aug 26, 2010 10:45 pm
brad wrote:Nice videos bitfogav, Isn't it great to see something happen for the first time after spending hours on a circuit :)
Yeah its great seeing it working :) I was up late last night just seeing what I could with it, I will post more videos etc and make some animations but Im going away for a few days :(
Ill defo need some contribution with some code when I get to possible transfer your pac-mac game to it or something? :)
Post by brad » Thu Aug 26, 2010 10:51 pm
That's a great idea about pacman!
you could play it all on the one screen without the screen having to scroll.
Will certainly have to port the code over to the new screen :)
Post by bitfogav » Sat Sep 04, 2010 7:07 pm
brad wrote:That's a great idea about pacman!
Well thanks to you Brad and seeing your NES control pad on one of the other forum threads I have now fitted a Control Pad Port to my 24x24 microchip board, this will easily give me 8 buttons from just 3 data lines, Ive actually connected all six I/O PORTA pins to the Control Pad Port for future hardware applications and also have a 5+volt and GND supply.
I have also looked into using a Playstation Control Pad, some of them have a Dual Shock control, which vibrates the control pad when it is powered up by a 9volt supply only on one of the connector lines, so imagine a racing car game where you hit another car or a wall and it vibrates your Control Pad :)
microchip board edited.jpg (80.52 KiB) Viewed 23002 times
Post by brad » Sat Sep 04, 2010 7:51 pm
Man that is a cool looking board, nice and neat :)
The NES controller works perfectly, there's never any hiccups - just a few lines of code and it's all good to go!
Post by bitfogav » Sat Sep 04, 2010 8:13 pm
brad wrote:Man that is a cool looking board, nice and neat :)
Thanks Buddy :) im almost ready to give my NES controller a go..
heres a pic of the NES controller connected and my microchip board made up, oh and with my PicKit2 connected.
micro board with nes.jpg (47.03 KiB) Viewed 22995 times
Post by bitfogav » Sun Sep 05, 2010 5:12 am
Heres a NEW video of the matrix
http://www.youtube.com/watch?v=VNQIBaPECC0
Thanks to Brad ive have been able to connect a NES control pad to this project quite easily and I have made a Race Car game which you could also say is based on one of Brads games. the game is still in the early stages so its pretty basic. but I am very impressed with the NES control pad!..
You might also see the fully working contol boards that Ive also made up to control the matrix in the video.
Heres the Full Code
// Name of Program
Program Rolling_Road  // useful for documentation purposes
// Device and Clock
Config MCLRE = ON
    // default fuses...
Config
   OSC = HS,
   FCMEN = OFF,
   IESO = OFF,
   PWRT = ON,
   BOREN = BOACTIVE,
   WDT = OFF,
   WDTPS = 128,
   PBADEN = OFF,
   DEBUG = OFF,
   XINST = OFF,
   LVP = OFF,
   STVREN = ON
// Modules
// Const Arrays
// Control Pad Port Setup and Flag bits
Dim nes_data As PORTA.0
Dim nes_latch As PORTA.1
Dim nes_clock As PORTA.2
Dim nes_flags As Byte
Dim nes_a As nes_flags.0
Dim nes_b As nes_flags.1
Dim nes_select As nes_flags.2
Dim nes_start As nes_flags.3
Dim nes_up As nes_flags.4
Dim nes_down As nes_flags.5
Dim nes_left As nes_flags.6
Dim nes_right As nes_flags.7
Dim x As Byte
Dim t As Word
Dim counter As Word
Dim block_1_green(8) As Byte
Dim block_1_red(8) As Byte
Dim block_2_green(8) As Byte
Dim block_2_red(8) As Byte
Dim block_3_green(8) As Byte
Dim block_3_red(8) As Byte
Dim block_4_green(8) As Byte
Dim block_4_red(8) As Byte
Dim block_5_green(8) As Byte
Dim block_5_red(8) As Byte
Dim block_6_green(8) As Byte
Dim block_6_red(8) As Byte
Dim block_7_green(8) As Byte
Dim block_7_red(8) As Byte
Dim block_8_green(8) As Byte
Dim block_8_red(8) As Byte
Dim button_debounce As Byte
Dim car_position As Byte
Dim hit_data As Byte
// Subroutines ====
Sub road_data()
    Select display_step
        Case 0
                    ' we need to initialize RED even though we are only using block7 row 6-7
                    block_1_red(0) = $00
                    block_1_red(1) = $00
                    block_1_red(2) = $00
                    block_1_red(3) = $00
                    block_1_red(4) = $00
                    block_1_red(5) = $00
                    block_1_red(6) = $00
                    block_1_red(7) = $00
                    block_2_red(0) = $00
                    block_2_red(1) = $00
                    block_2_red(2) = $00
                    block_2_red(3) = $00
                    block_2_red(4) = $00
                    block_2_red(5) = $00
                    block_2_red(6) = $00
