Drawing Graphics "PacMan" on 24x24 Led Matrix
Posted: Fri Sep 03, 2010 4:20 am
Heres a PacMan animation that I made for my 24x24 led matrix.
The link for the video is here -
http://www.youtube.com/watch?v=S2ARe1bBN-0
I can't post the whole code as theres alot of animation data but I will try my best.
// Name of Program
Program PacMan_animation  // useful for documentation purposes
// Device and Clock
Device = 18F4685         // Tell the compiler what chip we are using
Clock = 20               // Tell the compiler what we will be setting the clock to (Mhz)
Config MCLRE = ON
    // default fuses...
Config
   OSC = HS,
   FCMEN = OFF,
   IESO = OFF,
   PWRT = ON,
   BOREN = BOACTIVE,
   WDT = OFF,
   WDTPS = 128,
   PBADEN = OFF,
   DEBUG = OFF,
   XINST = OFF,
   LVP = OFF,
   STVREN = ON
// Modules
Include "Utils.bas"      // Include this file when we compile so that we can use keywords like "SetAllDigital"
// Const Arrays
// Anodes if we are using ULN2803 Chips (common-cathode Darlington transistor array.)
Const Anode_data(8) As Byte = (%10000000,%01000000,%00100000,%00010000,%00001000,%00000100,%00000010,%00000001)
// Setup ALL our PORTS
Dim E_ALL_74573 As PORTC.6               ' setup ALL 74573 enable pins
Dim L_RedB0_74573 As PORTC.4              ' setup our RED CATHODE 74573 latch pin
Dim L_RedB1_74573 As PORTC.0              ' setup our RED CATHODE 74573 latch pin
Dim L_RedB2_74573 As PORTC.1              ' setup our RED CATHODE 74573 latch pin
Dim L_GreenB0_74573 As PORTC.2            ' setup our GREEN CATHODE 74573 latch pin
Dim L_GreenB1_74573 As PORTC.3            ' setup our GREEN CATHODE 74573 latch pin
Dim L_GreenB2_74573 As PORTC.5            ' setup our GREEN CATHODE 74573 latch pin
Dim L_AnodeR0_74573 As PORTE.0            ' setup our ANODE 74573 latch pin
Dim L_AnodeR1_74573 As PORTE.1            ' setup our ANODE 74573 latch pin
Dim L_AnodeR2_74573 As PORTE.2            ' setup our ANODE 74573 latch pin
Dim Anode_port As PORTB                   ' Anode DATA PORT
Dim Graphic_port As PORTD                 ' Graphic DATA PORT (green and red)
' when latch pin = high then data can be latched, when latch pin = low data cannot be stored
' when enable pin = high outputs OFF, when enable pin = low outputs ON
The code above: starts with a "Program PacMan_animation" this is used only for documentation purposes, and which means we need to use "END" at the end of our program which you will see at the end of the code. We then declare our microchip and clock speed, I am using an external 20mhz clock, next we have Config MCLRE = ON as I am using a RESET switch on my hardware, then we include swordfish module "Utils" so we can set I/0 ports to digital ports, and then we have a constant array "Anode_data" this array is called in code to set the Anodes of the matrix.
Then lastly I define all my PORT BITS which control all my 'D' type Latch 74573's. Im using nine 74573's in total, 3 to control all the GREEN cathodes and 3 to control all the RED cathodes and 3 to control all the Anodes, and then set PORTB as my Anode control bus and PORTD as my graphic (cathode) bus, I could have used just one port for all my data bus.
