hello all,
I had this idea to start up a forum whereby any forum member could start their own topic and explain to people how to do something with respect to electronics.
For example, maybe you would like to show everyone what a resistor does, or perhaps how to use transistors to drive speakers, motors or LED's. Maybe you could write about using microcontroller interrupts or how to solder surface mount components. The list goes on!
So if you feel that you have something that others would benefit from learning about, then by all means - post it!
regards,
- professor brad
All about the Brads Projects university.
Re: All about the Brads Projects university.
It's 6502-oriented, but I have an article on interrupts at http://6502.org/tutorials/interrupts.html . (Enjoy my very outdated cartoons!)brad wrote:Maybe you could write about using microcontroller interrupts
I've done SOJs where you use a 1/8" tip that covers three pins at once, tack a couple of corners of the IC to hold it in place, then make a big bridge mess down both sides, then hold the board and row of pins vertically and go top to bottom, melting the solder again, and all the excess solder comes off on the iron, leaving just the right amount on every pin, and no bridges. It's amazing how well it works. It would be great if someone would post a video of that kind of thing.or how to solder surface mount components.
There's a list of my articles at http://wilsonminesco.com/GarthArticleLinks.html, mostly 6502-oriented but quite a few have applicability to other processors and microcontrollers too.The list goes on!
The newest feature of my website is simple methods for multitasking without a multitasking OS, for systems that lack the resources for a multitasking OS, or where hard realtime requirements would rule one out anyway.
One of the sections of the website which surprisingly gets the most traffic even though there's no conversation about it in emails or the 6502.org forum is about large look-up tables for hyperfast, accurate 16-Bit scaled-integer math, including trig & log functions.
The Circuit Potpourri page is actually section 22 of the 6502 primer about building your own 6502 computer, which is mostly about hardware aspects but touches on software a little too. The circuit potpourri page is just that-- a collection of ways to interface more than you probably imagined to your microprocessor project.
I have an RS-232 primer at http://wilsonminesco.com/RS-232/RS-232primer.html. (My apologies-- there aren't many pictures and diagrams at the beginning; but it should be clear and helpful anyway.)
There's I2C-6, a proposed connector standard for I²C, suitable for breadboarding, at http://forum.6502.org/viewtopic.php?f=4&t=2155 . (This one is on the 6502.org forum.)
The 65SIB specification is at http://forum.6502.org/viewtopic.php?t=1064&start=105 (on the 6502.org forum). This is a serial interface bus, compatible with SPI but more flexible. It uses a daisychain of ribbon cables to go from one outboard device to the next (so the host only needs one port to communicate with lots of devices), with autoaddressing and other valuable features. It can communicate with anything from dumb shift registers up to very intelligent devices. The "65" in the name is just because we hashed it out on the 6502.org forum; but there's nothing that particularly ties it to the 6502 or other 65-family processors.
I have more articles linked on the first page mentioned above.
For nearly the last couple of years, I've been slowly working on my next major website feature, a treatise on stacks. It will have about 16 chapters, starting with the basics (subroutine returns, then interrupts), and working through virtual data stacks, stack addressing, parameter-passing, inlined data, RPN operations, local variables and environments and recursion, how a stack is used when compiling or assembling nestable program structures, stack frames, and other things, stopping just as we get into multitasking where you assign each task its own stack(s) in the stack area(s) of memory. It was looking like I bit off more than I could chew, from a standpoint of how much work it was. It sat collecting dust for nearly a year, but I've been able to work on it a lot again in the last two months. If you have ideas or questions you want to see addressed, please let me know. It's 6502-oriented, but will have applicability to other processors as well. I don't know of anything like this on the internet.
Garth thanks so much for posting, I had a browse through your first link and couldn't believe the amount of content you have written up and with pictures to boot! This is a wonderful resource that you have. I have been looking at peoples home made computers lately so I will have to have a good browse through your homemade links for the 6502
It's up, at http://wilsonminesco.com/stacks/ , and addresses the range of subjects regarding 6502 stacks, starting with the definition and gradually reaching a stage a little bit past intermediate use, mostly ignoring the loftier subjects like multi-user, multithreading, and multitasking systems (which the 6502 is not very well suited for anyway). Here's a list of chapters:Garth wrote:For nearly the last couple of years, I've been slowly working on my next major website feature, a treatise on stacks. [...]
- definition and very basics
- subroutine return addresses and nesting
- interrupts
- virtual stacks and various ways to implement them
- stack addressing, both hardware and virtual
- passing parameters, and comparison of methods
- having a subroutine find inlined data, using the return address
- doing math and other operations by stacks in RPN
- RPN efficiency
- 65c02's added instructions that are useful in stacks
- using RTS, RTI, and JSR to synthesized other instructions
- where-am-I routines, for self-relocatable code
- a peek at the 65816's new instructions and capabilities that are relevant to stacks, and 65c02 code which partially synthesizes some of them
- local variables and environments
- recursion
- enough stack space?
- compiling or assembling program structures
- stack potpourri
- for further reading
Happy programming!
Thanks Garth and great work on the site!
I'll be posting it to my home page later this week when I should have some time to do so!
