Hello
Please can anyone help me to read the value of this capacitor?
Thank you
Is this a 22nf or 220pf?
- semi-newbie
- Joined: Sat Oct 26, 2013 3:40 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
- 1314339075947.jpg (93.51 KiB) Viewed 13374 times
Re: Is this a 22nf or 220pf?
It looks like n22, not 022, and especially because it's so tiny, I expect it's 22pF. Do you have a DMM with a capacitance-test function?
- semi-newbie
It is 220pf and 0.22nf
Thank you buddy
Thank you buddy
I can see you have the answer now but it looks like they are using the convention which seems to be used increasingly with resistors. Instead of writing 1.2k for instance it would be written as 1k2. So because you have an 'n' followed by the digits '22' you would place the decimal point in place of the 'n' and then that would give your value in nanofarads.
I'm not such a fan of this technique - but I guess it still works!