// Variable Declarations
Dim x As Byte
Dim t As Word
Dim counter As Word
Dim block_0_green(8) As Byte
Dim block_0_red(8) As Byte
Dim block_1_green(8) As Byte
Dim block_1_red(8) As Byte
Dim block_2_green(8) As Byte
Dim block_2_red(8) As Byte
Dim block_3_green(8) As Byte
Dim block_3_red(8) As Byte
Dim block_4_green(8) As Byte
Dim block_4_red(8) As Byte
Dim block_5_green(8) As Byte
Dim block_5_red(8) As Byte
Dim block_6_green(8) As Byte
Dim block_6_red(8) As Byte
Dim block_7_green(8) As Byte
Dim block_7_red(8) As Byte
Dim block_8_green(8) As Byte
Dim block_8_red(8) As Byte
Dim display_step As Word
In the code above I just declare my Variables
// Subroutines ====
Sub update_ram_data()
    Select display_step
        Case 0
block_0_red(0) = $00
block_0_red(1) = $00
block_0_red(2) = $00
block_0_red(3) = $00
block_0_red(4) = $00
block_0_red(5) = $00
block_0_red(6) = $00
block_0_red(7) = $00
block_0_green(0) = $00
block_0_green(1) = $00
block_0_green(2) = $00
block_0_green(3) = $00
block_0_green(4) = $00
block_0_green(5) = $00
block_0_green(6) = $00
block_0_green(7) = $00
block_1_red(0) = $00
block_1_red(1) = $00
block_1_red(2) = $00
block_1_red(3) = $00
block_1_red(4) = $00
block_1_red(5) = $00
block_1_red(6) = $00
block_1_red(7) = $00
block_1_green(0) = $00
block_1_green(1) = $00
block_1_green(2) = $00
block_1_green(3) = $00
block_1_green(4) = $00
block_1_green(5) = $00
block_1_green(6) = $00
block_1_green(7) = $00
block_2_red(0) = $00
block_2_red(1) = $00
block_2_red(2) = $00
block_2_red(3) = $00
block_2_red(4) = $00
block_2_red(5) = $00
block_2_red(6) = $00
block_2_red(7) = $00
block_2_green(0) = $00
block_2_green(1) = $00
block_2_green(2) = $00
block_2_green(3) = $00
block_2_green(4) = $00
block_2_green(5) = $00
block_2_green(6) = $00
block_2_green(7) = $00
block_3_red(0) = $00
block_3_red(1) = $00
block_3_red(2) = $00
block_3_red(3) = $00
block_3_red(4) = $00
block_3_red(5) = $00
block_3_red(6) = $00
block_3_red(7) = $00
block_3_green(0) = $00
block_3_green(1) = $00
block_3_green(2) = $00
block_3_green(3) = $00
block_3_green(4) = $00
block_3_green(5) = $00
block_3_green(6) = $00
block_3_green(7) = $00
block_4_red(0) = $00
block_4_red(1) = $00
block_4_red(2) = $00
block_4_red(3) = $00
block_4_red(4) = $00
block_4_red(5) = $00
block_4_red(6) = $00
block_4_red(7) = $00
block_4_green(0) = $00
block_4_green(1) = $00
block_4_green(2) = $00
block_4_green(3) = $01
block_4_green(4) = $01
block_4_green(5) = $00
block_4_green(6) = $00
block_4_green(7) = $00
block_5_red(0) = $00
block_5_red(1) = $00
block_5_red(2) = $00
block_5_red(3) = $00
block_5_red(4) = $00
block_5_red(5) = $00
block_5_red(6) = $00
block_5_red(7) = $00
block_5_green(0) = $00
block_5_green(1) = $00
block_5_green(2) = $00
block_5_green(3) = $b6
block_5_green(4) = $b6
block_5_green(5) = $00
block_5_green(6) = $00
block_5_green(7) = $00
block_6_red(0) = $00
block_6_red(1) = $00
block_6_red(2) = $00
block_6_red(3) = $00
block_6_red(4) = $00
block_6_red(5) = $00
block_6_red(6) = $00
block_6_red(7) = $00
block_6_green(0) = $00
block_6_green(1) = $00
block_6_green(2) = $00
block_6_green(3) = $00
block_6_green(4) = $00
block_6_green(5) = $00
block_6_green(6) = $00
block_6_green(7) = $00
block_7_red(0) = $00
block_7_red(1) = $00
block_7_red(2) = $00
block_7_red(3) = $00
block_7_red(4) = $00
block_7_red(5) = $00
block_7_red(6) = $00
block_7_red(7) = $00
block_7_green(0) = $00
block_7_green(1) = $00
block_7_green(2) = $00
block_7_green(3) = $00
block_7_green(4) = $00
block_7_green(5) = $00
block_7_green(6) = $00
block_7_green(7) = $00
block_8_red(0) = $00
block_8_red(1) = $00
block_8_red(2) = $00
block_8_red(3) = $00
block_8_red(4) = $00
block_8_red(5) = $00
block_8_red(6) = $00
block_8_red(7) = $00
block_8_green(0) = $00
block_8_green(1) = $00
block_8_green(2) = $00
block_8_green(3) = $00
block_8_green(4) = $00
block_8_green(5) = $00
block_8_green(6) = $00
block_8_green(7) = $00
The Code above is my Subroutine, this is the first animation data which sets the nine 8x8 matrix's, I am using a swordfish "SELECT" and then just calling aload of CASE commands. to update my RAM with new animation data.
