Any way to get this sensor working again?
Posted: Wed Nov 30, 2016 6:29 pm
I'm trying to build a RPM counter using arduino, and to achieve that, I choose to use a simple hall effect sensor together with a small neodymium magnet stuck on a wheel attached to a DC motor.
I'm using the L293D IC to control the movement of my motors. I've tested the hall effect sensor and the L293D separatly and everything worked just fine. Problems began when I noticed that both the IC and the sensor required a 5v power supply from the arduino, and the sensor just doesn't work whenever the IC is also connected to the 5v power supply. I've read many times that this chip draws a lot of power, and I think that maybe that's the reason for the malfunctioning of the sensor. But what should I do? There's any way to get this sensor working again while the L293D is on?