                    block_2_red(7) = $00
                    block_3_red(0) = $00
                    block_3_red(1) = $00
                    block_3_red(2) = $00
                    block_3_red(3) = $00
                    block_3_red(4) = $00
                    block_3_red(5) = $00
                    block_3_red(6) = $00
                    block_3_red(7) = $00
                    block_4_red(0) = $00
                    block_4_red(1) = $00
                    block_4_red(2) = $00
                    block_4_red(3) = $00
                    block_4_red(4) = $00
                    block_4_red(5) = $00
                    block_4_red(6) = $00
                    block_4_red(7) = $00
                    block_5_red(0) = $00
                    block_5_red(1) = $00
                    block_5_red(2) = $00
                    block_5_red(3) = $00
                    block_5_red(4) = $00
                    block_5_red(5) = $00
                    block_5_red(6) = $00
                    block_5_red(7) = $00
                    block_6_red(0) = $00
                    block_6_red(1) = $00
                    block_6_red(2) = $00
                    block_6_red(3) = $00
                    block_6_red(4) = $00
                    block_6_red(5) = $00
                    block_6_red(6) = $00
                    block_6_red(7) = $00
                    block_7_red(0) = $00
                    block_7_red(1) = $00
                    block_7_red(2) = $00
                    block_7_red(3) = $00
                    block_7_red(4) = $00
                    block_7_red(5) = $00
'                   block_7_red(6) = %00001000     ' check car position
                    block_7_red(7) = $00
                    block_8_red(0) = $00
                    block_8_red(1) = $00
                    block_8_red(2) = $00
                    block_8_red(3) = $00
                    block_8_red(4) = $00
                    block_8_red(5) = $00
                    block_8_red(6) = $00
                    block_8_red(7) = $00
            block_0_green(0) = %11111111
            block_0_green(1) = %11111111
            block_0_green(2) = %11111111
            block_0_green(3) = %11111111
            block_0_green(4) = %11111111
            block_0_green(5) = %11111111
            block_0_green(6) = %11111111
            block_0_green(7) = %11111111
            block_1_green(0) = %11110000
            block_1_green(1) = %11110000
            block_1_green(2) = %11000000
            block_1_green(3) = %11000000
            block_1_green(4) = %10000001
            block_1_green(5) = %00000001
            block_1_green(6) = %00000011
            block_1_green(7) = %00000011
            block_2_green(0) = %01111111
            block_2_green(1) = %01111111
            block_2_green(2) = %01111111
            block_2_green(3) = %11111111
            block_2_green(4) = %11111111
            block_2_green(5) = %11111111
            block_2_green(6) = %11111111
            block_2_green(7) = %11111111
            block_3_green(0) = %11111111
            block_3_green(1) = %11111111
            block_3_green(2) = %11111111
            block_3_green(3) = %11111111
            block_3_green(4) = %11111111
            block_3_green(5) = %11111111
            block_3_green(6) = %11111111
            block_3_green(7) = %11111111
            block_4_green(0) = %00000011
            block_4_green(1) = %10000011
            block_4_green(2) = %10000011
            block_4_green(3) = %10000001
            block_4_green(4) = %11000001
            block_4_green(5) = %11000001
            block_4_green(6) = %11000001
            block_4_green(7) = %10000001
            block_5_green(0) = %11111111
            block_5_green(1) = %11111111
            block_5_green(2) = %11111111
            block_5_green(3) = %11111111
            block_5_green(4) = %11111111
            block_5_green(5) = %11111111
            block_5_green(6) = %11111111
            block_5_green(7) = %11111111
            block_6_green(0) = %11111111
            block_6_green(1) = %11111111
            block_6_green(2) = %11111111
            block_6_green(3) = %11111111
            block_6_green(4) = %11111111
            block_6_green(5) = %11111111
            block_6_green(6) = %11111111
            block_6_green(7) = %11111111
            block_7_green(0) = %10000001
            block_7_green(1) = %00000011
            block_7_green(2) = %00000011
            block_7_green(3) = %00000011
            block_7_green(4) = %00000011
            block_7_green(5) = %10000011