        Case 1
block_0_red(3) = $80
block_0_red(4) = $80
block_0_green(3) = $80
block_0_green(4) = $80
block_6_red(3) = $80
block_6_red(4) = $80
block_6_green(3) = $80
block_6_green(4) = $80
        Case 2
block_0_red(2) = $80
block_0_red(3) = $e0
block_0_red(4) = $e0
block_0_red(5) = $c0
block_0_red(6) = $80
block_0_green(2) = $80
block_0_green(3) = $e0
block_0_green(4) = $e0
block_0_green(5) = $c0
block_0_green(6) = $80
block_6_red(1) = $80
block_6_red(2) = $c0
block_6_red(3) = $e0
block_6_red(4) = $e0
block_6_red(5) = $80
block_6_green(1) = $80
block_6_green(2) = $c0
block_6_green(3) = $e0
block_6_green(4) = $e0
block_6_green(5) = $80
the code above is the next two CASE commands, as you can see theres not has much data needed for the next load of data, as I am only updating the blocks of data that is needed to display the next Frame, and this is how the pacman code goes, I use a total of 64 CASE commands, each one is a Frame of data and only updates the RAM with the bits that are needed for the next frame.
        Case 64
block_2_green(5) = %00000000
block_2_green(6) = %00000000
block_2_green(7) = %00000000
block_5_green(0) = %00000000
block_5_green(1) = %00000001
block_5_green(2) = %00000001
block_5_green(3) = %00000001
block_5_green(4) = %00000001
block_5_green(5) = %00000001
block_5_green(6) = %00000001
block_5_green(7) = %00000001
block_8_green(0) = %00000001
block_8_green(1) = %00000001
block_8_green(2) = %00000001
block_8_green(3) = %00000001
block_8_green(4) = %00000001
block_8_green(5) = %00000001
block_8_green(6) = %00000001
       EndSelect
            // this is our count of frames
            // increment by 1
        display_step = display_step + 1
            // if we get to end, reset to 0
    If display_step = 64 Then    ' change the number of steps
        display_step = 0
    High (E_ALL_74573)  ' makes enable pin high (all outputs OFF)
the code above is our last CASE 64 (last frame) so we END SELECT. and then increase the display_step, this is our counter for which frame to display. and then we check display_step and if it equals 64 then it is reset to 0. and lastly make sure all the 74573's enable pins are in a HIGH state to turn off all outputs.
