The PROGMEM is changed in this Version! The Compiler is reporting an Error, that only a Constant can be written in this Part of the Memory! Does anyone know a solution, what to change in the code so it works?
Many thanks for help! Because working with the avr-libs is new for me!
Sample Sketches not working in IDE 1.5.8 BETA
Re: Sample Sketches not working in IDE 1.5.8 BETA
Hmm, that's interesting.
Can you post your code just to make sure we're looking at the same thing?
- newbie
- Joined: Thu Jan 08, 2015 5:02 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Hi, i found already a solution! You have to write a "const" in front of the declaration!
for example:
// Program memory arrays
const byte numberTable[30]PROGMEM={0b01111110, 0b01000010, 0b01111110, 0b0010001..........
many thanks!
for example:
many thanks!
Great work synd, thanks for updating us!
- newbie
- Contact:
Thanks a lot bro, I was also having the same problem, now it works ... Thumbs up.
You should also check The Engineering Projects because they have posted a lot of Arduino Projects and PIC Mirocontroller Projects and have also designed many new Proteus Tutorials and C# Tutorial. I hope you guys are gonna like them.
