Transistor Info
Re: Transistor Info
Handy and easy to use, thanks Chuck
- newbie
- Joined: Sun Oct 05, 2014 7:39 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Transistor Info
Hahaha thanks, I'm the creator of that site, and if you want I translated to english as well:
http://www.info-transistor.info/index.php?set_lang=en
One of the most interesting features is that my site generates always an image that you can insert in the forums, something like this:
In the bottom of the site you will find export options to share the main characteristics of a transistor, I hope you enjoy!
Whatever you need you can contact me trough the contact form on my web, regards!
Re: Transistor Info
Thanks for the extra info there Failsafe.
I am interested to know where it is pulling all of the data from. Did you set it all up or is it linked to some pre-existing external database?
- newbie
Re: Transistor Info
I did everything the database is internal, I made a scrapper that takes all the data from trusted sites I choose. At this moment it has 55,992 BJT 18,485 FET and 2,504 IGBT. It's not so small. Thank you for your interest!brad wrote:Thanks for the extra info there Failsafe.
Re: Transistor Info
Very impressive FailSafe,
Thanks again for making it!
- newbie
Re: Transistor Info
You're welcome! I hope you enjoy it