            block_7_green(6) = %10000001
            block_7_green(7) = %11000000
            block_8_green(0) = %11111111
            block_8_green(1) = %11111111
            block_8_green(2) = %11111111
            block_8_green(3) = %11111111
            block_8_green(4) = %11111111
            block_8_green(5) = %11111111
            block_8_green(6) = %11111111
            block_8_green(7) = %11111111
        Case 1
            block_1_green(0) = %11000000
            block_1_green(2) = %11110000
            block_1_green(4) = %11000000
            block_1_green(5) = %10000001
            block_1_green(6) = %00000001
            block_2_green(0) = %11111111
            block_2_green(3) = %01111111
            block_4_green(1) = %00000011
            block_4_green(3) = %10000011
            block_4_green(4) = %10000001
            block_4_green(7) = %11000001
            block_7_green(1) = %10000001
            block_7_green(5) = %00000011
            block_7_green(6) = %10000011
            block_7_green(7) = %10000001
        Case 2
            block_1_green(0) = %10000001
            block_1_green(1) = %11000000
            block_1_green(3) = %11110000
            block_1_green(5) = %11000000
            block_1_green(6) = %10000001
            block_1_green(7) = %00000001
            block_2_green(1) = %11111111
            block_2_green(4) = %01111111
            block_4_green(2) = %00000011
            block_4_green(4) = %10000011
            block_4_green(5) = %10000001
            block_7_green(0) = %11000001
            block_7_green(2) = %10000001
            block_7_green(6) = %00000011
            block_7_green(7) = %10000011
        Case 3
            block_1_green(0) = %10000011
            block_1_green(1) = %10000001
            block_1_green(4) = %11110000
            block_1_green(6) = %11000000
            block_1_green(7) = %10000001
            block_2_green(2) = %11111111
            block_2_green(5) = %01111111
            block_4_green(0) = %00000001
            block_4_green(3) = %00000011
            block_4_green(5) = %10000011
            block_4_green(6) = %10000001
            block_7_green(1) = %11000001
            block_7_green(3) = %10000001
            block_7_green(7) = %00000011
        Case 4
        block_1_green(0) = %00000011
        block_1_green(1) = %10000011
        block_1_green(2) = %10000001
        block_1_green(5) = %11110000
        block_1_green(7) = %11000000
        block_2_green(6) = %01111111
        block_4_green(0) = %10000001
        block_4_green(1) = %00000001
        block_4_green(4) = %00000011
        block_4_green(6) = %10000011
        block_7_green(2) = %11000001
        block_7_green(4) = %10000001
        Case 5
        block_1_green(1) = %00000011
        block_1_green(2) = %10000011
        block_1_green(3) = %10000001
        block_1_green(6) = %11110000
        block_2_green(7) = %01111111
        block_4_green(0) = %11000000
        block_4_green(1) = %10000001
        block_4_green(2) = %00000001
        block_4_green(5) = %00000011
        block_4_green(7) = %10000011
        block_7_green(3) = %11000001
        block_7_green(5) = %10000001
        Case 6
        block_1_green(2) = %00000011
        block_1_green(3) = %10000011
        block_1_green(7) = %11110000
        block_4_green(1) = %11000000
        block_4_green(2) = %10000001
        block_4_green(3) = %00000001
        block_4_green(6) = %00000011
        block_5_green(0) = %01111111
        block_7_green(0) = %10000011
        block_7_green(4) = %11000001
        Case 7
        block_1_green(3) = %00000011
        block_1_green(4) = %10000011
        block_4_green(0) = %11110000
        block_4_green(2) = %11000000
        block_4_green(4) = %00000001
        block_4_green(7) = %00000011
        block_5_green(1) = %01111111
        block_7_green(1) = %10000011
        block_7_green(5) = %11000001
        Case 8
        block_1_green(4) = %00000011
        block_1_green(5) = %10000011
        block_4_green(1) = %11110000
        block_4_green(3) = %11000000
        block_4_green(5) = %00000001
        block_5_green(2) = %01111111
        block_7_green(0) = %00000011
        block_7_green(2) = %10000011
        block_7_green(6) = %11000001
        Case 9
        block_1_green(5) = %00000011
        block_1_green(6) = %10000011
        block_4_green(2) = %11110000
        block_4_green(4) = %11000000
        block_4_green(6) = %00000001
        block_5_green(3) = %01111111
        block_7_green(3) = %10000011
        block_7_green(7) = %11000001
        Case 10
        block_1_green(0) = %11000001
