Controlling a RGB with PWM
Post by bitfogav » Sun Sep 08, 2013 11:18 pm
Simple programme to control a single RGB led using Swordfish.
Device = 18F4550
Clock = 48
Config  PLLDIV = 5,
        CPUDIV = OSC1_PLL2,
        USBDIV = 2,
        FOSC = HSPLL_HS
Include "RandGen.bas"
Dim TMR2IE As PIE1.1,       // TMR2 interrupt enable
TMR2IF As PIR1.1,           // TMR2 overflow flag
TMR2ON As T2CON.2,          // Enables TMR2 to begin incrementing
Signal_Pin As PORTB.0       // Signal output to frequency meter
Dim Red_Pin As PORTC.0,
    Green_Pin As PORTC.1,
    Blue_Pin As PORTC.2,
    Red_Duty As Byte,
    Green_Duty As Byte,
    Blue_Duty As Byte,
    Red_DutyVal As Byte,
    Green_DutyVal As Byte,
    Blue_DutyVal As Byte,
    RandomVal As Byte
Dim uS As Word,
    mS As Word
Interrupt TMR2_Interrupt()
    High(Signal_Pin)
    Save(0)                   // Back up system variables
    If TMR2IF = 1 Then        // Check if the interrupt was from TMR2
        TMR2IF = 0            // Clear the TMR2 interrupt flag
        uS = uS + 50
        If uS >= 1000 Then
            uS = uS - 1000
            Inc(mS)
            Inc(Red_DutyVal)
            Inc(Green_DutyVal)
            Inc(Blue_DutyVal)
    If Red_DutyVal > Red_Duty Or Red_Duty = 0 Then
        Red_Pin = 0
    Else
        Red_Pin = 1
    If Green_DutyVal > Green_Duty Or Green_Duty = 0 Then
        Green_Pin = 0
    Else
        Green_Pin = 1
    If Blue_DutyVal > Blue_Duty Or Blue_Duty = 0 Then
        Blue_Pin = 0
    Else
        Blue_Pin = 1
    Restore                   // Restore system variables
    Low(Signal_Pin)
End Interrupt
Private Sub TMR2_Initialize()
        TMR2ON = 0                  // Disable TMR2
        TMR2IE = 0                  // Turn off TMR2 interrupts
        PR2 = 149                   // TMR2 Period register PR2
        T2CON = %00000001           // T2CON 0:1 = Prescale
                                    //        00 = Prescale is 1:1
                                    //        01 = Prescale is 1:4
                                    //        1x = Prescale is 1:16
                                    //      3:6 = Postscale
                                    //     0000 = 1:1 postscale
                                    //     0001 = 1:2 postscale
                                    //     0010 = 1:3 postscale...
                                    //     1111 = 1:16 postscale
        TMR2 = 0                  // Reset TMR2 Value
        TMR2IE = 1                // Enable TMR2 interrupts
        TMR2ON = 1                // Enable TMR2 to increment
        Enable(TMR2_Interrupt)
// Start Of Program...
Low(Red_Pin)
Low(Green_Pin)
Low(Blue_Pin)
Red_Duty = 0
Green_Duty = 0
Blue_Duty = 0
Red_DutyVal = 0
Green_DutyVal = 0
Blue_DutyVal = 0
uS = 0
mS = 0
RandGen.Initialize(128)             // Initialize the Random Number generator
TMR2_Initialize                     // Setup and enable TMR2
While True                          // Create an infinite loop
        RandomVal = RandGen.Rand    // Grab a random number from 0 to 255
            Select RandomVal        // Find out what colour to increase/decrease
                Case 0 To 42
                    While Red_Duty < 255
                        mS = 0
                        Repeat
                        Until mS = 19
                        Inc(Red_Duty)
                    Wend
                Case 43 To 84
                    While Red_Duty > 0
                        mS = 0
                        Repeat
                        Until mS = 19
                        Dec(Red_Duty)
                    Wend
                Case 84 To 127
                    While Green_Duty < 255
                        mS = 0
                        Repeat
                        Until mS = 19
                        Inc(Green_Duty)
                    Wend
                Case 128 To 170
                    While Green_Duty > 0
                        mS = 0
                        Repeat
                        Until mS = 19
                        Dec(Green_Duty)
                    Wend
                Case 170 To 212
                    While Blue_Duty < 255
                        mS = 0
                        Repeat
                        Until mS = 19
                        Inc(Blue_Duty)
                    Wend
                Case 212 To 255
                    While Blue_Duty > 0
                        mS = 0
                        Repeat
                        Until mS = 19
                        Dec(Blue_Duty)
                    Wend
    End Select
Wend
You may need to download the random gen module and include it into your user library folder.
RandGen.zip
(970 Bytes) Downloaded 781 times
Re: Controlling a RGB with PWM
Post by brad » Mon Sep 09, 2013 10:06 pm
Thanks for that Gav, I'll have to put a little something together also.
Anything you'd like to see here Stacy?
