Brads Electronic Projects Forum • totaly awsome project
Posted: Tue Apr 05, 2011 10:45 pm
by MrDEB
too bad you couldn't do the leds in smd. Perhaps copper tape?
Wonder what the spacing is on a peg board?
IMPORTANT ??? On your DIPTRACE schematic, how do you get rid of the white boundary lines around a schematic unless its a paid version which I assume it is seeing how you have more that 300 connections.
Wonder how expensive it would be to use LED Matrix displays? $$$$
using RGB LEDs? or even bi-color.
Use a different colored LED for each players paddle.
An idea that slamed into my head!! combine this super pong table w/ tetris
SUPER TETRIS TABLE
now that would be way off the charts.
Re: totaly awsome project
Posted: Wed Apr 06, 2011 5:50 am
Thanks!
I have found a much better way of making the display - and that is to not make it at all, just buy it!
You can get a 16x32 pixel RED LED display for $10 each here: (postage is a little expensive though. two boards + postage = $57)
http://www.aliexpress.com/store/703830/ ... e-P10.html
You are thinking right up my alley with tetris. I already have though about an RGB version which would be an all in one game table. You could play super pong + mario bros + other games aswell - all in 3-bit color!
Posted: Thu Apr 07, 2011 1:16 am
by MrDEB
Looking at schematic and pcboard but only one Vdd pin is connected to 5+
reason?
Posted: Thu Apr 07, 2011 5:10 pm
I have found that you only need one connected.
Some people say you should have both connected but I have never run into any problems with only one. I guess it could increase the current capability, but I am not using the microcontroller to drive any high current components directly (like LED's)