        block_1_green(7) = %10000011
        block_4_green(3) = %11110000
        block_4_green(5) = %11000000
        block_4_green(7) = %00000001
        block_5_green(4) = %01111111
        block_7_green(4) = %10000011
        Case 11
        block_1_green(1) = %11000001
        block_4_green(0) = %10000011
        block_4_green(4) = %11110000
        block_4_green(6) = %11000000
        block_5_green(5) = %01111111
        block_7_green(0) = %00000001
        Case 12
        block_1_green(2) = %11000001
        block_4_green(5) = %11110000
        block_4_green(7) = %11000000
        block_5_green(6) = %01111111
        block_7_green(1) = %00000001
        Case 13
        block_1_green(3) = %11000001
        block_4_green(6) = %11110000
        block_5_green(7) = %01111111
        block_7_green(0) = %11000000
        block_7_green(2) = %00000001
        Case 14
        block_1_green(4) = %11000001
        block_4_green(7) = %11110000
        block_7_green(1) = %11000000
        block_7_green(3) = %00000001
        block_8_green(0) = %01111111
        Case 15
        block_1_green(5) = %11000001
        block_7_green(0) = %11110000
        block_7_green(2) = %11000000
        block_7_green(4) = %00000001
        block_8_green(1) = %01111111
        Case 16
        block_1_green(6) = %11000001
        block_7_green(1) = %11110000
        block_7_green(3) = %11000000
        block_7_green(5) = %00000001
        block_8_green(2) = %01111111
        Case 17
        block_1_green(7) = %11000001
        block_7_green(2) = %11110000
        block_7_green(4) = %11000000
        block_7_green(6) = %00000001
        block_8_green(3) = %01111111
        Case 18
        block_4_green(0) = %11000001
        block_7_green(3) = %11110000
        block_7_green(5) = %11000000
        block_7_green(7) = %00000001
        block_8_green(4) = %01111111
        Case 19
        block_1_green(0) = %00000001
        block_4_green(1) = %11000001
        block_7_green(4) = %11110000
        block_7_green(6) = %11000000
        block_8_green(5) = %01111111
        Case 20
        block_1_green(1) = %00000001
        block_4_green(2) = %11000001
        block_7_green(5) = %11110000
        block_8_green(6) = %01111111
        Case 21
        block_1_green(2) = %00000001
        block_4_green(3) = %11000001
        block_7_green(6) = %11110000
        block_8_green(7) = %01111111
        Case 22
        block_1_green(3) = %00000001
        block_7_green(7) = %11110000
        Case 23
        block_1_green(4) = %00000001
        Case 24
       EndSelect
            // increment by 1
    If display_step = 24 Then    ' change the number of steps
        display_step = 0
        For t = 0 To 25  // t = time delay
              For x = 0 To 7
        ' red data
                Graphic_port = block_3_red(x)
                Graphic_port = block_6_red(x)
        ' green data
                Graphic_port = block_3_green(x)
                Graphic_port = block_6_green(x)
        ' anodes data
                Anode_port = $00
        ' Enable our Matrix
                DelayUS(400)
             ' we now clear our Anode data to stop graphic ghosting
                Anode_port = $00
        ' red data
                Graphic_port = block_1_red(x)
                Graphic_port = block_4_red(x)
                Graphic_port = block_7_red(x)
        ' green data
                Graphic_port = block_1_green(x)
                Graphic_port = block_4_green(x)
                Graphic_port = block_7_green(x)
        ' anodes data
                Anode_port = $00
        ' Enable our Matrix
                DelayUS(400)
                Anode_port = $00
        ' red data
                Graphic_port = block_2_red(x)
                Graphic_port = block_5_red(x)
                 Graphic_port = block_8_red(x)
       ' green data
                Graphic_port = block_2_green(x)
                Graphic_port = block_5_green(x)
                Graphic_port = block_8_green(x)
       ' anodes data
                Anode_port = $00
       ' Enable our Matrix
                DelayUS(400)
                Anode_port = $00
            Next
              Inc(t)
        Next
// Check NES control Pad Data
Sub check_control_pad()
    nes_latch = 1      // grab the state of the buttons
    nes_latch = 0      // by giving a positive edge to the latch enable
    For x = 0 To 7
        nes_flags.bits(x) = nes_data    // the first bit (button a) will be shown on the nes_data pin, we read it,
        nes_clock = 1                   // then clock through the remaining 7 bits to check the state of all buttons.
