Brads Electronic Projects Forum • deciphering an application circuit--UAA2016
Posted: Sun Oct 16, 2011 11:22 pm
by MrDEB
I Emailed ON Semiconductor but they can't provide any input like HUUA??
Found this device while trying to build a temp ctr soldering iron as per this HAJJO schematic http://www.n0ss.net/hakko_936_schem-pcb_&_mod_v1r7.pdf
Built and found several descripencies between the PCboard layout and the schematic.
Well instead of trying to decipher the problems I am going with a PIC controlled soldering iron.
Could use the easy way out by just using an opti-coupler/triac (ON/OFF) but this UAA2016 looks like a better control solution using PWM via zero crossing.
The app circuit has lots of math which I get lost with. Hoping someone can config the app circuit then I can breadboard and go from there.
Page 3 on datasheet has app circuit.
Re: deciphering an application circuit--UAA2016
Posted: Mon Oct 17, 2011 8:55 pm
Looks like you have quite a project on your hands there!
what microcontroller are you using for the circuit?
Posted: Tue Oct 18, 2011 1:23 am
by MrDEB
Going to use an 18F4520 or 452. basically same pic.
If I can't figure out the UAA2016 then just using a opti coupler (ho hum)
My Komec 936 broke the heater element, purchased the HAKKO907 iron off Ebay for $12.
I got spoiled using a temp ctr iron and mst of hat I have to assemble is sMD so I am kinda at a standstill. The PIC ctr soldering iron is going to be perf boarded w/ dip.
will post present schematic after I add an opti-couplier, couple of LEDs then compress. Its using Diptrace (GREAT PROGRAM)
Posted: Tue Oct 18, 2011 6:55 am
by MrDEB
found an archived data sheet for the UAA2016
http://www2.renesas.com/maps_download/pdf/SEA-1201A.pdf
any help would be appreciated.
Posted: Wed Oct 19, 2011 8:48 pm
What help are you looking for with it?
Posted: Thu Oct 20, 2011 12:27 am
by MrDEB
I contacted ON semiconductor about the app schematic on page 3 but no help.
Going a different direction at present just using an MOC3023 opti coupler.
Would really want to use the UAA2016 but??
Posted: Fri Oct 21, 2011 6:27 am
What do you think the advantage would be using the UAA2016 over an opto-coupler?
Posted: Fri Nov 25, 2011 11:15 pm
by MrDEB
The advantage would be I could then utilize zero cross thus less shock of ON/OFF.
Better control of the temperature as well by using PWM.
The HAKKO soldering iron to mention one, utilizes zero crossing.
an example http://www.fairchildsemi.com/an/AN/AN-3006.pdf
Posted: Sat Nov 26, 2011 7:45 am
Oh I see now!
Very good practice :D
