http://ww1.microchip.com/downloads/en/A ... 00906B.pdfINTRODUCTION
This application note describes how to drive a bipolar
stepping motor with the PIC16F684. The Enhanced
Capture Compare PWM (ECCP) module is used to
implement a microstepping technique known as hightorque
microstepping. The microcontroller’s 8 MHz
internal oscillator allows the signals generated by the
ECCP module to achieve frequencies above the
audible range.
Stepper Motor Control Using the PIC16F684
theenggprojects
- Contact:
Re: Stepper Motor Control Using the PIC16F684
Thanks for the link, keep up the good work. (Y)
You should also check The Engineering Projects because they have posted a lot of Arduino Projects and PIC Mirocontroller Projects and have also designed many new Proteus Tutorials and C# Tutorial. I hope you guys are gonna like them.