        nes_clock = 0
    Next
// Check which button pressed
Sub check_buttons()
 ' check left button
    If button_debounce = 0 And nes_left = 0 And car_position <> 128 Then   // <> 128 is MSB bit 7
        car_position = car_position << 1
         button_debounce = 5
 ' check right button
    If button_debounce = 0 And nes_right = 0 And car_position <> 1 Then    // <1>> 1
         button_debounce = 5
// Debounce for buttons
Sub debounce_buttons()               // here we debounce buttons for the control pad
    If button_debounce <> 0 Then
        Dec(button_debounce)
// Stores Car Position for Display
Sub car_data ()
     block_7_red(6) = car_position      // this updates our car position to draw on display
// stores Road data
Sub hit_data_update ()
     hit_data = block_7_green(6)
// check to see if the Car has crashed (hit a wall)
Sub collision_detect ()
Dim result As Byte
       result = 0
        result = car_position And hit_data
      If result <> 0 Then
        display_step = 0            // this resets the road data
        car_position = %00001000    // this resets the car to the start position
// Set Ports
TRISA = %111001     // Make PORTA all inputs   NES control pad = RA0 Data input, RA1-RA2 Latch and Clock are outputs.
TRISE = %000        // Make PORTE all outputs
    PORTC = $00
    PORTD = $00
    PORTE = $00
counter = 0
display_step = 0
nes_latch = 0
nes_clock = 0
button_debounce = 5
car_position = %00001000  // start position for our car
hit_data = 0
// Main Program
While True()
        car_data
        road_data
        check_control_pad
        check_buttons
        debounce_buttons
        hit_data_update
        collision_detect
Wend
// end of program.
End
Post by bitfogav » Sun Sep 05, 2010 5:28 am
For some reason the subroutine "check_buttons" from the code above will not come out correctly when put in a forum code box, so here it is.
Post by brad » Sun Sep 05, 2010 9:24 pm
Ah Swordfish basic - nice and simple!
Post by bitfogav » Sun Sep 05, 2010 9:34 pm
brad wrote:Ah Swordfish basic - nice and simple!
yes im finding bits of it so easy now, where in assembly you had to write serveral lines of code to change the speed of the car for an example, where in swordfish its just a case of a few numbers.. :D
Post by brad » Mon Sep 06, 2010 9:53 pm
I have just tonight started expermenting with the inbuilt ADC's within the microcontroller.
you know what has made it simple for me? SWORDFISH include files :)
Post by bitfogav » Tue Sep 07, 2010 3:23 am
brad wrote:I have just tonight started expermenting with the inbuilt ADC's within the microcontroller.
Cool, I have yet to look at the ADC's with swordfish but I did do abit of ADC's using assembly. I have looked at EEPROM though with swordfish and i am quite amazed that this bit of code writes to eeprom
EE.Write(0,Value)
when I used to do it in assembly I had to write out this much code :o
eeprom.write
		bsf		STATUS, RP1			; set RP1 + clear RP0 = Bank2
		bcf		STATUS, RP0			; select BANK 2
		movwf	EEDATA				; puts contents of Working register into EEDATA register
		bsf		STATUS, RP0			; selects BANK 3
		bcf		EECON1, EEPGD		; Stores to DATA memory (NOT Program memory)
		bsf		EECON1,WREN			; sets bit in EECON1, WREN bit (turns ON write bit) (WREN = EEPROM Write Enable bit)
		movlw	55h					; puts 55h (85 decemal) into
		movwf	EECON2				; EECON2 register = EEPROM Control register 2
		movlw	0AAh				; puts 0AAh (170 decemal) into
		bsf		EECON1,	WR			; sets bit in EECON1, WR (write) bit, STARTS a write cycle.
									; The bit is cleared by hardware once write is complete.
write.done
		btfsc	EECON1,	WR			; waits for WR bit to clear before moving on, when cleared next line skipped.
		goto	write.done			; goes back to write.done untill WR is cleared
		bcf		EECON1,	WREN		; clears bit in EECON1, WREN bit (turns OFF write bit) (WREN = EEPROM Write Enable bit)
		bcf		STATUS, RP1			; we now have to clear BOTH RP1 + RP0 to -
		bcf		STATUS, RP0			; select BANK 0 and return to our prog.
		return						; returns to prog