        For t = 0 To 150  // t = time delay
            For x = 0 To 7
        ' red data
             High   (L_RedB0_74573)               ' setup our RED CATHODE 74573 latch pin
                Graphic_port = block_0_red(x)
             Low    (L_RedB0_74573)               ' setup our RED CATHODE 74573 latch pin
             High   (L_RedB1_74573)               ' setup our RED CATHODE 74573 latch pin
                Graphic_port = block_3_red(x)
             Low    (L_RedB1_74573)               ' setup our RED CATHODE 74573 latch pin
             High   (L_RedB2_74573)               ' setup our RED CATHODE 74573 latch pin
                Graphic_port = block_6_red(x)
             Low    (L_RedB2_74573)               ' setup our RED CATHODE 74573 latch pin
        ' green data
             High   (L_GreenB0_74573)             ' setup our GREEN CATHODE 74573 latch pin
                Graphic_port = block_0_green(x)
             Low    (L_GreenB0_74573)             ' setup our GREEN CATHODE 74573 latch pin
             High   (L_GreenB1_74573)             ' setup our GREEN CATHODE 74573 latch pin
                Graphic_port = block_3_green(x)
             Low    (L_GreenB1_74573)             ' setup our GREEN CATHODE 74573 latch pin
             High   (L_GreenB2_74573)             ' setup our GREEN CATHODE 74573 latch pin
                Graphic_port = block_6_green(x)
             Low    (L_GreenB2_74573)             ' setup our GREEN CATHODE 74573 latch pin
        ' anodes data
             High   (L_AnodeR0_74573)             ' setup our ANODE 74573 latch pin
                Anode_port = Anode_data (x)
             Low    (L_AnodeR0_74573)             ' setup our ANODE 74573 latch pin
             High   (L_AnodeR1_74573)             ' setup our ANODE 74573 latch pin
             High   (L_AnodeR2_74573)             ' setup our ANODE 74573 latch pin
                Anode_port = $00
             Low    (L_AnodeR1_74573)             ' setup our ANODE 74573 latch pin
             Low    (L_AnodeR2_74573)             ' setup our ANODE 74573 latch pin
        ' Enable our Matrix
             Low    (E_ALL_74573)       ' makes enable pin low (all outputs ON)
                DelayUS(400)
             ' we now clear our Anode data to stop graphic ghosting
                Anode_port = $00
        ' red data
                Graphic_port = block_1_red(x)
                Graphic_port = block_4_red(x)
                Graphic_port = block_7_red(x)
        ' green data
                Graphic_port = block_1_green(x)
                Graphic_port = block_4_green(x)
                Graphic_port = block_7_green(x)
        ' anodes data
                Anode_port = $00
        ' Enable our Matrix
                DelayUS(400)
                Anode_port = $00
        ' red data
                Graphic_port = block_2_red(x)
                Graphic_port = block_5_red(x)
                 Graphic_port = block_8_red(x)
       ' green data
                Graphic_port = block_2_green(x)
                Graphic_port = block_5_green(x)
                Graphic_port = block_8_green(x)
       ' anodes data
                Anode_port = $00
       ' Enable our Matrix
                DelayUS(400)
                Anode_port = $00
            Next
              Inc(t)
        Next
the code above setups all the data lines and even sets a delay so each frame is set to display a certain amount of time, this is done with the following line of code "For t = 0 To 150 // t = time delay".
// Set Ports
SetAllDigital       // Make all Pins digital I/O's
TRISA = %11111111   // Make PORTA all inputs
TRISB = %00000000   // Make PORTB all outputs
TRISC = %00000000   // Make PORTC all outputs
TRISD = %00000000   // Make PORTD all outputs
TRISE = %00000000   // Make PORTE all outputs
    PORTB = $00      ' clear all ports
    PORTC = $00
    PORTD = $00
    PORTE = $00
    // this clears all data in all 74573 data latches
        // and this makes all outputs off
        ' make sure all our data latches are closed
// Initialize Variables
counter = 0
display_step = 0
// Main Program
While True()
          update_ram_data
Wend
// end of program.
End
And then the code above is the last part of the code: we start by setting all the PORTS of the microchip and then I make sure that all the data on all of the 74573's is cleared. I also then initialize variables and then make a WHILE LOOP which only calls one subroutine "update_ram_data" this gives us a Infinite loop so the animation PacMan will go on forever! :)
If you have any questions then just ask.
Posted: Fri Sep 03, 2010 10:01 pm
Very cool man :)
You have actually inspired me to get into these types or larger displays. I am also looking into using PWM to give more shades / colours.
Ontop of that I have been reading up on using standard LED's as light sensors (photodiodes) They work unbelievably well! I will go and start a new thread on the topic...
Just imagine your 24 x 24 matrix where you can touch it and make pixel's light up!
Posted: Sat Sep 04, 2010 3:26 am
brad wrote:Very cool man :)
Yeah I have read that thread, thats well cool and yeah that would be something if my 24x24 matrix did that :)
Ive looked into PWM too, I know quite abit about it, what it is and how it works because it is used in many motor vehicle systems, eg: fan motors etc, and I have made a project which controls 8 leds using PWM, but it would be something if these 8x8 red and green used PWM..
