Hi everyone, hopefully someone can lend a hand with an issue I am having.
I am writing a little program that displays different color bouncing balls on a 32x32 pixel RGB LED matrix. I wanted to use a structure array for the balls. The code to bounce the balls around the screen works just fine as long as I copy and paste each section of code and individually write in the number of the ball in the structure array.
To start off, heres the contents of the structure:
Structure Ball
Color As Byte
X As Byte
Y As Byte
XDelay As Byte
XDelay2 As Byte
YDelay As Byte
YDelay2 As Byte
GoingUp As Boolean
GoingLeft As Boolean
MaxJumpHeight As Byte
CurrentJumpHeight As Byte
End Structure
Dim Multiball(4) As Ball
Sub BounceTheBalls()
for Index = 0 to bound(multiball)
' First move the balls left / right
If Multiball(Index).XDelay <> 0 Then
Dec(Multiball(Index).XDelay)
Else
Multiball(Index).XDelay = Multiball(Index).XDelay2
If Multiball(Index).GoingLeft = false Then
Inc(Multiball(Index).X)
If Multiball(Index).X = 31 Then
Multiball(Index).GoingLeft = true
Else
Dec(Multiball(Index).X)
If Multiball(Index).X = 0 Then
' then move the balls up / down
If Multiball(Index).YDelay <> 0 Then
Dec(Multiball(Index).YDelay)
Else
If Multiball(Index).GoingUp = false Then ' if the ball is going down
If Multiball(Index).YDelay2 > 0 Then ' only take one away if we are still greater than 0 (0 is the fastest we can get because it's the lowest delay)
Dec(Multiball(Index).YDelay2)
Multiball(Index).YDelay = Multiball(Index).YDelay2 ' now make the ball move down 1 space
Inc(Multiball(Index).Y)
Else ' if the ball is not going down, then it must be going up - so we need to slow the ball down
Inc(Multiball(Index).YDelay2)
Dec(Multiball(Index).Y)
Inc(Multiball(Index).CurrentJumpHeight)
If Multiball(Index).Y = 31 And Multiball(Index).GoingUp = false Then
Multiball(Index).YDelay = 0
Multiball(Index).YDelay2 = 0
Multiball(Index).GoingUp = true
Multiball(Index).CurrentJumpHeight = 0
End If
If Multiball(Index).GoingUp = true And Multiball(Index).CurrentJumpHeight >= Multiball(Index).MaxJumpHeight Then
next
However if I use exactly the same code - but replace the 'Index' in multiball(Index) with a number such as 0, 1, 2 or 3, the code works perfectly and that particular ball will then bounce around the screen. If I copy and paste this code four times (one time for each ball) and then replace the 'Index' with an actual number, all balls then bounce around the screen.
So I guess the big issue here is that as soon as I try and use a variable to access the array, it doesn't work. But if I use an actual integer - it does work.
Any help or suggestions would be much appreciated!
