Basic Electronic Components and their Symbols and Connection
On the Youtube site, there are actually 32 more videos in a list and the link is here:
https://www.youtube.com/watch?v=t8kGhq3 ... BTAErdui92
Re: Basic Electronic Components and their Symbols and Connec
I've got the same circuit simulator
It was expensive but it has basically every single part you could think of including micro controllers that you can add code to and have it run!
What software is it exactly?
It is called Proteus VSM. There are different versions you can buy, but back in 2010 I bought the cheapest version which was about $250USD and it allowed you to use three different PIC micro controllers in the simulation.
If you want the full fledged version it is over $1500. Too expensive for me!
Here's the link:
http://www.labcenter.com/products/vsm/pic18.cfm
Here's the link:
