My PCB Prototype Board
Hi everyone!
I have been working on this project for the last few days, and have just got round to making my own PCB's. I wanted to make a board that gave me access to all the data pins and to use a LCD display. So I designed a schematics using Diptrace and then created my own PCB layout and made it onto some copper clad.
I decided to use a 40pin microcontroller, 20mhz crystal, 8 leds and 8 buttons, LCD display which can be detached from the board.
Heres some pictures:
pcb layout- pcb board- proto board- Heres a video: (video not quite the right way up but you get the idea)
Re: My PCB Prototype Board
Wow man, I can't believe how perfect that completed board came out! Did you use the press n peel paper?
I have made boards myself but they don't seem to come out as perfect as your pic here...
Yeah for this I used press and peel, i just set my iron on max and held it on it until you could see the print through the press and peel paper!, I also use a piece of paper between the press and peel paper and the iron, so the iron is not in direct contact with the press and peel paper!brad wrote:Wow man, I can't believe how perfect that completed board came out! Did you use the press n peel paper?
I tried the UV light way but I think i mixed up the cemicals wrong and the Pre-Sensitised film all came off!! hehe! oops!
- odessa
- Location: London [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Thats a fantastic board Gav ! , Im working on a similar one using a GLCD at the moment.
If when you tried using photoresist all the film came off it sounds like you didn't develop it for long enough...you should get a really clear image of the tracks on the board.
I really like the way you have layed out and routed that board btw ... top job !!
(\_/)
Gota love diptrace! The best darn PCB program out there!
- sdudley
Excellent job! Forget doing my own, I'll just send you the schematics for my projects.
I look forward to seeing your board Jay!odessa wrote:Thats a fantastic board Gav ! , Im working on a similar one using a GLCD at the moment.
Yeah I tried using photoresist film but when I put it into the developer for 5-10 sec I saw the outline for the traces, went to take the board out of the developer and half of theodessa wrote:If when you tried using photoresist all the film came off it sounds like you didn't developer it for long enough...you should get a really clear image of the tracks on the board.
traces dissapeared, the developer turned black! and so not sure if the mix was too strong? I guess its a case of trial and error? Ill have to give it ago again, maybe on a smaller project lol.
Thanks Jay!odessa wrote:I really like the way you have layed out and routed that board btw ... top job !! .
Thanks Stacy nice to see you backsdudley wrote:Excellent job! Forget doing my own, I'll just send you the schematics for my projects.
Yeah Brad I thought about purchasing DipTrace Non-Profit version (1000 pin limit - 4 layers).brad wrote:Gota love diptrace! The best darn PCB program out there!
Has for this Project Board I used just over 200 pin connections and the limit for the free version is 300 pins, Imagine if I used a double sided board, im sure Ill be reaching the limit of the free version!
I would like to say though that I made all the traces and connections myself, and didnt use the Auto-Trace functions that you get with Diptrace.
- sdudley
Nice to be back... I miss you silly guys!bitfogav wrote: Thanks Stacy nice to see you back
Well it's hard not to miss us
- sdudley
Hey guys,
Brad convinced me to move from Eagle to DipTrace (so I did). I am having trouble saving my schematics to an image.
I see you guys posting images of PCB layout's so I know it can be done there (I have yet to open the PCB editor), but how about in the schematic editor?
What am I missing here?
Thanks,
Thanks,
Hey Stacy,
Well if your using diptrace schematics then the way I would convert my schematics to a image is by clicking on the preview button: Then click on the save button, this will save the schematics as an image: Then you should get a box pop up like this to save the image: There is probably an easier way than this but this is the way I found.
- sdudley
Thanks bitfogav.
I also posted the question on the DipTrace forums and was given the same answer. Just not as well done as yours!
Nice one bitfogav!
Users browsing this forum: No registered users and 19 guests
