LM3886 Schematics + PCB
Posted: Thu Aug 25, 2016 6:11 pm
Hello!
Very small PCB based on Yorkville Amps.
This circuit diagram Yorkville use in 50w guitar and keyboard amp, active stidio monitor, active PA speakers, small powered mixer... Circuit is simple R5, C5 and D1 make turn on/off delay on mute pin. I made over 80 PCBs, and use PC procesor heatsink for cooling. Most of them work in 2-6 channel amplifier for caffe-bars. Work great over 2 years in all condition even sumer heat. I you are beginer in DIY, start with this amp.
Pout 68W RMS, THD 0,01%, Damping >400
PCB size 53x25mm
I use the LM3886 was bought from kynix semiconductor. There is the datasheet : http://www.kynix.com/uploadfiles/pdf967 ... 789714.pdf
PCB size 53x25mm
