Post here to discuss designing your own PCB's
1266:
Garth
Post
by Garth » Sun Jan 29, 2017 1:41 pm
Posted on the AnyCPU forum, at
http://anycpu.org/forum/viewtopic.php?p=2315#p2315 :
Holy mackerel!! It looks like about 340 ICs (counting the mezzanine) and there might be more ICs under the big ones! I've laid out a board with 500 parts, but much of it was analog, and a lot of those were resistors, diodes, and capacitors. The IC count was only about 30. Routing buses for the one above must have been a nightmare, requiring a huge number of layers. Troubleshooting and repairing with those white and yellow wires would be quite a challenge too.
Post
by brad » Tue Mar 14, 2017 8:00 pm
I like it how they ran out of room, so the SIP resistors needed to be tacked on.
Garth
Post
by Garth » Wed Mar 15, 2017 4:48 am
I suspect that was to fix problems after some debugging.
Post
by brad » Mon Mar 27, 2017 11:44 am
Perhaps they didn't have pull-up / down resistors in there and had issues?
BigEd
- newbie
Post
by BigEd » Fri Apr 07, 2017 7:11 am
Big board you say? Try
this:
The biggest Series 32000 board ever from Janz AG: the "Maxi 32000"
Garth
Post
by Garth » Fri Apr 07, 2017 8:48 am
Wow, if I counted right, that's 665 ICs on one board, assuming there aren't any on the back.
1266:
1266:
