Table not doing much
- decided to stick around...
- Joined: Wed Oct 24, 2012 4:38 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Table not doing much
I first started looking for dark acrylic, but everything was crazy expensive (100 dollars for a small piece), so white instead. And I even think white is probably better, makes the table a little more light/happy.
$100 a piece seems a bit expensive. However, the white acrylic looks great!
- Saimaster13
I found some dark tinted acrylic at Home Depot for pretty cheap, $25 for a nice sized piece. It is more of a slightly dark tint, but with the protective cover on it it diffuses lights nicely. I plan on using it for an 8x8 gaming thing, kind of like Retroball.
Joshua
Well we don´t have Home Depots in the Netherlands, hahaha
And the dark tinted piece was really thick so I guess that also increases the price.
- Saimaster13
And we have progress, the screen works so that´s cool and the acrylic really helps.
I still need to swap + and - for two potentiometers. And because of the extra layers of paint the glass doesn't fit anymore
so I'll fix that with a dremel. And then we have a working retroball custom build!!!
And it indeed flickers, but that's the next step with the crystal!
So here's a movie
http://s303.beta.photobucket.com/user/W ... 0.mp4.html
So here's a movie
Ok, so I fixed the controls, placed everything together and the glass now fits. And the pong game is really cool, brad!!! So much better than the early instructables version
Any chance of a video of how it runs?
I might have to wait to look into fixing the flicker problem for over my Christmas break. Will let you know how it goes though
So here a video of the latest state of the table.
I'm not really in a hurry, because now I don't have have a whole bunch of parts lying around. I'm already happy that you want to take the time to fix the code. So thumbs up!
I'll buy a crystal at my local electronics shop 20 mhz and I already have some caps lying around. So I'll make the hacky crystall add on board following the schematic of bitfogav
BTW I saw in the code there's also a speaker/sound in the retroball version. Are you just generating beeps? Or did you have special sound samples? because if they are only beeps I could add a speaker to an extension port on the board and the table would even have sound than
Jst let me know, I probably have some speaker lying around.
Those blue LED's look really nice
I can't notice the flicker in the video - is it worse in real life?
also, make sure your caps are 15pF
The flickering is not horrible, but in real life in some parts you really notice it. In the video it looks perfect
Yeah I´ll take 15pf caps!
Just don't let anyone on youtube know that it flickers
The add-on board shouldn´t take long :p I see that Brad mentions 15 pf and bitfogav 22pf. I have both so I can choose
I ordered the crystal, so it will be here soon. Also ordered some heat shrinking tubing to make it pretty and safe.
22pf will be the limit for a 20Mhz crystal, but the recommended cap from the datasheet is a 15pf cap..
Okay 15pf it is. Tomorrow I'll receive the crystal. The only hard part is solering it on the chip.
